Go to Post It's amazing what you'll find in the FIRST Manual :) - dcarr [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:29
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
GMCI Scouting System Test in Chicago - Anyone want to help?
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 3/20/2000 11:15 PM MST
Team 66, in cooperation with team 65, is running a systems test of our networked scouting server at the Midwest regional. In order to get a better feel for how the server will perform under normal operating conditions, I am currently looking for one more team with a laptop they wish to hook into the system. The system requirements are as follows:
- Laptop computer running Windows 95/98 with an available serial port
- Null modem cable - 9-pin on one end, with whatever you need to hook to your computer on the other end.
- An installed and properly working web browser.
If you are interested, please contact me in the team 66 pit area on Thursday. If I am not in the pit area at the time, someone on my team should be able to direct you to where we are setting up for the test. See you in Chicago!
Nate
#0047 (ChiefDelphi)
Note: GM Teams Given Priority on Connections (EOM)
Posted on 3/20/2000 11:16 PM MST
In Reply to: GMCI Scouting System Test in Chicago - Anyone want to help? posted by Nate Smith on 3/20/2000 11:15 PM MST:
[EOM]
[IMG] code is Off
Scouting Network Brainstorm Jack FIRST Scouting Network 13 28-05-2003 23:25
Scouting System Name Jack FIRST Scouting Network 10 04-05-2003 21:30
The problem with scouting... archiver 2001 10 23-06-2002 23:49
