Go to Post FIRST is about family, making new friendships, belonging somewhere, doing something you love, and finding out what your real love is in life, so when you're old and wrinkly you can look back at high school and say "This is when I found myself." - Winged Wonder [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
Unread 22-02-2008, 14:46
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: [YMTC]: Hurtling Interference YMTC
Originally Posted by Scott358 View Post
Thoughts on the following defensive strategy being called for hurdling interference??
After a the ball has left a hurdling robot of the type that needs to extend over the overpass... parking behind it and "trapping" it.
This obviously does not stop the first hurdle, but can significantly slow down/stop that robot after the hurdle.
Thoughts?
This would be covered under the pinning rules.
As far as the original topic goes: As long as bluabot has a ball in it's possession, it will be a penalty.
Defense will be played ... but most likely will be played outside the home streches.
___________________
- Tennyson, Ulysses
Unread 22-02-2008, 17:09
Not only is it pinning (and it's 6 seconds instead of 10 this year), some hurdling robots will be unaffected by this move.
Unread 25-02-2008, 00:03
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
This is a slight twist. What if Blueabot was an on the fly hurdler and even though Redabot was overtly pushing Blueabot in its' home stretch, Blueabot was still able to get a hurdle. The rule does not address whether or not the hurdler is successful in getting a hurdle, its' only concern is with the overt, blatant, or aggressive contact that INTERFERES with the hurdling attempt. It does not say interferes to the point where a robot can not make a hurdle. Redabot was interfering with Blueabot while it was attempting a hurdle, which Blueabot just happened to make anyway. Is this a case or no harm, no foul? Or does Redabot get a penalty?
I am inclined to think that Redabot would still get the penalty. If I applied no harm, no foul to other rules, such as high speed raming when the robot that is ramed does not get damaged, no harm, no foul doesn't work. The original questions may be something that the GDC needs to address. I do not think that Redabot should get away with breaking the rule just because Blueabot was successful in getting a hurdle.
If it becomes a no harm, no foul situation, would Blueabot be better off missing the hurdling attempt to get a ten point penalty on the Red Alliance instead of the eight points for a hurdle?
What are the odds that the GDC would come back and say this is a hypothetic situation? The question to the GDC should be direct. If it is clear that Redabot is breaking <G42> but Blueabot makes the hurdle anyway, does Redabot still get a penalty for breaking <G42>?
[YMTC]: YMTC: Thank You Game Design Committee Natchez You Make The Call 2 16-01-2007 23:30
YMTC - Manufacturing Steve W General Forum 46 05-09-2006 02:35
YMTC: worthy of DQ? Levin571 You Make The Call 7 15-03-2005 16:09
YMTC: Should YMTC have a future Natchez You Make The Call 13 21-04-2004 00:46
YMTC: Is it goaltending? Natchez You Make The Call 43 12-04-2004 18:03
