Go to Post Try to remember, FIRST is like life, it is about the journey not the destination. - rees2001 [more]
Unread 24-02-2008, 00:20
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
pic: Team 166's Desperate Weight Saving Measures - 2
Unread 24-02-2008, 00:23
FIRSTMa2104's Avatar
FIRSTMa2104 FIRSTMa2104 is offline
FRC #2104 (Colonel Robotics)
FIRSTMa2104 is on a distinguished road
Re: pic: Team 166's Desperate Weight Saving Measures - 2
I am scared
Team 2104 had to loose weight last year and we changed our drive train "slightly"
...it never work as it should, actually we weren't able to drive, so just be careful hope you tested it.
Unread 24-02-2008, 00:33
Oh yes, we wouldn't have gone through the trouble of putting these plastic tubes on without testing it.
The tubes are just there so the remaining rubber rollers don't slide around on the brass tube, which was what was happening when we first drove these wheels.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-02-2008, 00:39
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
What about cutting off the super long srews.
Unread 24-02-2008, 17:20
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
could you find aluminum screws and aluminum nuts to replace the ones that are on there, im sure mcmaster would carry such items.
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 24-02-2008, 18:01
I wouldn't trust aluminum hardware in this application.
148 (120 lb robot + 15 lb bumpers + 13 lb battery) pound robot driving around on these wheels? It doesn't sound too good.
Unread 24-02-2008, 19:34
FRC #0612
Team Role: Mascot
I am just making a suggestion. Aluminum hardware is something that has worked for 612 in the past, last year our wheels were made of plastic and the drive system was assembled using only aluminum hardware, and they never failed once. I do agree admit that using steel provides more strength and that we were not using a Mecanum drive system so maybe making the comparison is unfair. But for next year maybe this team can test out aluminum nuts and bolts and see if they hold up.
Unread 24-02-2008, 20:47
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Congratulations, I am not sure we could have taken that risk.
Unread 24-02-2008, 21:51
rjmah rjmah is offline
rjmah will become famous soon enough
Great idea. We could have used this idea last year except we had to shed the 1.8 lbs. at our first regional.
Robert Mah
Team 1246 Agincourt Lancers
Unread 14-03-2008, 17:14
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
My team was wondering how well did that end up working for you? Was it worth it? Have any issues and if so what were they?
pic: 166's '08 Robot: Atlas Dan Petrovic Robot Showcase 4 24-02-2008 14:59
pic: Team 166's Desperate Weight Saving Measures - 1 Dan Petrovic Extra Discussion 5 24-02-2008 12:29
pic: Team 166's Gemini as of 2/12 Dan Petrovic Robot Showcase 2 14-02-2007 00:32
Team 166's robot Eric Finn Robot Showcase 20 28-01-2007 23:06
pic: Saving weight (and rotational mass) M4 Sherman Extra Discussion 11 09-08-2006 00:20
