Go to Post The first team that uses a lawyer to interpret the rules should be disqualified from all competitions, just on general principles. - dlavery [more]
Unread 22-02-2008, 23:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Too much traction
Originally Posted by FRC Manual
COTS – A “Commercial, Off-The-Shelf” COMPONENT or MECHANISM, in it’s unaltered, unmodified
state. A COTS item must be a standard (i.e. not custom order) part commonly available from the
VENDOR, available from a non-team source, and available to all teams for purchase.
There ya go!
Unread 22-02-2008, 23:10
pufame's Avatar
pufame pufame is offline
FRC #0291 (CIA)
Team Role: Webmaster
pufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud of
I can't tell how you have the wheels aligned on the shaft from the picture but...
http://andymark.biz/am-0104.html
The AndyMark Coolie Dualie Wheels have the same diameter center hole and hole pattern as the IFI Tractions (if I remember correctly) and would probably be the easiest to switch to at a regional (if you do decide you want to switch the wheels out).
Unread 22-02-2008, 23:11
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
[quote=InfernoX14;705454]Too bad surface area doesn't affect traction
[quote]
No offense meant here but if surface area doesn't affect traction then:
Why do drag racers use really wide tires?
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 22-02-2008, 23:17
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Originally Posted by Vikesrock View Post
You cannot fabricate upgrade parts during the first FIX-IT window. You may still bring unlimited COTS parts to any competition regardless of intended use. Omni wheels qualify as COTS parts and would be perfectly legal to bring.
Alright, cause I looked in the rule book, and it's not very clear about the first week regionals.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 22-02-2008, 23:18
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
[quote=Brian C;705462][quote=InfernoX14;705454]Too bad surface area doesn't affect traction
I knwo ti's off topic, but I love racing and I have to back him up that (at least with drag cars) more surface area on the ground = more traction and speed
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 23-02-2008, 00:04
CraigHickman
Posts: n/a
Before this gets off topic: The discussion of surface area in relation to traction has taken place in many threads. Please search on it, as many rather brilliant people have posted their input on the issue, and it would be a burden to have them repost it here.
As for the turning issue, take a dremel to the roughtop tread and remove strips of tread to reduce the traction of the wheel. Should take about 5 minutes total.
Unread 23-02-2008, 00:12
That guy
AKA: Dennis
Thank you very much everyone, I was just talkign to a mentor and we now have a few things we will try:
1) Move the center wheels to change the wheelbase
2) Use a 1” wide wheel for 2 of the wheels which will reduce the friction (less wheel tread on the carpet)
3) Raise or lower the casters.
4) Install larger casters
5) Replace a wheel set for a pair of omni wheels
6) Change the wheel tread to lower friction type
7) Change the gear ratio of the drive
8) Install larger wheels on the left side of the robot (old dirt track stock car trick)
Number 8 is my personal fav cause it keeps in the spirit of the bases of this years game
Unread 23-02-2008, 09:57
demps45 demps45 is offline
Freddie the Teddy
FRC #0378 (Delphi Circuit Stompers)
demps45 is an unknown quantity at this point
There are many different ways to help your turning problem, including adding the omni's, changing your wheelbase a bit, or just reducing the traction on two of your wheels. We (Team 378) will be at the Finger Lakes Regional and would be glad to add our help if you want/need it.
Unread 23-02-2008, 10:12
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Are you using cims to drive your robot? If so how many?
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 23-02-2008, 11:21
That guy
AKA: Dennis
Thank you, If we can't fix this problem with the things our mentors have in mind i will take you up on that offer.
4 CIM motors 2 in each TB gearbox
Unread 23-02-2008, 11:35
nuggetsyl's Avatar
FRC #0025
how many feet per sec is your robot going??? aka what is it geared to.
11 VCU winner
12 MAR Mt Olive
red is for team 348
Unread 23-02-2008, 11:46
That guy
AKA: Dennis
idk the gears but i do know it goes from 12 to 13fps and we could ramp it up to go faster then that
Unread 23-02-2008, 18:09
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Be careful. You can quickly go from too much traction to too little.
Instead of grinding off the roughtop, add wide zip ties sideways around the wheels through the holes in the rims.
If that's not enough - add omni's in the front. We made the mistake of adding omnis in the rear. It was a nightmare to control. When we hit the gas, the weight transfer to the back wheels would reduce the friction on the front ones, and it made hard acceleration a bear to control.
Unread 24-02-2008, 12:50
Jaybee1405
Posts: n/a
Last year we had 6 IFI traction wheels, all powered. With 42 teeth sprockets on the wheels and a 25? tooth output sprocket, we outpushed everyone. But, like you, we couldn't turn. So we flipped the front traction strips over and re-riveted them so the wedgetop was facing the aluminum wheel itself. It worked like a charm. We still outpushed everyone and, more importantly, we were able to turn.
Unread 24-02-2008, 12:53
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Yu could also check FIRST if you need anything to be approved by the rules. [off_topic]
Also I can't seem to get to FIRST are "remodeling" their site?
[/off_topic]
The system is down.
Rockford Robotics 2039: Think outside the bots.
Too much code MARS-CJ Programming 2 22-04-2006 17:34
Too much torque? Ctrl Alt Delete FIRST Tech Challenge 2 07-03-2006 01:55
Pneumatic Wheels -> Too Much Traction OldDan1168 Technical Discussion 2 24-02-2004 11:28
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
