Go to Post Holy Orbit ball Batman!!!!!!!!!!:yikes: - yodameister [more]
Unread 23-02-2008, 12:58
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Using Kevin's PWM outputs for a quieter drive system.
That's usefull information, since with servos, the actual output drive IS directly related to the RC's PWM frequency (many servos use the PWM leading edge to initiate the drive signal)
So that begs the question....: What is the PWM Output frequency of a Victor? and: Why does my transmission sound so cruncy at low power.
The noise starts well before the GBox's output shaft starts moving, so I assume it's an oscillation detectable at the motot's output shaft.
Phil.
Phil Malone
http://www.GEARSinc.org
Problem with PWM outputs on RC Adam Richards Control System 1 20-02-2007 06:37
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
What drive system is your team using? dpick1055 Technical Discussion 22 27-01-2007 23:29
Using 6 motors in a drive system? FIRST JerseyKid Motors 7 12-01-2005 23:49
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
