Go to Post FIRST Championships event is not about winning, its about the experience, the atmosphere, the people and the sites, there are a lot of amazing things to see at The Championships. - Mike Schroeder [more]
Unread 22-02-2008, 22:05
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Too much traction
We have run into a little snag. Turing can be really hard for our bot due to the fact we are using 4 IFI Traction wheels with a 4X4 set up. We can turn, but we got to be also moving backwards or forwards. It has been really bugging me cause I'm one of the drivers of the bot. I would love to put Omni wheels on the front, but the bot is already shipped. I was wondering is anyone else had any suggestions. The fix has to be able to be done at regionals during our tuning time. Any suggestions would be very helpful.
Here is a pic of your chassis if this will help at all:
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 22-02-2008, 22:12
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Re: Too much traction
Sounds like you're having the same problem we had last year. Later you'll find the traction will be totally lost (after competition though so don't worry), anyway You could either drive with a lot of jerking forward and quick switching into a turn or you could probably modify the wheels with those omni-wheels or the smooth rubber tires that come in the kit (with the shifters and those rubber wheels strafing in high gears was A-M-A-M-A-Z-I-N-G!!!)
Hope this helps.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 22-02-2008, 22:14
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
put zip ties on either the front 2 wheels or the back 2 wheels
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 22-02-2008, 22:22
JoshD's Avatar
JoshD JoshD is offline
FRC #0975 (Synergy)
JoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to behold
Send a message via AIM to JoshD Send a message via MSN to JoshD
We ran into this problem. If your going to do omni wheels, put them in the front and DON'T power them, trust me. Or, we found this out by breaking a chain, if power two wheels on the right side and one on the left side, just power the right more and it turns real nice.
Unread 22-02-2008, 22:28
in between teams
AKA: Luke Van Oort
If adding omnis isn't possible, just reduce the distance between the drive wheels so the wheelbase is significantly wider than it is long. Some casters may be necessary to add to the robot for balance. Actually, if you had casters on the front and rear with drive wheels in the middle, you might (depending on drive wheel squishiness) be able to raise/lower the casters a few mm to reduce the normal force on your drive wheels. Another option might be switching to lower traction tread on a pair of wheels. McMaster-Carr has a wide variety of conveyor belt materials, I'm sure you can find a lower traction one that can be adapted to your wheels (like the PVC or Nitrile Incline conveyor belting). In my opinion, your best bet is to move the front wheel back to a couple of holes after where the idler currently is, and then move the other wheel a few more holes back to get a centered drive system with a width of 1.5*length. Casters at the ends would restore balance.
Team 1219: 2009 - Mentor
Unread 22-02-2008, 22:32
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
I believe you can still order omni wheels and bring them in to the competition, as they are COTS.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 22-02-2008, 22:36
That guy
AKA: Dennis
Thank you everyone, like i said any ideas will be helpful
Originally Posted by lukevanoort View Post
If adding omnis isn't possible, just reduce the distance between the drive wheels so the wheelbase is significantly wider than it is long. Some casters may be necessary to add to the robot for balance. Actually, if you had casters on the front and rear with drive wheels in the middle, you might (depending on drive wheel squishiness) be able to raise/lower the casters a few mm to reduce the normal force on your drive wheels. Another option might be switching to lower traction tread on a pair of wheels. McMaster-Carr has a wide variety of conveyor belt materials, I'm sure you can find a lower traction one that can be adapted to your wheels (like the PVC or Nitrile Incline conveyor belting). In my opinion, your best bet is to move the front wheel back to a couple of holes after where the ideler currently is, and then move the other wheel a few more holes back to get a centered drive system with a width of 1.5*length. Casters at the ends would restore balance.
We already do have ball casters on the back. I think we moved the back wheels further back so maybe if we move it forward again it will help out.
I hope so, my mentors arn't too concerned, so I'm wondering if they have a fix. I'm just trying to gather some fixes so if they dont have any we arn't trying to fix it off the top of our heads.
Unread 22-02-2008, 22:38
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Adding Omni Wheels will definitely help with your maneuverability. This years game is not so much about pushing and shoving as it is about being able to move around easily.
If you can put omni wheels on I would suggest you put them on the REAR not the front. The reason for this is to allow you to make turns very easily and quickly. This will allow you to literally turn on the pivot of one front wheel.
Think: Forklift units in your local home store. The front wheels are the drive wheels and the rear wheels allow it to maneuver easily around obstacles.
If omni wheels are not an option I would suggest you change out the rear wheels with the kit of parts wheels. These have less of a surface area in contact with the carpet along with a lower CoF and should allow you to makes turns easier.
Good Luck!
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 22-02-2008, 22:47
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Maybe try flipping the wedgetop/roughtop tread around such that the "back" side is facing "out" and the wedgetop/roughtop is against the metal rim on one end (front or back)?
Unread 22-02-2008, 22:50
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
I would say that omni's would your best bet. ideally, you could make it a 6 wheeled robot (they dont all have to be powered) with the center wheel slightly (about an 1/8" or so) lower that the other wheels. this will allow you to turn with relative ease. however, with weight and time being an issue this prolly wouldn't help, but just an idea.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 22-02-2008, 22:52
That guy
AKA: Dennis
We have the weight to spare, but this year we really wanna get in a lot of practice matches.
Unread 22-02-2008, 23:01
Too bad surface area doesn't affect traction
Are you going to a first week regional? If so, then I'm not sure about the rules on upgrade parts. I'm pretty sure omni wheels, in your case, would be considered upgrade parts. If you're going to a regional after the first week, then you are allowed to bring upgrade parts.
It's really lame how first week regionals can't bring in upgrade parts, but every other regional can. What's the reason for that?
Unread 22-02-2008, 23:04
That guy
AKA: Dennis
Thankfully FLR is week 2.
Unread 22-02-2008, 23:05
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You cannot fabricate upgrade parts during the first FIX-IT window. You may still bring unlimited COTS parts to any competition regardless of intended use. Omni wheels qualify as COTS parts and would be perfectly legal to bring.
Unread 22-02-2008, 23:07
That guy
AKA: Dennis
what does COTS stand for =P
Too much code MARS-CJ Programming 2 22-04-2006 17:34
Too much torque? Ctrl Alt Delete FIRST Tech Challenge 2 07-03-2006 01:55
Pneumatic Wheels -> Too Much Traction OldDan1168 Technical Discussion 2 24-02-2004 11:28
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
