Go to Post Have you ever found yourself staring at a physics problem, not understanding it, then connected it to a past FRC game and suddenly felt the light bulb start shining? - StephLee [more]
Unread 19-02-2008, 06:50
martin417's Avatar
martin417 martin417 is online now
Opinionated old goat
AKA: Martin Wilson
How many teams suck?
Just curious, since there were only two suckers at the local scrimmage this weekend, how many teams are using some sort of vacuum apparatus to acquire and/or hold the ball? and if you do, how do you hurdle? (shoot or lift over) ours grabs with a vacuum funnel, and shoots the ball over with pneumatics:
http://www.youtube.com/watch?v=QeQSGmFnKAE
While the other sucker team at the scrimmage (awesome rookie bot from 2415 Westminster WiredCats Robotics) was a lifter:
http://www.chiefdelphi.com/forums/sh...highlight=suck
Unread 19-02-2008, 10:57
Team56 Team56 is offline
FRC #0056
Team56 is infamous around these partsTeam56 is infamous around these parts
Re: How many teams suck?
I love the design, Very special and unique =)
www.team56.com
Unread 19-02-2008, 12:16
czeke czeke is offline
Tool and Die maker/Tool Designer
AKA: Carl Zechel
FRC #1091 (Oriole Assault)
czeke has a spectacular aura aboutczeke has a spectacular aura about
Ours is a lifter, which we hope will get the trackball close and slightly above the trellis, release the vacuum and have the trackball sort of tumble over it. But we hope to be able to pick it up near the end of the match and simply place it on the trellis. The vacuum is both strong and allows us to have very good control of the trackball.
Unread 19-02-2008, 13:23
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
rookie team 2415 also sucks.
1771, really like your sleekness. Its a good looking bot!
Unread 19-02-2008, 13:44
Ian G Ian G is offline
BUILD SUCCEEDED
FRC #2415 (WiredCats)
Ian G is an unknown quantity at this point
Send a message via AIM to Ian G
The vacuum/shooter design is brilliant. It was awesome watching it go at the scrimmage, good luck at regionals!
Unread 23-02-2008, 08:29
martin417's Avatar
AKA: Martin Wilson
Just a bump to get this question back out there. There must be more than three vacuum gripper bots! Lets from all you suckers!
Former Mentor Team 1771
Former mentor Team 4509
Unread 23-02-2008, 11:37
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
326 also has some what of a vacuum style robot... to see it ya'll just going to have to wait until pittsburg to see it...
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 23-02-2008, 13:14
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
After we sucked figuratively much less than literally last year, never again... have you tested your "sucker" with the ball being bumped, or in a less-than-optimal orientation to the robot? Those were our big problems last year...
Unread 23-02-2008, 15:40
martin417's Avatar
AKA: Martin Wilson
Last year the game piece was a torus, sub-optimal for sucking, this year it is a sphere, there is no "less-than-optimal orientation"
Unread 23-02-2008, 16:00
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Except for the porous fabric, seams, and zipper.
Unread 23-02-2008, 16:09
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
team 1323 tried it with the inner tubes and it didn't work out to well for us, but the vacuum designs i see this year rock,
good luck
R.C.
MadTown Robotics Team 1323
Unread 23-02-2008, 17:03
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
We have tested the strength extensively. Basically there is no way to knock the ball off with any hit we could inflict to the ball. We tried kicking it slamming it into the ground hitting it repeatedly (I'm pretty strong) and every other way imaginable and the ball won't come off. We hold the ball with 360 lbs of suction so needless to say we're not worried about losing the ball. I would go so far to say that are gripper is probably one of the most secure ones. Additionally we can acquire the ball just by touching it, ,we don't have to press on to it for an extended amount of time.
Mentor 2415
Unread 23-02-2008, 17:04
FRC #0840 (ART)
Well, say the ball is at a distance such that the sucker can't come in straight on... what happens then?
Unread 23-02-2008, 17:15
GaryVoshol's Avatar
Cogito ergo arbitro
How is that any different than if another robot's forklift isn't lined up straight-on? Either robot will have to move to adjust.
(since 2004)
Unread 23-02-2008, 17:21
AKA: Sean
Exactly. Also to take care of the vertical orientation we are using both a potentiometer and reed switches to tell us exactly the right height to pick up the ball.
Mentor 2415
How many teams in 2005? Andrew General Forum 103 10-03-2005 19:13
How many SD teams in 05? JP_1163 FIRST-related Organizations 0 01-10-2004 11:50
How many teams.... archiver 2001 0 24-06-2002 04:03
How many teams? archiver 2000 9 24-06-2002 00:37
How many teams.. archiver 1999 8 23-06-2002 22:53
