Go to Post Just put it in the dryer for a few extra cycles. That should shrink it down nice and small. - notmattlythgoe [more]
Unread 20-02-2008, 16:29
AndrewSTA AndrewSTA is offline
FRC #2574
AndrewSTA is an unknown quantity at this point
A couple questions that may be too late.
Okay, so we finished our robot and sent it off.
Now we reread the rules, and seem to have some potential problems.
So Hybrid mode is 15 seconds correct? Rumors have been stirring that it is 30 seconds, anyone know?
And also, as most robots are
Like that and drive up, (so the width is only 28 or so).
Our bot is 36 wide, and 27 deep. is this going to be a problem for our starting configuration? Rumors have also been stirring that there will be problems associated with this as well. Anyone know? I know there are a couple bots out there with the same configuration?
Here's a diagram.
[__]
Thanks in advance.
Unread 20-02-2008, 16:33
GaryVoshol's Avatar
Cogito ergo arbitro
Re: A couple questions that may be too late.
15 seconds is correct.
Drive configuration is no problem.
(since 2004)
Unread 20-02-2008, 16:43
FRC #2574
Where did you see the thing about drive configuration? Our challenge we are foreseeing is that in the rules it says that the long dimension must be away from you, or something to that effect. Thanks.
Unread 20-02-2008, 17:01
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
<R11> describes the size limitations. There is no mention of drive direction, nor should there be.
There are crab/swerve drive robots that can move in arbitrary directions, so "forward" is not necessary aligned with the "front" of those robot. All the inspectors will care about is the robot fitting in the box in its starting configuration.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 20-02-2008, 17:03
KarlSTA KarlSTA is offline
FRC #2574
KarlSTA is an unknown quantity at this point
We are wondering if we're gonna have to start "sideways" for our robot becuase it drive with the wider way forward. Here is the rule.
<G18> ROBOT Orientation- ROBOTS must start the MATCH with their long (maximum) dimension in a vertical orientation. After the start of the MATCH, ROBOTS may change their orientation such that the long dimension is either vertical or horizontal. Refer to Rule <R08> and Rule <R17> to determine how this affects the use of STANDARD BUMPERS and FLAGS.
If we could get a FIRST inspector or a mentor to respond to this...that would be EXCELLENT.
Unread 20-02-2008, 17:05
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
The maximum dimension would be the 60 in. height. Stating that it must start in a vertical orientation prevents you from starting with your robot on it's side.
Unread 20-02-2008, 17:09
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
If your flagholder is mounted so the top is 51" high (as it must be), then it is necessarily the longest dimension and your robot is upright. No worries.
Hi!
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Teams have been starting in a "wide" configuration for as long as I can remember. You are allowed to start facing in any direction, so long as you're touching the wall.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-02-2008, 17:11
Assume the driving base of your robot is just under 38"x28". If your robot is short (say 30" tall), then the long dimension will be 38" length. This must be the vertical direction for your starting configuration, so your robot will need to flip downward to get the wheels on the floor.
I doubt teams will do this, though I've seen teams (HOT?) establish a very long drive base (60") by flipping from the starting configuration into driving configuration.
Given the flag height requirement, I suspect virtually all robots will have a dimension greater than 38" and it will be vertical at the start of the match and (hopefully ) remain that way throughout the match.
Unread 20-02-2008, 17:12
FRC #2574
can anybody show a rule that disagrees with the one i posted up above because that CLEARLY says that it has to start in a certain direction.....
Unread 20-02-2008, 17:15
FRC #2574
thanks so much for that explanation of that "vertical" rule.....
Unread 20-02-2008, 17:16
You did by posting the rule. The robot size is 28" by 38" by 60", and the 60" has to start vertically. That's the way the box is set up. Therefore, you can either "flop" down so you have a 28" by 60" drive or a 38" by 60" drive, OR you can stay upright and have a 28" by 38" drive, oriented either "long" or "wide". If you can explain how the rule says you must start in a certain direction, I'll listen.
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
You're right. The rule does say you have to start in a certain direction, such that your longest dimension is pointing towards the ceiling. Since the top of your flag holder is 51" off the ground, it should be guaranteed that this is the case. This only constrains two of your rotational degrees of freedom, so you're still free to rotate about the z-axis, and thus can start facing in any direction on the xy-plane.
_
Unread 20-02-2008, 17:21
FRC #2574
we misinterpreted the rule to mean starting vertically on the horizontal plane from the wall of the field.....it just turned out weird....thanks to all
<G18> states the maximum dimension of the robot must be oriented vertically in the STARTING CONFIGURATION. That dimension can become horizontal in the PLAYING CONFIGURATION. There is no rule about how the driving direction is oriented with respect to the field or robot.
pic: Too bad it's too late.... Cody Carey Chit-Chat 20 31-05-2006 16:54
[FVG] Too late to join? Matt Krass FIRST-related Organizations 3 28-10-2004 21:36
Too late for 2004? nwagers Starting New Teams 16 30-09-2003 11:56
couple of questions... archiver 2001 5 23-06-2002 22:48
too late to register? RobDeCotiis Championship Event 8 09-04-2002 18:46
