Go to Post More resistors Igor! - BitTwiddler [more]
Unread 19-02-2008, 19:20
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Our teams worries
No pics, just sharing some facts like how many times we predicted we'll get disabled during a match.
We have a SINGLE scissor lift going up to knock the ball off and its flimsy. (Wasn't my idea...) If we hit the ball on the wrong spot, then the ball comes back down and pins our scissor lift. And if we do get it down and our arms are deployed, then were screwed becuase it will land on our arms (2 pieces of 1 inch wide steel tubing on each arm) and incompletely destroy them.
My prediction is that we get disabled about 4 or 5 times. Whats yours?
EDIT: I'll post some pics later.
EDIT AGAIN:
Some pics:
The robot without the side paneling with the arms deployed.
The scissor lift
Deployed lift
Prototyping of the arms. This is a working model and our final design.
Unread 19-02-2008, 19:54
BK Lounge's Avatar
BK Lounge BK Lounge is offline
Brian Kyte
AKA: BK Lounge
FRC #1591 (Greece Gladiators)
Team Role: Driver
BK Lounge is an unknown quantity at this point
Send a message via AIM to BK Lounge
Re: Our teams worries
way to be a negative nancy. i dont think ur robot will break 4-5 times. just try abd avoid getting ur wooden arms rammed.
my team made huge metal claws. in a scrimmage they took one hell of a beating. hope u get nice opponents
nuts hold the world together, the world holds us, i hope we didnt forget to tighten them nuts
Unread 19-02-2008, 19:56
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
ouch, a rookie team i take it? You may never know it might work better then you think.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 19-02-2008, 21:04
zacattack's Avatar
zacattack zacattack is offline
AKA: Zach Fisher
FRC #1724 (Weber Fever)
zacattack has a spectacular aura aboutzacattack has a spectacular aura aboutzacattack has a spectacular aura about
Your totally S.O.L.!!!!, if it fails at the comp rip everything off the and make a racing bot and nothing else.
Unread 19-02-2008, 22:20
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Don't panic. If things go horribly wrong at the competition, ask your pit neighbors for advice or help. They will do their best to help you succeed.
It may go better than you think. Even if it doesn't, no matter how the robot does, you're still going to learn a lot, and that's the point of this exercise. Don't give up.
Our rookie season, we had more robot problems than you can imagine -- six major drivetrain failures during matches, scoring mechanism design problems, and general steering problems (casters can result in a robot that drives like a broken shopping cart). We kept plugging at it and troubleshooting between matches. We didn't ask for help, but in retrospect we should have. By the end of the regional, there probably wasn't another team there that could change a broken axle as fast as us. The next year, our robot was a lot more mechanically and structurally sound. This year, it's pretty nice, and we weren't bolting on major assemblies for the first time on ship day.
Based on your analysis of your robot, I'd suggest keeping the claws in to protect them while the lift is up. If you're a punch and herd robot, you're not likely to need to use both at once. I'd also suggest adding chain tensioners to your drivetrain at the regional if you haven't since those pictures were taken, since your chains are long and look a bit loose. (That's part of what did us in as rookies.)
Unread 19-02-2008, 22:49
Yeah, I totally agree on these points. Which regional(s) are you attending btw?
All in all, the robot really isn't what matters, as cliche as that sounds, you do end up learning an amazing amount of stuff on the field and in the pits. All I can say is good luck and I hope you do great
btw, how high up does the scissor lift extend? It looks to me that you could have shortened it and used that loss of weight to add something that would create more stability for it.
Unread 20-02-2008, 12:27
That guy
AKA: Dennis
I know it looks bad, but our team (145) has been around for 11 years now and last year was one of our worst. We started our with an awesome design, but as the build season went one we fount out that things weren't going to work. So almost everything BUT the drive train was redesigned. Well in the long run we where up at 3Am trying to finish our robot the day before ship. The bot went into the crate in pieces. We spend almost all of our first day at competition trying to get our arm and ramps to work. So we got in like 2 practice matches. Still at the first day of qualification matches all we could do is drive around and play defense. We didn't get our Ramps working until the LAST qualification match and we didnt get picked for alliance partners. The only good thing that happened is that we where the best defensive robot there. Dont let things get ya down and out cause you may never know things might bet better then you think. But if they arn't look twords next year.
Unread 20-02-2008, 12:51
dtengineering's Avatar
AKA: Jason Brett
I notice this is your rookie year. Just having a robot that passes tech and moves around the field is no small acheivement. It sounds like you would like to have your robot at a more advanced stage of development, but I can assure you that you are far ahead of where we were in our rookie year.
You will find that as you learn and as your team develops that the robots will become more advanced and meeting ship deadlines will become easier. Most importantly, however, when you get to the competition you will find that there are lots of people there to help you out and lots of opportunities to improve your machine.
In our first year we got to the tournament only to discover that we couldn't turn! We had done all our testing on cement, and the carpet had wayyy to much traction. We spent our practice day modifying the robot to turn (thanks to some help from team 1241... Rick Hansen Secondary for helpful advice and a lift to Home Depot among other things) then lost every match on Friday. All day Friday the students kept working on the robot, and completely changed how the robot worked.... we won every match on Saturday... although luck played a role (bad on Friday, good on Saturday) seeing our hard work pay off made it feel like we had won the whole tournament.
