Go to Post I never said there was anything wrong with the kit frame, simply that it was weak. - Viper37 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #76   Spotlight this post!
Unread 22-02-2008, 10:45
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Re: Archiving Recorded Regionals 2008
Has anyone tried SnapStream yet? (I'm downloading it right now)? Any opinions?
  #77   Spotlight this post!
Unread 22-02-2008, 11:58
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I have and my honest opinion is that it is far easier to just record directly with windows movie maker. SnapStream is a good program, but for this application its just too much effort to set up, firing up windows movie maker is just alot easier.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
  #78   Spotlight this post!
Unread 22-02-2008, 12:01
Jno
Originally Posted by Vikesrock View Post
I think we definitely should try and pick one video format for all the videos.
As I stated above outputting to .mp4, or .mov (h.264) is really easy with all these free ipod video converters. This is what I recommended above:
Format: .mov or .mp4 (.h264 or MPG4)
Resoultion: 640X480 VGA
Video Bit Rate: 1024kbps
Audio Bit Rate: 128kbps Stereo
  #79   Spotlight this post!
Unread 22-02-2008, 12:32
aksimhal's Avatar
AKA: Anish
But doesn't Windows Movie Maker only output to .wmv?
  #80   Spotlight this post!
Unread 22-02-2008, 13:04
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
And my experience is batch converting out of WMV is very slow.
  #81   Spotlight this post!
Unread 22-02-2008, 13:40
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Two capture programs that ought to be significantly easier to capture with than Windows Media Encoder or Windows Movie Maker are WinDV and VirtualVCR.
WinDV literally records straight from a DV camcorder (90% of these will take video input by buying a composite jack coupler and plugging a feed into the traditional video output port.) Then, spacebar will start and stop recording, automatically splitting the file each time, making it very easy to parse matches. (As long as you don't have it set to capture every 150th frame, like 177 did for Jersey 2007 (Though this is nice for timelapsing)). DV files are not tiny, but capturing only a few hours should not be too large.
VirtualVCR serves a similar function, except it is compatible with any capture device that has a WDM driver, not just DV cameras (that means ~everything). I honestly have not used it much and am unfamiliar with the way it operates, but it could be a great alternative if you cannot capture using DV.
Team 177 - Bobcat Robotics
  #82   Spotlight this post!
Unread 22-02-2008, 13:54
aksimhal's Avatar
AKA: Anish
Interesting...
What would work best with the FIRST Regional setup?
  #83   Spotlight this post!
Unread 22-02-2008, 15:18
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I don't know what I'll be using yet. It's up in the air. Guess I can try to build some inexpensive rig to do a capture on. We do plan on also making our own recordings available.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #84   Spotlight this post!
Unread 23-02-2008, 13:33
I put together this graphic explaining how The Blue Alliance plans to record the Boston Regional. Hopefully others can find it of use.
  #85   Spotlight this post!
Unread 23-02-2008, 14:36
Jno
for capturing on the cheep I recommend this USB Capture device. It worked well for me last year and it runs off usb. for capturing to DV I would be be worried about hard drive space for most people, I recorded in wmv last year at about 2 mb/s and got about 15GB of footage for a regional. If you got a big external HD go ahead and record in DV.
  #86   Spotlight this post!
Unread 23-02-2008, 20:36
aksimhal's Avatar
AKA: Anish
At the regional, the feed will be provided with composite type cable or something else?
Thanks
  #87   Spotlight this post!
Unread 23-02-2008, 22:21
Thanks
It is generally a composite feed through RCA cables. You likely will need your own RCA cables.
  #88   Spotlight this post!
Unread 23-02-2008, 22:23
Jno
Thanks
yep you get yellow red and white outputs (otherwise known as composite), I believe there is also a s-video output but I'm not 100% sure. Sometimes they put the box in a weird location around the arena, feel free to ask one of the volunteers where it is if you can't find it.
  #89   Spotlight this post!
Unread 23-02-2008, 23:31
aksimhal's Avatar
AKA: Anish
Ok, thanks. Is the usb capture device you recommended reliable? (Also, is ther any thing cheaper.)
Thanks for everything. You guys help a lot.
  #90   Spotlight this post!
Unread 23-02-2008, 23:45
Jno
I recorded 3 regionals with it, hasn't crapped out on me yet. It certainly isn't the top of the line, but its a safer bet compared to some of the ones that are $5-10 cheeper. Be aware of some of the no-name brand ones on sites like tigerdirect and newegg, I wouldn't use any of the software that comes with the capture device, but it works for getting the video into your computer. You should expect to pay at least $30...
[IMG] code is Off
Getting to the 2008 Honolulu Regionals doesn't require breaking the bank da Marshalls Regional Competitions 113 10-01-2008 13:14
New Regionals in 2008 Madison Regional Competitions 48 14-09-2007 22:53
SVR 2006 Recorded Webcast Joobacca Regional Competitions 3 24-03-2006 08:53
auto archiving of posts Joe Ross CD Forum Support 4 01-01-2004 02:04
automatic archiving Joe Ross CD Forum Support 5 04-08-2003 13:27
