Go to Post *puts on flame suit and goes to hide in the corner* :D - Wayne Doenges [more]
Unread 20-02-2008, 17:05
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: A couple questions that may be too late.
The maximum dimension would be the 60 in. height. Stating that it must start in a vertical orientation prevents you from starting with your robot on it's side.
Unread 20-02-2008, 17:09
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
If your flagholder is mounted so the top is 51" high (as it must be), then it is necessarily the longest dimension and your robot is upright. No worries.
Hi!
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Teams have been starting in a "wide" configuration for as long as I can remember. You are allowed to start facing in any direction, so long as you're touching the wall.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-02-2008, 17:12
KarlSTA KarlSTA is offline
FRC #2574
KarlSTA is an unknown quantity at this point
can anybody show a rule that disagrees with the one i posted up above because that CLEARLY says that it has to start in a certain direction.....
Unread 20-02-2008, 17:15
FRC #2574
thanks so much for that explanation of that "vertical" rule.....
Unread 20-02-2008, 17:16
You did by posting the rule. The robot size is 28" by 38" by 60", and the 60" has to start vertically. That's the way the box is set up. Therefore, you can either "flop" down so you have a 28" by 60" drive or a 38" by 60" drive, OR you can stay upright and have a 28" by 38" drive, oriented either "long" or "wide". If you can explain how the rule says you must start in a certain direction, I'll listen.
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
You're right. The rule does say you have to start in a certain direction, such that your longest dimension is pointing towards the ceiling. Since the top of your flag holder is 51" off the ground, it should be guaranteed that this is the case. This only constrains two of your rotational degrees of freedom, so you're still free to rotate about the z-axis, and thus can start facing in any direction on the xy-plane.
_
Unread 20-02-2008, 17:21
FRC #2574
we misinterpreted the rule to mean starting vertically on the horizontal plane from the wall of the field.....it just turned out weird....thanks to all
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
<G18> states the maximum dimension of the robot must be oriented vertically in the STARTING CONFIGURATION. That dimension can become horizontal in the PLAYING CONFIGURATION. There is no rule about how the driving direction is oriented with respect to the field or robot.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 22-02-2008, 22:08
FRC #2574
man....i thought after the build deadline it would get easier....today we got a call from fedex....here's something how it goes
Fedex (F): We lost your shipment....what does it look like?
US: It's a 4ft x 4ft x 5'6" plywood crate spraypainted blue with the number 2574 painted on it.
F: And what would you estimate it's value at (thats when we start worryin)
US: Ohhh....about $10,000
F: oh..........okay (now whats goin on). And what would it look like if it was broken open?
US: Well.....theres a lot of robotics stuff. And it has a lot of steel arms and a controller platform on plexiglass and steel. And some motors and stuff.
F: Okay we'll let you know the status of your shipment......(that phone call went nicely)
don't worry...they called back later and found it
Unread 22-02-2008, 22:45
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Well I can tell you that MY stomach would be in knots until the follow up call confirming they found it.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 22-02-2008, 23:02
Alalea Alalea is offline
AKA: Heidi
FRC #1688
Alalea will become famous soon enough
D*MN! I would've been going insane! I would've been crying and stuff!
I love deadlines. I like the whooshing sound they make as they fly by.
- Douglas Adams (DNA) 1952 - 2001
pic: Too bad it's too late.... Cody Carey Chit-Chat 20 31-05-2006 16:54
[FVG] Too late to join? Matt Krass FIRST-related Organizations 3 28-10-2004 21:36
Too late for 2004? nwagers Starting New Teams 16 30-09-2003 11:56
couple of questions... archiver 2001 5 23-06-2002 22:48
too late to register? RobDeCotiis Championship Event 8 09-04-2002 18:46
