Re: Mechanical Or Electrical???
Mechanical!
I really don't know for you though. What are your like's/dislikes? |
Virtually every school that offers engineering--at all--has both ME and EE. Most of the engineering schools offer a course that can help you choose which you like. Many make that course required--here at SDSM&T, 9 of the 12 engineering programs/departments require the course.
Where are you going to college, just to know? Or is that dependent on this? (If the latter, go in undeclared and choose after taking courses in both or a decision course. I'm doing that right now.) |
It seems like mechanicals pick up on basic electrical knowledge as they go. Mechanical is a pretty broad field as it is and you cover many types of engineering. Electrical isn't as broad. You may want to look want ads for the type of career you would be doing when you graduate. Sometimes an electrical position will list either a degree in EE or ME. Also, if you decide on a degree and then want to switch, it might be easier to switch from ME to EE as intro to mechanical classes typically cover designing and physics. Your best option would be to talk to someone at the school you are considering. They can probably help match you with students of each major and go over the differences between both majors.
I have several degrees, an AS in EE, a BS in ME and an MS in ME. I originally planned to be an electrical engineer (hence the AS in EE) After I got to the 4 year program and started taking courses, I seemed to like the ME courses better (in early engineering you have have to take both) it may have been the personality of the professors (the EE people tended to be abrasive). At any rate, I got my undergrad degree in ME and have enjoyed working as an ME for many years. I would probably do the same if I had to start over.
My 2 cents. |
Keep your options open for now. Don't go into a program that forces you to pigeon hole yourself into a specific slot right away. My alma mater (Olin) won't let students declare a major until their sophomore year, and I strongly agree with that philosophy.
I strongly disagree with hallk, though I may be biased as an ECE myself. The amount of "cross pollination" you receive is not a function of your major, but rather a function of your own interests/drive and the quality of the program you are enrolled in. You might want to consider Systems Engineering, as it sorta kinda not really straddles the two. |
And don't limit yourself, either. There are a lot of other engineering majors out there, like Civil, Mining, Materials, Chemical...the list goes on. |
#7
Honestly i do you not exactly what to do because i have never actually done anything that is directly involved with mechanical, but i have not done anything major in electrical either. My college is something i hope to decide based on my major, so i can go towards what is best for my major.
Thanks for your inputs and i will keep them in mind when it comes time to decide. ![]() |
#8
There is a 3rd option. Mechatronics engineering, which is a combination of both. I was faced with your same delimna. I was torn between electrical and mechanical. My first year i declared myself as a mechanical, but started to miss the electrical side of things. When i found out my school was offering a Mechatronics degree, i jumped on it and so far have been happy. Its a personal decision and you should go with what you feel. Look at the kind of careers each offers when you graduate. Remember, alot of the basic classes overlap between EE and ME. You can easily take core classes for a while until you make up your mind.
#9
I'm almost to the point where I need to make this decision also. Can anyone go deeper into what an EE does and what you learn about?
#10
An EE degree, like an ME, doesn't lock you into much at all. It's a huge field and you could end up doing all sorts of things. I have a few EE friends. One is working on wind mills in New England developing weather logging equipment and another is working for a company that makes aircraft lighting products. Both use the same basic skills but have very different responsibilities.
I can tell you that your education will probably start with basic technical math and DC/AC circuits. From there you'll get into logic, microcontrolers, signals and programming. All the while you'll be taking more advanced math courses. By the time you graduate you'll have created a senior project that incorporates what you've learned, sometimes as a group. EE senior projects are often robotic in nature. If you really are unsure of which one, a lot of technical schools offer a bachelors degree program in electro-mechanical engineering, or something similar. It's basically 2 associates degree programs, one in EE and ME, welded together to form a bachelors. Holders of one of these degrees are likely to end up in a very hands on position, perhaps in a supervisory role over a small team. Emphasis is on skills, experience and flexibility, and less so on high level theory. They have excellent placement rates and young people with this kind of degree are aggressively recruited. If you want a technical job right away with the opportunity to move up, this is a good option. In any case, it's a good opportunity for you to get a side by side comparison of the two fields. |
#11
Both fields are so broad, it's hard to limit what an EE does or an ME does - either one can do just about anything. The good news for those folks on the fence is that there is a lot of overlap in the math and theory when dealing with things like energy, power, and system stability, so you can pick a program or make your own mix from EE and ME for the first two years and then decide. The college I attended my freshman year (Cooper Union) had no difference between ME and EE programs in the first year - calc, physics, chem, thermodynamics, english, programming, whatever.
Every college has "suggested" courses to take at suggested times, but they all assume a single major and a four year stay. You don't have to do that - this isn't high school, and there's no time limit. You can try one thing and if it's not a good fit, try something else. You can change concentrations, majors, schools, or advisors at any time. You can try to get a co-op position for a semester to get a better idea of what's available. If it takes a semester or two longer to earn your degree, that's absolutely not a problem. My advice is, first, second, and third: don't worry. It is a big decision, but it doesn't have to be made all at once, and certainly not all right now. Try one, explore it as much as you can, and don't be afraid to change your mind later. The worst thing that'll happen is that it'll take a little longer than you originally thought (and five years after graduation, you'll only be glad). One advantage is that you'll have a broader background than many of your peers. You should be free enough to tailor your course selection with your out-of-major electives to keep yourself interested. Relax. Steve P.S. I'm an EE, doing mostly circuit design since graduating in '85 |
#12
Just adding a little to what a lot off other smart people have said, don't get too settled or worried about not be settled yet. Get started in a good engineering school and look for opportunities to Coop. Coop programs let students "try out" different careers. It also lets employers try you out. Its one of those rare win-win situations. It looks great on a resume when its time to get the real job as well.
Good luck! |
| Mechanical/Electrical Off-Season Projects | CraigHickman | Technical Discussion | 49 | 19-08-2007 15:37 |
| Mechanical Vs Electrical | D.J. Fluck | General Forum | 28 | 30-04-2007 15:59 |
| Mechanical or Electrical | Nate Edwards | College & University Education | 4 | 10-08-2006 20:49 |
| Power issues...Electrical? Mechanical? | Rhubarb | Technical Discussion | 24 | 08-03-2006 17:20 |
| Mechanical | randomperson | FIRST-related Organizations | 5 | 03-06-2003 19:53 |
