Go to Post I just like that PVC is the most basic need of humankind according to that diagram. Whatever would we do without it?! - Po-ser [more]
View Poll Results: What drivetrain did you choose?
Skid Steer 46 40.00%
Mecanum 12 10.43%
Swerve 7 6.09%
Ackerman 10 8.70%
Tank Treads 7 6.09%
Other 33 28.70%
Voters: 115. You may not vote on this poll
Unread 24-02-2008, 17:19
in between teams
AKA: Luke Van Oort
Re: What drivetrain did you do?
Like 1618, we are using a kitbot-derived 6WD with AM Shifters (Gen 2 Servos, in our case) geared to 13.3 and 5.3 ft/s. Unlike most kitbot-based 6WDs, ours has an adjustable centre wheel. We tried it coplanar, lowered 1/16", and lowered 1/8"; we found that we much preferred 1/8" to the other ones. Coplanar could not turn at all in high gear (but was awesome to drive in low gear - I can see why 25 likes it), 1/16" was faster turning in low gear and could drive in arcs in high gear (ie. you had to move forward to turn), and 1/8" can turn in place in high gear, albeit a bit slowly. We are only running 1 chiaphua per side though; if we had two per side, I'd probably go with 1/16" or 3/32" lowered.
Team 1219: 2009 - Mentor
Unread 24-02-2008, 17:36
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
we are using tanksteer with the 2 back powered by two motors each. We did not even bother with DeWalts this year. We did not believe that we would be able to get much speed in this game do to traffic.
Unread 24-02-2008, 17:38
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
6 wheels. Center wheel is dropped down 1/4inch. Turns on a dime and can make nice U-turns.
"6-wheel rocker"
Mitty Robotics Alumni
TKO 1351
Unread 24-02-2008, 17:44
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
AM supershifter /w servo 2 CIMS per side.
Belt driven four wheel drive /w 6 inch x 1 inch IFI traction tires wedgetop tread.
Belt reduction 3:4 after the transmission
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 24-02-2008, 17:46
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
8WD live axle with AM SuperShifters and two CIMs. We're using 2008 AM FIRST kit-of-parts wheels and a 2-1/2" x 1-1/4" x 1/8" wall tubular aluminum welded chassis, with tensioners based on the prototype that Jabba-the-Hutt made for us in the off-season.
Richard Wallace
since 2003
Unread 24-02-2008, 18:01
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
6wd with center wheels direct driven by kit box Toughbox - 2 CIM's per side, front and rear corners are Omni's - no center wheel drop. 4 custom designed spring/sprocket tensioners. We've clocked it at 10f/s but the weight causes it to take a little while to hit that speed. I would have liked a lighter robot by 10-20 lbs but that wasn't going to happen.
Unread 24-02-2008, 18:10
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
We went with an omni drive. 4 wheels on the 45 degree angles just like our vex robot from the Milwaukee vex league. It works really good, really fast and good maneuverability. The programmers did a great job getting it to drive strait.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 24-02-2008, 18:19
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We were seriously considering an Ackermann set up, but then our programers figured out how to make a 6wd robot drive like one, so we just built a 6wd bot.
We had fun designing it, too. We aimed for super simplicity: the frame is made of four lengths of c-channel, and the wheels sit on protruding bolts. Very light and easy to fix.
Unread 24-02-2008, 18:48
Jaybee1405
Posts: n/a
RWD (2 IFI 6x2 traction wheels) powered by 4 CIM's through toughboxes; Front steering (non-Ackermann, non-powered, kit wheels).
Unread 24-02-2008, 18:53
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
4WD, skid steer, run by 4 Cims through Dewalt transmissions.
___________________
- Tennyson, Ulysses
Unread 24-02-2008, 21:47
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Soap-Box style steering X 2.
Two pivoting axles, linked with a cross-bar to provide high-speed staight-away and turning. Each axle has a pair of CIM motors, driving inline 3:1 Banebots Planetary gearboxes and custom made 4" diameter traction wheels.
Original tests showed that we could drive and steer JUST using differential speeds on the opposing wheels, but we ended up adding a dedicated steering motor with position feedback for Hybrid mode.
See video of the bot in action:
http://www.youtube.com/watch?v=JKdTJSR-KuU
Phil Malone
http://www.GEARSinc.org
Unread 24-02-2008, 22:08
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
we invented our own drive system! (you may of seen videos of it on other threads) It called "the Linkage" and it is 4 omnis set up like 4wd, that switch 90 degrees so they are also 4wd in a sideways orientation, giving us 4 motors of power in all 4 directions without the mechanical no how of a swerve drive!
Unread 24-02-2008, 23:21
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
We did a true Ackermann type steering, with a ATV differential in the back, powered by 4 CIMS running through a modified AM 2 Speed Transmission.
Unread 24-02-2008, 23:31
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
6-WD. Omni's on the front, 2007 kit wheels in the middle and back. Two CIM's per side. Zero drop on center wheels. One speed at 10 fps. Stable & strong. Easy to turn, but doesn't spin out on fast corners.
Unread 25-02-2008, 04:18
JOhnch181 JOhnch181 is offline
FRC #1294
JOhnch181 is on a distinguished road
we are driving a 4wd using super shifter with performance wheels in the front and a kit wheel back right and an omni on the left. turns slowly in low but takes the corner perfectly in high gear.
What did you do to gain an Award? Alex Cormier Awards 21 17-03-2008 09:41
What drivetrain style are you using? Mike Nawrot General Forum 32 27-01-2008 16:32
What did you acquire at Championship 05? Dorienne Championship Event 22 02-05-2005 01:43
How long did it take for you to build your drivetrain? NoodleKnight Technical Discussion 18 29-12-2004 16:13
Drivetrain, what did you use? maclaren Technical Discussion 42 15-02-2004 21:09
