Go to Post It doesn't seem hard, but it is. You can do it with enough time, dedication, and skill, but that doesn't stop it from being hard. - lemiant [more]
Unread 23-02-2008, 20:43
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: Weight for the BOM
Dave.... you are correct.... however there are usually other items that weigh more and if removed will not weaken the structure.
Consider.......
Using Alum washers in place of steel
Using Alum clamp collars or even elim. the collar and replacing with a roll pin
Best of all.... using alum rivit in place of steel fasteners
I also like letting the air out of the IFI Traction wheels.....
Other weight saving ideas??????
Mike Martus
Creating a BOM in Solidworks on a different sheet than the drawing views Madison SolidWorks 1 09-01-2008 20:29
need ideas for light weight materials team 1094 Control System 13 04-05-2007 09:34
What is your estimate for typical electronics weight? groves Electrical 5 24-01-2007 23:20
How much weight for Electronics? Cuog Electrical 5 12-01-2007 12:05
The BOM, people, the BOM! rolocroz Rumor Mill 2 06-01-2004 20:28
