Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Unread 22-02-2008, 15:01
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Is there a place this year for robots that cant hurdle?
As stated in the title, If you can herd and remove balls but you cant hurdle will you be at a significant disadvantage?
Just looking for CD's thoughts
matt
Unread 22-02-2008, 15:02
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Is there a place this year for robots that cant hurdle?
We're banking on NO. There are only two trackballs per alliance; at least one robot will have to find something else to do, whether that be running laps, "rebounding" the hurdled trackballs and returning them to the hurdlers, or something else.
Hi!
Unread 22-02-2008, 15:04
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
That probably depends on your lap times.
The way I see alliance pickings going this year, most alliances will consist of two hurdlers and one fast lap runner. If you can run laps faster than most other teams, then you probably have a good chance of being picked for eliminations. The fact that you can remove balls from the overpass is a plus.
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
If not, somebody better tell JVN in a hurry.
http://www.chiefdelphi.com/forums/sh...ad.php?t=64839
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 22-02-2008, 15:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I think that there's a place on any alliance for someone who can't or choses not to hurdle. In a match like previously stated there are never more than 2 trackballs per alliance. Unless you're going to be doing some all-star amazing passes between three hurdler someone's going to need to either play defense or run laps.
Personally I think an alliance is going to need 2 decent hurdlers and one bot thats highly maneuverable and mildly powerful that can run laps and act as an annoyance to other teams. I think in some qualifying matches we're going to see the weakest hurdler (should there be three) be out in this defensive/lap scoring position. Also my theory be true I think we're going to see a lot of strong hurdlers pick another hurdler first and then a good lap runner second.
Also In this years game I like the fact that all you need is a working drivetrain to score. In the event of a catastrophic failure of all other scoring systems you may be saved by a working drivetrain. And tot hose of you who think that it can't happen it can and it will. In NJ last year I played 2 out of three of my matches without pneumatics and one of those with nothing but a right and left drive motor.
-Dustin Benedict
Unread 22-02-2008, 15:30
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
There is certainly a place for gripperbot and racerbot. The ideal alliance this year is one shooterbot, one armbot, and then one agile gripperbot to reload the shooterbot. As long as the trackballs keep being fed into the shooterbot, the alliance could get upwards of 15 hurdles per match.
RPI '12
Unread 22-02-2008, 15:34
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
A fast lap runner will run into traffic with 5 other robots and/or up to 4 balls on the field. A ferrari in traffic is no faster than a big rig truck. **extreme case** That's the disadvantage they will have.
Hurdlers will still be able to go around the track.
But the reverse scenarios cant happen.
IMO, that puts hurdlers at an advantage.
HOWEVER, there are levels of performance on how well teams can hurdle (speed and efficiency) which will affect outcome of matches.
During teleop period, the question will be, "Can a team hurdle at least once while a lapper runs around the track four times?"
Autonomous is the key.
Unread 22-02-2008, 15:39
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
matt
I believe that the non-hurdlers will make the difference in the games.
Hurdlers will mostly cancel esch other out and recieve the most defense against them, thus it will be the 'alternative scorers' that will make or break alliances.
___________________
- Tennyson, Ulysses
Unread 22-02-2008, 16:22
waialua359's Avatar
AKA: Glenn
I'm not sure on this.
I think hurdlers will try and worry about grabbing their own ball and trying to hurdle, unless your talking at the end of matches.
Both teams that have alternative scorers can cancel each other out too.
If its 3 hurdlers vs a team of 2 with one alternative scorer, I can see your point. But in the playoffs, I dont think teams will do that knowing that only 2 balls in their alliance will only be available. In fact, I would rather have a robot that focuses on defense and not let teams put a ball up at the end instead of a lapper. A lapper will have a hard time stopping a robot from putting a ball on the overpass at the end, all else equal. That's 12 points bonus equivalent to a lapper who has to do 6 laps just to tie that feat. Autonomous is the difference maker.
Unread 22-02-2008, 16:24
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
I believe a defensive herder (not a racer) could make a big difference in the game. Continuous contact between a Robot and Trackball are permissble herding. You are also allowed to herd your opposition's trackballs. Robots may also push or react against any element of the arena. No where in the rules does it say you have to be moving to herd. So if a herding Robot hanging out just past the oppositions finish line can pin the opposition's Trackball against the wall following their opponents hurdle, the best hurdler now has no Trackball to to hurdle with. Defensive Trackball management. You gotta love it.
Unread 22-02-2008, 16:29
waialua359's Avatar
AKA: Glenn
True, but when we practiced, those dammn balls move like crazy a lot more than we originally thought (since they are relatively heavy and large).
Gripping/grabbing a ball will be tough too with traffic and a whole lot of robots on the field. That will waste just as much time as trying to do a hurdle.
Unread 22-02-2008, 16:42
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I'm thinking three hurdlers.
When one hurdles there will be one waiting to get the ball for their attempt and one with the other ball racing around to hurdle.
An effective three team relay will be unstoppable.
Unread 22-02-2008, 17:06
waialua359's Avatar
AKA: Glenn
Never thought about that. GOOD POINT!
Unread 22-02-2008, 18:06
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I think 1 outstanding hurdler and 2 highspeed herders, to bring the trackballs around, will win this year.
It'll be interesting to see the different playstyles and how they react.
Less than a week before BAE
___________________
- Tennyson, Ulysses
Unread 22-02-2008, 18:15
waialua359's Avatar
AKA: Glenn
Well I guess we can all wait and see how matches play out during week 1 regionals. Too bad all of them are not NASA webcasted.
pic: This is our robot as of last night. Alot more should get done this week now that things are in place dfukuba Extra Discussion 28 25-01-2007 13:14
Fantastic Robots This Year Matt Reiland General Forum 9 25-02-2006 15:53
was there anything unique about the robots that placed 1st through 10th last year? SCYTE16 General Forum 9 16-11-2004 21:01
Will there be a BOM this year!! D@ve General Forum 2 14-12-2003 11:23
I think there are about 100 rookie teams this year! Erodge General Forum 15 19-10-2002 23:08
