Go to Post Starting projects is fun, easy, and exposes you to new things, but finishing them shows true character. - Greg McKaskle [more]
Unread 23-02-2008, 20:12
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Transferring code over to mplab from easyC
During our 10 hr window today i transferred my easyC program into mplab. It was long and tedious, and I'm still working on taking care of " Set PWM". Other than that, everything else has just involved converting everything through notepad to a .c or .h file and then cutting and pasting in the appropiate file of the default code. ( I replaced default_routine with operator control.) I did this because I am tired of dragging blocks, and I think I can handle MPlab. Out of curiosity, does anyone know an easier way to do this?
Unread 24-02-2008, 11:09
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
Re: Transferring code over to mplab from easyC
Also if anyone needs help doing it this way, I am willing to help. Just pm me. If I can ,I'll help you with just about anything.
Unread 24-02-2008, 18:56
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
If you check the help file there is a C editor built into easyC.
Unread 24-02-2008, 19:06
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I have been unable to locate it unless your speaking of the conversion into raw code. Also I generally wanted the code to be more universally understood in case I need help during competition.
Unread 25-02-2008, 08:46
Kingofl337's Avatar
AKA: Adam
Just click on the Projects tab. You can convert functions you created to "C" code and you can create .C and .H files and edit them as well.
How to get EasyC code into MPLab rhoads2234 Programming 6 08-06-2007 14:45
Converting EasyC Tracking Code into MpLAB Ultima Programming 5 08-02-2007 21:38
Transferring EasyC for Competition Day Kingofl337 Programming 0 06-03-2006 11:38
Transferring EasyC for Competition Day Kingofl337 Programming 0 06-03-2006 11:32
