Go to Post I guess the freshmen had to learn the hard way, never turn your back on a robot. - Bcahn836 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 20-02-2008, 20:33
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: Archiving Recorded Regionals 2008
Originally Posted by aksimhal View Post
So, do you have to reserve the space or do they have enough cables?
Thanks,
There is no reservation, but space is limited. Usually there is only about 5 teams recording the stream, so you should be fine.
When I mean cables, I mean that you have to bring your own Composite video cables to plug into to the black box from your recording device. Also note that FIRST only provides mono sound, so you should only plug it your mono port.
There is usually a mini tv that they provide to check your feed to make sure that your feed is working properly. A power strip should also be near by.
I would also recommend that you check your setup about every 1-2 hours. In the past, I have had my recorder turned off and cables pulled from the back. While I am sure it was not purposeful, just look out for it.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
[IMG] code is Off
Getting to the 2008 Honolulu Regionals doesn't require breaking the bank da Marshalls Regional Competitions 113 10-01-2008 13:14
New Regionals in 2008 Madison Regional Competitions 48 14-09-2007 22:53
SVR 2006 Recorded Webcast Joobacca Regional Competitions 3 24-03-2006 08:53
auto archiving of posts Joe Ross CD Forum Support 4 01-01-2004 02:04
automatic archiving Joe Ross CD Forum Support 5 04-08-2003 13:27
