Go to Post Relax. Have fun. Enjoy the improvements. Build what you want to. - Rich Kressly [more]
Unread 20-02-2008, 13:26
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
pic: 1902 2008 Bot as Shipped.
Unread 20-02-2008, 13:37
footballguy footballguy is offline
FRC #0217
footballguy is an unknown quantity at this point
Re: pic: 1902 2008 Bot as Shipped.
Looking forward to seeing "Oink Oink Boom" in action
Unread 20-02-2008, 13:52
iR3 Creative
AKA: Dan Richardson
2008 Specs
Weight: 119.7 Lbs
Functions: Hurdle( I guess that means herd to ), Cap, Lap, Effective Hybrid
Method: Can hurdle forwards and backwards, also cap and knock without touching the ball on the other side. See below for hybrid.
Finish: Powder Coated Neon Green and Safety orange for obnoxious awesomeness.
Drive:
6 Wheel Drive: 2 AM performance, 4 kit wheels, single plain drive.
2 Speed Frame Integrated Am Shifter: 14-15fps, 6-8Fps.
Fast and maneuverable.
Arm:
2" Bore 12" Stroke Piston running at 60psi working pressure for bottom axis, with variable positions if it needs to be changed during competition.
Elbow Joint is driven by a 256:1 AM Planetary Gearbox from the fp, with a further 3:1 sprocket reduction.
Elbow joint Moves at ~30 degrees per second allowing for quick hurdles and caps.
100 Click Encoder for Position Feedback in both autonomous and presets for arm in Operator Control.
2 75 lbs Gas struts to provide for absolutely no back drive on the arm with ball stowed, Motors work to position the arm both up and down.
Manipulator:
Banebot 64:1 on 3:1 reduction for intake wheels.
Intake wheels are 2008 kit wheels covered with High Traction Roughtop tread.
"Tusks" 1/8" Aluminum with schedule 40 all thread and tapped aluminum round bar to keep it in compression.
Tusks Forced closed by a 35lbs gas strut with two linear springs compressed around their shaft to create a constant pressure of 35 lbs + k*x of the linear springs.
Hybrid:
Autonomous sub routines set by location of the ball sent in by the robocoach via the IR.
Encoders inline with drive train and combined with a gyro using a PID controller for a field positioning system. I've been told tracking at +/- 3 inches tho not verified.
Sonar Sensors for collision "preparedness" and wall adjustments.
Consistently scored 20 points in autonomous and can hit all three balls based on the robocoachs input.
Comments on the video: I've been asked why we can't cap, We can, its actually much easier than hurdling, but just didn't show it because we were only filming and practicing hurdling. The video was filmed on a dead battery so its a bit slow ( 14-15 fps sucks battery fast on a 6wd ) and we only had about 15 minutes of drive time or so.
Improvements: Drivers need lots of practice, we finished a bit later than usual this year. Hybrid needs to be finalized and hopefully begin knocking the other ball off more consistently.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 20-02-2008, 14:32
iR3 Creative
AKA: Dan Richardson
Looking forward to seeing the Chickens in ATL as well!
Unread 20-02-2008, 15:16
Gabe Salas Jr.'s Avatar
Gabe Salas Jr. Gabe Salas Jr. is offline
Ri3D 1.0
AKA: CrazyBear
FRC #0233
Gabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant future
Thank you for answering all the questions I wanted to ask.
Again, it looks amazing. I can't wait to see the powder coat and the robot in action at UCF.
"Confidence, not arrogance."
Does your robot use its powers for good, or for awesome?
Unread 20-02-2008, 16:00
Cooley744's Avatar
Cooley744 Cooley744 is offline
Cooley744
AKA: Lauren
FRC #0744 (Shark Attack)
Cooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to behold
Send a message via AIM to Cooley744
Looks really nice. I can't wait till UCF Regional. It's gonna be so much fun!
For whatever you do, work at it with all your heart, as working for the Lord, not for men.
Colossians 3:23
Proud graduate and now lead strategy mentor and driving coach for 744 Shark Attack.
Unread 20-02-2008, 17:27
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
great job guys, cant wait to see it in the big N.O.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 20-02-2008, 17:36
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Note the last 15 seconds of the video is the hybrid mode in action, knocking down the first ball and just missing the second ball.
We estimate 50% of our games we will get 20 points or more in hybrid mode, but we will have to see what really happens at Florida regional.
Doug Leppard
Unread 20-02-2008, 17:42
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
It looks great guys, nice work. I know with a little practice she'll be singing. It looks like your hybrid mode works the same as ours. Except yours is faster
www.179swampthing.org
Unread 20-02-2008, 23:55
Git 'em!
http://www.flickr.com/photos/tmbrudy/2280443565/
Robot in 3 Days
Team 1741 2008 bot video cgredalertcc Robot Showcase 6 28-02-2008 18:46
973 Completed Bot 2008 - ARMageddon pyxelz Robot Showcase 9 20-02-2008 20:05
pic: Team 1902- Exploding Bacon 2008 Robot Matt_Kaplan1902 Extra Discussion 33 11-02-2008 13:32
simulator (now that the bot is shipped) mcktim Programming 8 08-03-2006 18:45
pic: 2 Robots shipped.... CD47-Bot Robot Showcase 13 04-03-2003 02:43
