Go to Post I don't mind being odd...I like to - listen - to Dean Kamen's speeches. They make sense. I don't get to listen to a lot of sense in the world, just a lot of noise. - JaneYoung [more]
Unread 23-02-2008, 23:38
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
pic: Team 166's Desperate Weight Saving Measures - 1
Unread 23-02-2008, 23:42
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: pic: Team 166's Desperate Weight Saving Measures - 1
you could also lose a tiny bit from trimming off the 3/8" of bolt sticking out past the nut. about an hour with a dremel and you could save a couple of ounces from each wheel.
Unread 24-02-2008, 00:26
Jaybee1405
Posts: n/a
or 5 minutes with a zip wheel
might mess up the threads but times are desperate
Unread 24-02-2008, 00:34
That's the next step
These are the wheels on our practice robot and we don't really have to take the time cutting down those bolts. We just did this to the practice robot to make sure the wheels would still work properly.
We probably already cut down those bolts on our competition robot. I can't remember.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-02-2008, 11:42
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
what kind of bolts are those? I believe switching to aluminum bolts would save some weight.
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 24-02-2008, 12:29
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
It looks like the bolts are stainless steel. I personally wouldn't use anything but stainless steel or steel on anything in the drive train just because of the beating their likely to take a beating. We had some aluminum bolts sitting around our shop a while back and I wouldn't even use them on a vex robot.
-Dustin Benedict
pic: 166's '08 Robot: Atlas Dan Petrovic Robot Showcase 4 24-02-2008 14:59
pic: Team 166's Gemini as of 2/12 Dan Petrovic Robot Showcase 2 14-02-2007 00:32
Team 166's robot Eric Finn Robot Showcase 20 28-01-2007 23:06
pic: 166's build season schedule Dan Petrovic Extra Discussion 12 13-01-2007 00:19
pic: Saving weight (and rotational mass) M4 Sherman Extra Discussion 11 09-08-2006 00:20
