[FTC]: Flag Holder
Any recommendations on what to use for an FTC flag holder?
Re: [FTC]: Flag Holder
You have use something that won't damage the flag. Standard things I have seen are:
- A piece of vex square shaft mounted with 2 shaft collars - Long screws from the kit with a keps or lock nut Note the hex standoffs are too wide for most staws and will often cause issues. |
Doesn't the flag holder need to be a tube of some sort?
Nope. The flag, itself, is a straw so the holder can be a vertical piece of shaft. My teams have used shaft successfully for two years now. Those silly FRC folks have the flag thing backwards
.Referrring to <R13> in the interactive manual here: http://forums.usfirst.org/showpost.p...51&postcount=2 it tells you the dimensions of the flag tube (part of the flag itself) |
Thanks everyone.
| Flag, Flag Holder vs Trackballs | Swampdude | Rules/Strategy | 29 | 09-03-2008 09:17 |
| Flag Holder (?) | Spiders | Technical Discussion | 8 | 24-02-2008 16:48 |
| Flag Holder Mounts | RoboGeek99 | General Forum | 10 | 17-02-2008 19:32 |
| Flag Holder info | Magnechu | Kit & Additional Hardware | 4 | 13-02-2008 19:08 |
| Flag holder position | Rosiebotboss | General Forum | 13 | 25-01-2008 22:11 |
