Go to Post Who knew there were this many FRC teams that are teams! Very impressive, I might add. - [more]
Unread 23-02-2008, 00:47
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
Operator/Bit Issue
Hi,
We are having a really unique problem that has stumped the whole programing team, all of the mentors, and the team leader. We are trying to write some code in MPLab to calculate the number of encoder ticks needed to reach six feet. We have found that fourteen encoder clicks is the same as one inch. The problem comes in when we try to multiply 72(six feet in inches) by 14(clicks in an inch). When this happens we get -16 which is 32 bits off. We are using the variable type long. Below is the code that we have written:
long atemp=0;
atemp=14*72;//should be 1008
printf("atemp=%ld\r\n", atemp);
This code did not work and gave us a value of -16 for atemp. We also tried this:
long atemp=0;
atemp=72+72+72+72+72+72+72+72+72+72+72+72+72+72;
This also did not work and gave us a value of -16. Adding smaller numbers works fine and multiplying smaller numbers also works. We have pretty much exhausted any ideas.
Thanks,
Julian
Unread 23-02-2008, 00:51
Re: Operator/Bit Issue
C18 diverges from the ISO standard in that when all operands will fit in a char, it will do the math in a char. If you cast one operand to an int, it will do the math the way you want. You can also enable integer promotion in the project file.
Unread 23-02-2008, 01:09
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Or write
atemp=14L*72L;
which will make sure the numbers are treated as longs.
Also, i'm not sure if you can print longs...
Unread 23-02-2008, 01:13
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
I believe that both casting them to an int or using %ld should work.
Unread 23-02-2008, 01:25
int wont print the whole long though (only the low 8 bits), and i can't remember whether %ld actually works.
Unread 23-02-2008, 01:55
Racer26 Racer26 is offline
I think %ld does work in later revisions of the default code (kevins?)
Also, an alternative method of getting the math the way you want it:
 atemp = (long)14*(long)72;
Yay for C-style casting... in my opinion, SO much easier than C++ casts.
Unread 23-02-2008, 02:36
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
You code is working. The problem is with the printf statement.
so you can keep your code.
-Borna Emami
Team 0x27
Unread 23-02-2008, 14:30
FRC #0852
Thanks to everyone for the help. Typecasting made the code work. The printf statement was fine.
Julian
pic: A "Bit" of a problem. Herodotus Extra Discussion 26 11-10-2007 01:53
A bit of humor... 114Klutz Chit-Chat 0 01-04-2006 17:34
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
A bit unfair... Martin General Forum 61 26-02-2002 07:48
i am a bit miffed Zeinin 3D Animation and Competition 3 18-01-2002 13:39
