Go to Post I wanted to make an epoxy/carbon fiber/fiberglass arm for our 'bot, but I was outvoted by conservative teenagers. Oh well... - Rick TYler [more]
Unread 20-02-2008, 12:29
bsmmoney bsmmoney is offline
Team President
AKA: Brent
FRC #0617 (Locomotives)
bsmmoney is an unknown quantity at this point
Send a message via AIM to bsmmoney
Chicklet Amps
On the IFI website, the chicklet is specified to only allow 500mA, but the backup battery is 750mA. Can someone explain this? Is there an issue on the website? Thanks!
Unread 20-02-2008, 12:31
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Chicklet Amps
500mA is the maximum current draw of the Chicklet. 700mAh is the capacity of the backup battery. They are different units referring to different characteristics. The backup battery should do a fine job of powering the Chicklet.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-02-2008, 12:40
dtengineering's Avatar
AKA: Jason Brett
Re: Chicklet Amps
700mAh refers to the fact that the backup battery should be able to provide 700mA for 1 hour. (700mA x 1 h = 700mAh). Typically a NiCd battery such as this can be discharged at between 10 - 20 "C", where "C" represents the rated one hour charge capacity (700mAh, in this case). So in other words, the peak current draw that you could place on the backup battery would be around 7-14 amps, but at 7A it would only last for 6 minutes (7000mA x 0.1h = 700mAh). Actually it would last for less than that, as the quicker you drain a battery, the less efficient it is.
A similar thing occurs with the 18Ah pb-acid gel cell batteries used for the robot. Theoretically in a three minute match (I'm rounding up to simplify the math) you could draw 18Ah / .05h = 360amps for the duration of the match. Again, physics and chemistry intervene to reduce this discharge rate, but the estimate forms a good starting point. Considering that there is a 120A breaker on the robot, any fully-charged battery should be good for at least two full matches at FULL power for 100% of the match time... although the batteries are much happier if you can charge them after each match.
Jason
Unread 20-02-2008, 15:43
Re: Chicklet Amps
I believe the current specification is how much current can be delivered to a USB connected device. This relates to the current delivered by the USB host (Chicklet) and you will find similar specifications on USB cards for your computers.
As Jason pointed out, you do not want to draw that much current from the Backup battery so keep your USB devices to a minimum and be careful that each one does not require huge amounts of current. A NiCad battery of this type will maintain a 700maHr rate when discharged at 1/10 C. i.e. 70 ma for at least 10 hours. Between 1/10 C and 1 C that 700maHr rating will fall. At 1 C it is likely 500maHr or less.
Unread 20-02-2008, 17:19
Fab.Master's Avatar
Fab.Master Fab.Master is offline
Fab.Master will become famous soon enough
Re: Chicklet Amps
the reason we were asking was because the rules state it can be powered by any 7.2 volt battery and I wanted to make sure that a 4200mah battery would fry a $120 chicklet because our mentor would kill me
Unread 20-02-2008, 17:32
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Chicklet Amps
Nah, as long as the voltage is right, you won't fry anything. Even if it couldn't supply enough current, it wouldn't break anything.
Jacob
Unread 21-02-2008, 07:23
Re: Chicklet Amps
I wanted to make sure that a 4200mah battery...
That's a really big battery to have at the player station.
Unread 21-02-2008, 07:44
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Chicklet Amps
The 500 mA current rating on the Chicklet matches the USB spec. The actual current draw varies based on the device being connected. Of all the supported devices, the Microsoft mouse draws the most current at 100mA. You can use as large of a battery as you wish so long as the voltage does not exceed 15 volts DC. Voltages higher than 15VDC cause excessive heat and could damage the Chicklet.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 21-02-2008, 09:02
AKA: Jacob Komar
Re: Chicklet Amps
I made this mistake the other day.
http://www.chiefdelphi.com/forums/sh...40&postcount=3
While you most certainly could use a 7.2-15v battery, it would not conform with the rules:
Originally Posted by GDC - The Robot
<R106> Devices connected to the joystick ports of the Operator Interface via a FIRST-approved USB adapter (the only approved USB adapter is IFI Part Number USB-CHICKLET) are excluded from Rule <R105>. If used, this USB adapter must be powered with a 7.2V battery functionally identical to the back-up battery. Power from the competition port or any other source shall not be used to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a MATCH.
*sigh*
Jacob
AMPs for RC and Compressor beemgruem Electrical 9 10-01-2008 10:08
40 amps a must? O AntiGravity O Technical Discussion 16 13-02-2003 22:08
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
6 awg wire how much amps? viper Electrical 3 20-01-2003 14:29
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
