Go to Post Don'tcha love technology? :p - Cory [more]
Unread 19-02-2008, 23:01
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
CIM motor heatsink
Our team this year went with a 28x28 frame so everything is very compacted. This is leading me to worry about heat issues. Anyone know of any CIM motor heat sinks? (I saw 1024 put heat sinks on their fp motors) or the diameter of the motor so we could pick up and jerry rig a heat sink.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 19-02-2008, 23:03
CraigHickman
Posts: n/a
Re: CIM motor heatsink
It's about 2.5" in diameter. However, due to the black powdercoating, you're going to want to check the sizing with calipers, so you get a good fit on your motors.
Unread 19-02-2008, 23:05
Aren_Hill's Avatar
Build Nifty Things
another option is find a common heatsink and bend it to a 2.5"diameter.
On our robot we had a fp motor getting rather toasty so we took the stock heatsink from a students quadcore processor and easily modified it to slide over the motor with a fan mounted on it, it works quite nicely
A guy who likes robots.
Unread 19-02-2008, 23:11
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
i believe that was my heatsink
Unread 19-02-2008, 23:25
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
they also sell performance RC heatsinks for 600 size motors such as the fp motor. with fans for about $20
Unread 19-02-2008, 23:28
Woody,
It sounds as if you have some weight to spare but heatsinks on the outside of motors are very inefficient for cooling. The majority of heat is built up inside the motor armature due to high current. That heat is only conducted to the outside of the motor by radiation, a little convection and conduction through the motor shaft via the bearings. If you are experiencing heat on the CIM motor, you have raised the temperature of not only the armature but the magnet and outside case structure as well. I would guess that if the case were above 100 degrees, the internal temp might even be twice that. The motor will simply not last long with that stress. You should really look at the motor curve as it applies to your design. When you get into the finals, you might not survive with the repetitive heating of the motor as matches get closer together and driving becomes more difficult.
Unread 19-02-2008, 23:42
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
The CIM motors are pretty rugged, I don't think they'll give you a problem.
Unread 20-02-2008, 11:09
Woody1458's Avatar
AKA: Woody Jansen
Thank for the advice guys. One thing I forgot to mention is that due to our compact spacing we had to put the compressor right in between our four CIMs, so I think one way or another the out side will get hot no matter what I do. BTW I contested that placement but the team decided against me, so telling me to move the compressor would be mostly pointless.
GO DANVILLANS!!
CIM Motor Differences Kims Robot Motors 2 07-02-2008 14:41
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
CIM motor gearbox tseres Motors 3 22-05-2007 22:31
dewalt motor VS. CIM motor John Gutmann Motors 12 10-01-2007 18:57
No CIM Motor in 2006? Sscamatt Rumor Mill 21 22-03-2005 22:47
