Re: Eclipse does not work
if you are using kevins code you need to rename the ifi_frc_30.lib or ifi_frc_24.lib to ifi_frc.lib depending on wich compiler you are using
| Autonomous mode does not work | Sunny | Programming | 9 | 16-01-2008 15:31 |
| IFIloader and usb converter does not work | jasonpeinko | Control System | 9 | 09-01-2008 20:54 |
| Arcade Mode (12) does NOT work | jakk | Programming | 2 | 10-07-2006 19:27 |
| Does easy c work in nt? | Bob22341 | Programming | 2 | 12-01-2006 22:11 |
| Chaos theory does not work!!!!! | S9ar7acu3 | General Forum | 3 | 09-02-2003 11:46 |
