Go to Post Manual labor experience with engineering training is a powerful combination. - N7UJJ [more]
  #31   Spotlight this post!
Unread 20-02-2008, 18:04
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Ross340 will become famous soon enoughRoss340 will become famous soon enough
Re: Team 1501 is coming to play
so is the curved surface on the back in case of a tip?
  #32   Spotlight this post!
Unread 20-02-2008, 19:04
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
I think it's because it looks cool.
The secondary reason might be because curves make monocoque extremely strong, but that's still secondary :-)
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
  #33   Spotlight this post!
Unread 20-02-2008, 19:20
Nathan
Maybe also to help it fit in the 80"? Or is that a tertiary reason?
  #34   Spotlight this post!
Unread 21-02-2008, 12:45
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
First lets say that we don't have a typical front to our robot this year. We have a Sail Side and a Fork Side. It took many confusing conversations before we came to this terminology, since we drive forward on either side of the robot being the forward direction with a flip of a lever switch.
The curved surface is the Sail Side and is curved for its strength and to allow the initial starting dimensions. The pivoting action provides the telescoping of the carriage rails to "Load" our launch device and simultainously pick up the ball in the same motion. We are very proud of this design and very confident that the safety judges will agree that our tension device is safe off the field, which was a major concern through the design phase.
If you like the robot so far, just wait until you see the "remove the ball from the overpass thingy" we have yet to reveal. Along with the vision routines this device will be very simple and very effective.
  #35   Spotlight this post!
Unread 22-02-2008, 01:03
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Cool bot...what happens if there are two trackballs of same color near each other an equal distance from your camera???
  #36   Spotlight this post!
Unread 22-02-2008, 05:34
As far as we know from the rules, that won't happen during the initial field setup for the autonomous mode as there is only to be one ball of each color on each side of the overpass at the start of autonomous mode.
  #37   Spotlight this post!
Unread 22-02-2008, 08:37
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
flamefixed is on a distinguished road
very nice robot!
are the large pistons mounted on a casing around the forkside axle shaft?
and whats the release and reset mechanism on the forks?
and are the ropes and gas piston? there to support the welds on the forks?
  #38   Spotlight this post!
Unread 22-02-2008, 10:24
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
There's a funny story associated with the piston mounting. The CAD file had them one length and the actual pistons were another. It turned out great as we were able to mount the pistons to our Omni-Wheel shafts. weight savings
If you look at the end of the forks you will see two pieces of UHMW. The robot sits on these in the starting position and the forks will fall forward when we move forward.
The gas piston (now removed) was to help the forks fall forward. We found we didn't need it. The yellow ropes are to take up the strain, of the forks when we fire. The welds won't fail. The forks would bend before that would happen. We are planning on making a second set of forks.
Good questions.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #39   Spotlight this post!
Unread 22-02-2008, 11:46
very nice way to deploy the forks.
in the other post i was referring to how do you release the forks for launch? and then bring them back down to reset?
  #40   Spotlight this post!
Unread 22-02-2008, 11:55
Chris_Elston's Avatar
Chris_Elston Chris_Elston is online now
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
check out the video again, around 0.34 through 0.38 seconds in the video you'll see the awesome release latch slide...*cough*...curt...*cough*...(inside joke)...
When the sail is in fork truck mode, the tubing is loose, no tension. we lock the latch. stretch the sail like stretching a rubber band..then we release the latch like pulling a pin. It's a safe setup when in the pits, unless we stretch the sail...
After the sled fires, we return to fork truck mode, sail returns, and the forks fall at a rate of 32.1740 ft/s² or 9.80665 m/s².
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
  #41   Spotlight this post!
Unread 22-02-2008, 11:56
AKA: Warthog
My Bad
When the sail moves forward it stretches the tubing. When we are ready to fire the operator triggers the release. The first thing that happens is the flag is moved out of the way (it's on a pivot) than the trigger is released.
When the sail is brought back, the trolley (where ball rests) moves back down the tracks using gravity. When it reaches the bottom the trigger moves out of the way (it's on a pivot) and will drop back when the trolley is past. On the trolley is a piece of angled steel that the trigger catches on.
  #42   Spotlight this post!
Unread 22-02-2008, 12:03
Goober!!!'s Avatar
Goober!!! Goober!!! is offline
I am The Goober!!!
AKA: Steve
FRC #1501 (Team Thrust)
Goober!!! is a jewel in the roughGoober!!! is a jewel in the roughGoober!!! is a jewel in the rough
Send a message via MSN to Goober!!! Send a message via Yahoo to Goober!!!
Talking Re: Team 1501 is coming to play
I’m really proud of 1501 this year with a fantastic robot. I wished I would have been there more this year, but school and work have been keeping me busy. I'm trying my hardest to get to BMR this year to cheer on the team and all the other teams that are going. So good luck to all of the teams this year!!!
Goober!!!
I am the Goober!!!
Check out the "Goofy Goober Rock" song!!!
  #43   Spotlight this post!
Unread 22-02-2008, 12:11
you mean the forks fall at a rate accelerating at 9.8 m/s² ? assuming you have perfect sliders
  #44   Spotlight this post!
Unread 22-02-2008, 21:07
http://www.chiefdelphi.com/media/photos/30674
Here is a link to a photo of the Carriage Latch Release.
  #45   Spotlight this post!
Unread 25-02-2008, 12:32
AKA: Warthog
We will once again be having the "Guess the Rivet Count" game at BMR.
The person who guesses closest the total number of rivets, in our robot, WITHOUT going over will win something nice. What it is I have no idea
The number of rivets is NOT 1501.
Strategy Coming Into Play nehalita Rules/Strategy 13 16-02-2006 20:43
Team 1501 website Wayne Doenges Website Design/Showcase 2 25-12-2005 19:16
Image Discuss: Guess who's coming to play the National Anthem? CD47-Bot Extra Discussion 7 24-02-2003 10:58
