Go to Post And THAT is why they have safety manuals. - Eria4044 [more]
Unread 17-02-2008, 23:25
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: IR Board Problem
Originally Posted by DarkJedi613 View Post
I have a pretty detailed post here about that.
Man... beat again at a good idea!
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 18-02-2008, 10:34
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Thanks! Ours went down last night and I cannot find a pic programer. I will give this a try.
Unread 18-02-2008, 21:40
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Originally Posted by iambujo View Post
We had success with it today as well. I used winpic to program the chip with a custom serial cable I made late last night based upon a whole lot of googling and research. I too erased before programming to get it to work. For teams in need of doing this that don't have fancy PIC programming hardware or time to order some, attached is the harness schematic I made. I used a PC serial port (and not a laptop) because most of what I read said that the laptop voltage levels are not high enough on the serial port to program it.
So I did this, I was able to initialize (once I used a desktop, not a laptop) and I was able to erase the program currently on there. But when I go to load the FIRSTIR.hex, it gives me an error saying there is a problem with the file. If I ignore that fact and try to load it onto the PIC then it goes through and fails during verification. Any ideas? I'm using the FIRSTIR.hex posted here. Is it possible something is wrong with that file? Or am I doing something wrong? Thanks.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 19-02-2008, 07:10
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Humm, sorry to hear that. Did you unzip the hex file?
I didn't have any problems and I used the same file you mentioned. Can you read from the device without error? I wonder if your PC serial port voltage is too low, I saw mention that that could cause problems when I was researching. I guess since it worked for me, I don't have much insight into figuring out what can go wrong.
Unread 19-02-2008, 10:27
Running Riot
AKA: Patrick Cloke
Yes I unzipped the hex file. I can read from the device without error (although now its empty!). I don't think the serial port voltage is too low, it erased the device fine. As soon as I open the hex file (before loading it into the device) I get the following error:
LoadHex: Ignored 316 locations at addr 0x000400...0x002008 .
Also though, do I need to manually select the device (PIC1687)? Is anything to be changed in Device config? When I select the device that it says:
Couldn't find "devices\PIC16F87.dev", please borrow/copy from MPLAB !
FIRSTsearch
Unread 19-02-2008, 16:14
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
what programmer are you using? (ICD2?)
what software do you use with it?
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 19-02-2008, 16:44
FRC #2729 (Storm)
Check out the screen shot in my powerpoint slides. Under the interface tab I selected "JDM (2) for serial port" under Interface Type, and then I loaded the ElCheapo_PCB.ini for the definition file. This was via trial and error before I got "success". Maybe that will help if you didn't do that.
Unread 19-02-2008, 16:53
Running Riot
AKA: Patrick Cloke
I'm using iambujo's method of a serial dongle connected to the board.
Yes, I saw that and set both of them. Maybe I'll try again on a different computer. Thanks for your help. Its strange because I can connect, erase, read, verify, etc. I just cannot write the hex file. Perhaps it is the voltage levels.
FIRSTsearch
Unread 19-02-2008, 19:21
The IR PIC hex file has also been posted by FIRST on their Additional Technical resources page
http://www2.usfirst.org/2008comp/Manual/FIRSTIR.HEX
Unread 19-02-2008, 19:30
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
To anyone with IR board problems that's coming to the oregon regional, team 2273 (shameless plug) will graciously give you a hand in getting it to work. It'd be a shame for any teams to not get their robot to do at least SOMETHING in hybrid. We have a PicKit2 and the know-how to get your boards up and running.
Unread 19-02-2008, 21:42
Running Riot
AKA: Patrick Cloke
Thanks. The files are identical. So that's not the problem.
I'll keep fiddling with it and post if I have any success...
FIRSTsearch
Unread 23-02-2008, 03:49
tpage22's Avatar
tpage22 tpage22 is offline
AKA: Taylor Page
FRC #1503 (GM Spartonics)
tpage22 is an unknown quantity at this point
i have the same problem as DarkJedi613
No luck so far.
Unread 23-02-2008, 18:16
Running Riot
AKA: Patrick Cloke
I got it to work!
The things I changed (note I don't know if all these are necessary):
Devices Tab:
Choose PIC16F87
Options Tab:
Provided the MPLAB devices directory (you really only need one file - "PIC16F87.dev" and it was asking for a 16F716 algorithm, but also providing PIC16F716 didnt help).
Interface:
Interface type: JDM (2) for serial port
Custom interface definition file: ElCheapo_PCB.ini
And that was it! Note: it gave me LOTS of errors, but the device works now (through test it with a remote) so I'm not sure whats up with that. I just tried it again on my laptop (through a USB to serial adaptor -- I changed the Option "I/O Port Access Driver" to "no direct access at all, only use win API"). This DID NOT work however -- I could not even erase the board. It is possible a true serial port would work however. Good luck!
FIRSTsearch
Programing IR board problem Shivang1923 Programming 5 16-02-2008 22:55
IR board problem AmitCarmeli Electrical 3 09-02-2008 18:53
Another IR Board Problem C222 Electrical 2 13-01-2008 17:36
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
