Go to Post My team heard another team describe the Championships as "10,000 kids jamming the Georgia Dome for 3 days…more nerds per square foot than a Star Trek convention…and more purposefully employed " Is this true?, Because I don't think there could possibly be a more wonderful place on earth - Emily3204 [more]
Unread 24-02-2008, 20:48
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
pic: Team 34 - Ackerman Steering
Unread 24-02-2008, 20:49
Jaybee1405
Posts: n/a
Re: pic: Team 34 - Ackerman Steering
That's sweeeeet. What are you using to power it? A globe?
Unread 24-02-2008, 21:00
Yep. A globe and a 4 to 1 worm drive gearbox.
Ed Sparks
MECH TECH FRC-3959
Unread 24-02-2008, 21:32
Jaybee1405
Posts: n/a
Same thing we used, + a pot (I'm assuming you used one too). Except we didn't use a worm drive gearbox.
Unread 24-02-2008, 22:02
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
And it was a 8:3 reduction out of the globe.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-02-2008, 22:06
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
Team 2468 is using a globe motor with Ackermann steering as well. We mounted a pot with a flexible shaft for feedback. Our steering mounts are racing go kart spindles with the KOP wheels with IFI tread mounted on them.
Give it a look at:
www.chaprobotics.blogspot.com
We can turn in a little over 5 foot turning radius.
Unread 24-02-2008, 22:08
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
I'm very curious as to how this feels/performs from a driving standpoint vs. normal tank-style drive... anyone with experience?
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 24-02-2008, 22:09
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Not yet, but I'm about to find out since there isn't enough force on the back wheels to turn the bot in place. Maybe I'll keep you updated.
Kevin Li
596 - Sciclones
Unread 25-02-2008, 10:48
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Another nifty design from Team 34. I like the steering concept. Should make you fast around the corners. Good luck at Peachtree and Bayou.
Unread 25-02-2008, 11:12
Umm Errr...
How do the controls work? Wheel and pedal? Is the steering rack control position based with closed loop? The Tie rod ball joints look swept back a bit. Was that to give you a higher Ackerman percentage?
1139 Alumni
Unread 25-02-2008, 20:27
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
ED, So when are we going to see the whole robot.
Unread 25-02-2008, 21:24
AKA: Foxy
dont be afraid to pm me any details or just post here...
I'm very curious
Unread 25-02-2008, 23:09
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
looks impressive, very nice job
I'm curious to see how ackerman will compare to tank, crab, and mekanum (sp?) this year, and who will come out on top, control and speed wise. I'm sure cornering will be easier for you guys depending on your controls of course.
Good luck in overdrive
Unread 26-02-2008, 00:04
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
I have driven this robot, which has Ackerman steering. To me it felt a lot like an RC car.
1519 uses a steering wheel to control their robot. (not sure what 34 is using) I thought it was more intuitive at first, than a tank style robot, but it takes as much practice to get good at it.
Very nice robot!!
I like the blue! I'm really looking forward to seeing the whole thing.
Unread 26-02-2008, 00:13
Robotoer's Avatar
Robotoer Robotoer is offline
Team 1678 Engen - Team Captain
FRC #1678 (Engen Robotics)
Robotoer is an unknown quantity at this point
Send a message via AIM to Robotoer
Team 1678 used a Van Door motor attached to a bar with potentiometers for ackerman steering. What kind of program/control system did you guys use to control steering? We were having some issues with making our system match its wheel angle to the angle of our steering wheel. Of course, I didn't know about PID loops until after we shipped the robot , but still, I am curious.
Team 2468 Fully Functional Steering Robot Coach Norm Robot Showcase 11 11-02-2008 00:53
steering wheel help FIRST Team 2044 bsbllpss Programming 3 23-01-2008 16:13
pic: steering edomus Extra Discussion 10 05-06-2005 11:12
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
