Go to Post Eh, typical FIRST team, take something awesome and make it even better. - rsisk [more]
Unread 18-02-2008, 21:53
jasonpeinko jasonpeinko is offline
FRC #1087
jasonpeinko is an unknown quantity at this point
Eclipse does not work
Im trying to compile the code with eclipse but i get a stupid error,
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - could not find file 'ifi_frc_8722.lib'.
Errors    : 1
Mplab died with wine and i cannot get it working again something about not being able to create the display module.
Unread 19-02-2008, 09:46
FRC #1087
Re: Eclipse does not work
is there a way to compile with command line?
Unread 20-02-2008, 20:24
gauntletguy gauntletguy is offline
AKA: Eric Nelson
FRC #2771
gauntletguy is an unknown quantity at this point
Send a message via AIM to gauntletguy
if you are using kevins code you need to rename the ifi_frc_30.lib or ifi_frc_24.lib to ifi_frc.lib depending on wich compiler you are using
Unread 20-02-2008, 22:54
Elgin Clock's Avatar
FRC #0237 (Black Magic)
If(eclipse_active
Then(Hide_moon
w00t!
Unread 20-02-2008, 22:58
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
Originally Posted by Elgin Clock View Post
If(eclipse_active
Then(Hide_moon
w00t!
If(Moon_hidden_suddenly
Then(
RPI '12
Unread 20-02-2008, 23:32
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
If(eclipse_active
Then(Hide_moon
w00t!
OK, bonus points for the multi-level nerd humor. Nicely done.
Unread 22-02-2008, 09:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
if(nerds_funny==1)
Heck_Freezes_Over = 1;
Unread 22-02-2008, 09:51
Racer26 Racer26 is offline
the ==1 in your if statement is redundant.
Autonomous mode does not work Sunny Programming 9 16-01-2008 15:31
IFIloader and usb converter does not work jasonpeinko Control System 9 09-01-2008 20:54
Arcade Mode (12) does NOT work jakk Programming 2 10-07-2006 19:27
Does easy c work in nt? Bob22341 Programming 2 12-01-2006 22:11
Chaos theory does not work!!!!! S9ar7acu3 General Forum 3 09-02-2003 11:46