Don't stress that the robot you put in the crate is not exactly the robot you WANTED to put in the crate, or the robot that you expect to finish the competition with... there are about 1,400 teams around the world thinking the exact same thing... the other 100 or so probably don't have a clue what they are getting in to!
Jason
Unread 20-02-2008, 13:03
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Well, I don't think you are screwed as you state you are, but you do have some valid concerns.
First off, I'd get the programmers to pull the sissor lift down as soon as it hits it's max height, thus avoiding the ball coming down on the sissor.
I would also put some sort of protection on the end of that sissor as those corners look sharp and I do not believe you will pass inspection with those sharp corners.
Wood is not a bad choice for your gripper as long as you work with the grain. Wood has plenty of give before it breaks so the ball should not bother your gripper too much. I would be very cautious about interaction with the playing field or other robots though as they can generate far higher forces. You may want to consider creating a replacement set, or possibly redesigning them to be made out of Aluminum surrounded by PVC.
Your drivetrain looks decent enough so you should be able to score points running laps.
One more thing ... the robot looks like it has very little guarding. I'd suggest some Lexan sheeting around the robot to protect it's innerds from wandering robot arms.
This is all a learning experience, especially for rookie teams. good luck and remember to have fun.
___________________
- Tennyson, Ulysses
Unread 21-02-2008, 19:03
AKA: Brandon Liatys
Wood is not a bad choice for your gripper as long as you work with the grain. Wood has plenty of give before it breaks so the ball should not bother your gripper too much. I would be very cautious about interaction with the playing field or other robots though as they can generate far higher forces. You may want to consider creating a replacement set, or possibly redesigning them tobe made out of Aluminum surrounded by PVC.
THe sharp points have been taken care of.
"First off, I'd get the programmers to pull the sissor lift down as soon as it hits it's max height, thus avoiding the ball coming down on the sissor."
Dude I LOVE you!
One question on that. Would that require a sensor or something?
For those wood things, we have a few backup sets.
And those are shots form before we put lexan on. We did
Unread 21-02-2008, 19:15
Cooley744's Avatar
Cooley744 Cooley744 is offline
Cooley744
AKA: Lauren
FRC #0744 (Shark Attack)
Cooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to behold
Send a message via AIM to Cooley744
Last year we used PVC arms and they broke almost every match! lol it was fun making tons and tons of spare arms for off season competitions!
For whatever you do, work at it with all your heart, as working for the Lord, not for men.
Colossians 3:23
Proud graduate and now lead strategy mentor and driving coach for 744 Shark Attack.
Unread 21-02-2008, 20:42
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Thumbs up Re: Our teams worries
All of the posts above are valid. In situations like this I like to whip out my copy of the hitchhikers guide to the galaxy and take a glance at the cover. I don't know why the word's DON'T PANIC are so soothing. From the looks of things you are actually in pretty good shape. If worst comes to worst you can transform it into a box on wheels, which in this particular game can still be quite effective. But let's not start chopping limbs off immediately. As the previous posts have already said, there is plenty of help to be found once you are at the regionals. None of the teams wants to see another team fail and you will find that most if not all of them are willing to help, and those that aren't probably have problems of their own. I also find that the inspectors themselves to also be very helpful. So, in conclusion, take a deep breath, relax. Things aren't as bad as they seem, put a smile on and get ready for the plunge. For young teams in particular I recommend making connections and soaking in the atmosphere. Have fun!!
Unread 21-02-2008, 22:30
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Hey, we had one of the exact same problems with our ball poker (a PVC pole that is winched up inside of a slightly larger piece of square aluminum). We found while testing at the Cheezy Poof's field (thanks again, guys!) that if we hit the ball near the edge, the ball wouldn't fall down but would rather push our pole against the overpass rail while it was coming down. Doesn't sound so bad, except that it became impossible for our winch to retract the pole, causing the fuse in the spike to blow, and leaving us with a robot trapped in the tiny square of the overpass. Eek! We replaced the pole with something that won't bend (huzzah for spare axles that fit inside pipe!) and added a rangefinder pointed straight up so it will be easier for us to know when we're under the ball to hopefully mitigate the problem.
Depending on how fast the scissor lift is, retracting as soon as it is up may not be enough. Our poker did that (after a small delay to reduce wear on the winch transmission) and still got pinned, though it's certainly a good idea to come back down as fast as possible in any case. Hitting the ball closer to the center would probably be the most effective strategy, and the drivers can use the tape on the finish lines to help them line up, something we couldn't do on the practice field.
For being concerned about the ball landing on your arms, could you just turn the robot before you poke or if the ball starts to fall? It would take more time, but should help prevent that problem if the arms are safely under / on the other side of the overpass.
And high five for your fellow ball-poking and arms-for-herding robot! Hurdling is SO overrated!
Unread 22-02-2008, 10:04
AKA: Brandon Liatys
Where is the tape at compared to the ball? Is it right under the center of the ball?
Unread 22-02-2008, 14:01
AKA: blacklint
It's under the far rail of the overpass, aka away from the center on your side of the field and towards you on the other side. So definitely don't center yourself on it, but it should still be a useful visual indicator.
Our fellow teams... (Request for Helping the Southern California Teams) Rachika Garcia General Forum 3 07-12-2007 01:16
Shipping Worries Aaron General Forum 2 15-02-2003 20:06
Joystick Worries Skabana159 Electrical 6 05-01-2003 23:59
Worries Jessica Boucher General Forum 25 28-09-2001 18:13
