Re: What kind of robot to build for a convention?
You'll need: - a base with either omniwheels or a pair of wheels and castors - last year's camera, with a pan/tilt servo assembly sitting on top of it. - The green light box, and a 12V supply, as a portable device. Mounting the pan/tilt assembly on the front of a basic rectangular base actually makes it look like some kind of a "one eyed puppy"... Behavior: - You show it the light box (you'll need a 12V source on your belt), and it follows you around. Algorithm: - Whenever it can't see the light it starts "looking around" searching for it. Once the camera is tracking: - IF the camera is left or right of the forward direction when the tracking settles, the base then rotates in place to face it. Once facing the light: - IF the tilt angle is less than some angle (~45 degrees), move forward. - IF the tilt angle is greater than a high angle (~60 degrees), back up. Now, whenever the tilt angle is between the two set points, the robot sits in front of you and gazes longingly at the light, like a puppy begging for a treat. Approach it, and it backs away so it's "not stepped on". Turn the light off, and it starts looking around for it. If using an omnibase, it could also "sidestep" to try to get in front of the light, as well. Bumper switches increase the range of behaviors. Team 470 built one of these, and it was a HUGE hit at several events we shared. We're planning on building a FRC scale one this fall, for parades. For extra fun, you could have it do some "hey, pay attention to me" behaviors once sitting there if idle too long. - Make it bark. (Add a sound system and a digital recorder card, and trigger it.) - Have it "sit up and beg" (or raise its "paws") with additional motors & casters - Add a "pet me" pushbutton sensor above it's eye, which makes it run in circles for a minute with joy (etc.) Building the hardware for this isn't tough at all. - Keith McClary Chief Engineer, FRC 1502, "Technical Difficulties" "We make easy things look difficult, every day!" |
| What kind of computer do you use for programming? | Rohan_DHS | Programming | 21 | 05-01-2006 11:52 |
| What kind of materials do you use for your wheels? | Alex Cormier | Technical Discussion | 1 | 24-01-2005 19:19 |
| what kind of robot will win? | Bcahn836 | Championship Event | 44 | 12-04-2004 00:02 |
| what kind of design are people going for? | mrobrien | Rules/Strategy | 47 | 02-04-2003 12:23 |
| WHat KInd Of Robot do you have | EIROBOTICS86 | General Forum | 12 | 13-02-2003 02:29 |
