Re: Archiving Recorded Regionals 2008
This is an update to a previous post:
http://www.chiefdelphi.com/forums/sh...d.php?p=576804 This one has the 2008 regionals. For consistency and predictability sake, we have a preference in naming the movie files. General Naming Rules * Two or three character event abbreviation in lowercase, e.g. "fl" * Underscore, "_" * XOR: Qualification: Use THREE digits, "001", "047", "108". Elimination: Use "qf4m2", "sf2m1", "fm3" Awards: Use "award_" + AwardDescription. Opening: Use "openingremarks_" + "friday" or "saturday". Closing: Use "closingremarks_" + "friday" or "saturday". Else: any string that does not begin with "qf", "sf", "fm", or a digit. * ".wmv" (or whatever format extention you encoded, hopefully windows media) Notes: # Always use lowercase, please. # No spaces in a filename, please. # Sometimes a match gets replayed- name the one that counts in the standings as "fl_001.wmv". The one(s) that do NOT count, "fl_001bad1.wmv", "fl_001bad2.wmv", etc... Abbreviations are as follows: BAE SYSTEMS Granite State Regional NH Midwest Regional IL New Jersey Regional NJ Pacific Northwest Regional OR St. Louis Regional MO Arizona Regional AZ Finger Lakes Regional ROC Greater Kansas City Regional KC NASA / VCU Regional VA San Diego Regional SDC Boilermaker Regional IN Chesapeake Regional MD UTC Connecticut Regional CT Detroit Regional DT Florida Regional FL Peachtree Regional GA Pittsburgh Regional PIT Silicon Valley Regional SJ Wisconsin Regional WI Brazilian Regional BR Buckeye Regional OH Lone Star Regional TX Los Angeles Regional CA Microsoft Seattle Regional WA Oklahoma City Regional OK Sacramento Regional SAC Waterloo Regional WAT West Michigan Regional MI Israel Regional IS Bayou Regional LA Boston Regional MA Colorado Regional CO Great Lakes Regional GL Greater Toronto Regional ON Hawaii Regional HI Las Vegas Regional NV Minnesota Regional MN Palmetto Regional SC Philadelphia Regional PA SBPLI Long Island Regional LI New York City Regional NY Many thanks, KA-108 ![]() |
I'm pretty sure 2175 will be recording MN.
I think we definitely should try and pick one video format for all the videos. |
Has anyone tried SnapStream yet? (I'm downloading it right now)? Any opinions?
I have and my honest opinion is that it is far easier to just record directly with windows movie maker. SnapStream is a good program, but for this application its just too much effort to set up, firing up windows movie maker is just alot easier.
But doesn't Windows Movie Maker only output to .wmv?
#7
And my experience is batch converting out of WMV is very slow.
#8
Two capture programs that ought to be significantly easier to capture with than Windows Media Encoder or Windows Movie Maker are WinDV and VirtualVCR.
WinDV literally records straight from a DV camcorder (90% of these will take video input by buying a composite jack coupler and plugging a feed into the traditional video output port.) Then, spacebar will start and stop recording, automatically splitting the file each time, making it very easy to parse matches. (As long as you don't have it set to capture every 150th frame, like 177 did for Jersey 2007 (Though this is nice for timelapsing)). DV files are not tiny, but capturing only a few hours should not be too large. VirtualVCR serves a similar function, except it is compatible with any capture device that has a WDM driver, not just DV cameras (that means ~everything). I honestly have not used it much and am unfamiliar with the way it operates, but it could be a great alternative if you cannot capture using DV. |
#9
Interesting...
What would work best with the FIRST Regional setup? |
#10
I don't know what I'll be using yet. It's up in the air. Guess I can try to build some inexpensive rig to do a capture on. We do plan on also making our own recordings available.
#11
I put together this graphic explaining how The Blue Alliance plans to record the Boston Regional. Hopefully others can find it of use.
#12
At the regional, the feed will be provided with composite type cable or something else?
Thanks |
#14
Format: .mov or .mp4 (.h264 or MPG4) Resoultion: 640X480 VGA Video Bit Rate: 1024kbps Audio Bit Rate: 128kbps Stereo |
| Getting to the 2008 Honolulu Regionals doesn't require breaking the bank | da Marshalls | Regional Competitions | 113 | 10-01-2008 13:14 |
| New Regionals in 2008 | Madison | Regional Competitions | 48 | 14-09-2007 22:53 |
| SVR 2006 Recorded Webcast | Joobacca | Regional Competitions | 3 | 24-03-2006 08:53 |
| auto archiving of posts | Joe Ross | CD Forum Support | 4 | 01-01-2004 02:04 |
| automatic archiving | Joe Ross | CD Forum Support | 5 | 04-08-2003 13:27 |
