Go to Post if your true love is building robots, this makes perfect sense - EddieMcD [more]
Unread 20-02-2008, 19:40
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
flamefixed is on a distinguished road
team 219 lift video/semi reveal
http://video.google.com/videoplay?do...83199508&hl=en
the last stage, or few feet of movement, is not at full power. this was one of the first test runs and i wanted to baby it near the top. also, the baby-ing was done above the height needed to hurdle. the lift extends to 40 inches above the top of the rack.
this is driven by two cims feeding into our fabricated gearbox shown here
http://www.chiefdelphi.com/media/photos/30369
more pics of the bot:
http://www.chiefdelphi.com/media/photos/30371
http://www.chiefdelphi.com/media/photos/30370
more pics on the way
lift: we are sporting an 8020 stock lift angled back slightly to keep the weight over the robot to help prevent tipping.
this lift uses 8020 nylon bearings and t slots and custon made delrin sliders.
it has cascade style belting, one belt for the left, one for the right, side of the lift with an easy tensioning method of loosening a slider with an allen wrench and using a quickgrip to snug up the belt. as stated in the other thread, two cims power our lift up AND down in about two seconds. two cims were used because there are 4 sections to the lift. this helped maximize overlap (i believe 30-40% overlap) on each section, making the lift extremely stable. also, the top of the lift can dislodge the trackball.
grabber: the ball grabber is a forklift with the end tines bent up and in to secure the ball. the forks are driven by a window motor so as to fold up for starting configuration, added safety during the match, and to fold down onto the trackball to grab it. the forks are spring-hinged at a 45* angle so when we either drive the lift down, or actuate the forks, the tines spread around the ball until it reaches the bottom and close. the force down by the ball is pushing on the hinge in the way it does not want to open, therefore securely holding it. the tines also rest on a shoulder so when we have the trackball, the tines flex slightly, causing more friction on the shoulder and preventing any spread. this ability to come down from the top of the ball makes it much easier to trap and contain rolling and bouncing trackballs.
kicker: mounted at the top of the lift is an arm attached to another window motor. this arm swings out and, with a freely spinning wheel, rolls the ball off our forklift and over the rack very effectively.
any questions or comments are welcome and ill try my best to answer them as accurately and quickly as possible!
Unread 21-02-2008, 02:44
Lucretius Lucretius is offline
#395 Mentor, #1884 Alumnus
FRC #0395 (2 Train Robotics)
Lucretius is an unknown quantity at this point
Re: team 219 lift video/semi reveal
Looks nice! We've been having a lot of trouble with our tower, which is powered by two Fisher-Price motors at the moment. How many CIMs you using, total?
Unread 21-02-2008, 05:06
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Seems like the ball might tend to fall off if another robot "accidently" "bumps" into yours. Is this the final version or did you add something to compensate for that?
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 21-02-2008, 18:06
2 CIMS on the lift, 2 for the drive.
the ball is surprisingly stable because of the forks ability to flex. driving it, shaking it, and hitting it with another robot, and some kids foot, did not affect it. also some precision touching and i was able to start bouncing the ball back and forth between each fork. practice, practice, practice.
more video - http://www.youtube.com/watch?v=_S5Bqsrn9b0
Unread 26-02-2008, 21:24
as the nj regional draws closer...
bump
Good Time To Reveal Robot? thefro526 General Forum 5 01-02-2008 21:09
VIDEO: 1947 LIFT Tottanka Robot Showcase 1 16-02-2007 03:48
GTR Semi-Finals Highlight Video Adrienne E. Robot Showcase 10 19-05-2006 20:38
pic: team 1596 Electronics (Semi-Final) the_short1 Robot Showcase 4 04-03-2006 21:19
pic: Team 219 CD47-Bot Robot Showcase 2 26-02-2004 15:35
