Go to Post But altering register values via bitwise operations in nested ternary commands is so much fun! - artdutra04 [more]
Unread 20-02-2008, 22:29
fireball3004's Avatar
fireball3004 fireball3004 is offline
James Davis
AKA: James Davis
FRC #2090 (Punahou Robotics)
Team Role: Animator
fireball3004 is an unknown quantity at this point
Send a message via AIM to fireball3004
Re: Materials
??? that's what I thought I was supposed to do, I must be missing something because it's still not working. does it only work if it has the smae title or material ID or is my computer jsut being funky?
Newbies away
Unread 20-02-2008, 22:43
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Materials
Read up into UV unwraps
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 21-02-2008, 00:39
James Davis
AKA: James Davis
Team Role: Animator
Re: Materials
Buddy, I'll be honest, I have no idea what that is, I'll look it up tomorrow because I have homework tonight. But are there any settings that need to be on to do this? I just did it by creating sub object materials and applying them through IDs, but I'm certain that's not the only way. everytime I try applying it to selection it applies it to the whole object, not just the subobjects I have selected.
Newbies away
Unread 21-02-2008, 00:51
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Re: Materials
Lol, Pete wants you to look up something else that's kind of related to sub-object materials.
I think what you're trying to do is put certain materials on certain faces, right?
Every face on your object has a number called the Material ID. You assign different materials to different IDs. So, if you have a simple building, the walls could be set to ID 1, the windows could be ID 2, and the roof could be ID 3. You set them by selecting the polygons and finding the set material ID box somewhere in Editable Poly.
In the Material Editor, you need to make a Multi/Sub-Object material. When you do, you'll see a list of ten different little materials inside it, each with a number next to it - its Material ID. To assign materials to the house for example, you could set the number of sub materials to 3, set the material #1 to a brick texture, set material #2 to a glass texture, and set material #3 to a shingle texture.
HTH.
Unread 21-02-2008, 02:10
James Davis
AKA: James Davis
Team Role: Animator
Re: Materials
mm, thanks mazin, I just figured that out, but is there anyways to do it without IDs? In the tutorials I reviewed to figure out this problem, they simply selecteed and applied the texture.
Newbies away
Materials stinger 3D Animation and Competition 3 26-02-2005 17:47
Materials Jeff K. General Forum 11 22-01-2005 02:24
materials nick_champ_2 General Forum 7 05-02-2003 20:02
Materials archiver 2000 1 24-06-2002 00:20
Materials Finch Rules/Strategy 2 28-01-2002 23:00
