#16
Re: pic: Team 148 Robowranglers: Swerve Module and Motors
Holy cow I don't know if the main breaker can even handle that much ampereage!
Do you have any trouble with anything popping/blowing if you slam it into forward (or switch directions)? Awesome! Now I REALLY can't wait for that video! -q |
#17
Gah.....ahhhhh......ummmmm.......holy......... I suppose not everything in Texas is big
Speechless. Entirely speechless. Well not entirely.... Elegant, innovative, and a total commitment to a strategy. There's so much about this robot I like, I had a hard time picking a thread to post in. Perhaps this is the perfect time for JVN to tell us his thoughts on Tumbleweed and the experience the 148 students had in the process. You've been really quiet for months and I know you're watching ... and there are so many of us out here that LOVE to learn from you ![]() |
#18
ohhhhhhhh pretty Well we've seen some bots do 10 laps in 60 seconds, I'd imagine this would have to be comparable or better. 20 Laps is 40 points, add some for auton and you've got a winning bot. Can't wait to see you guys in the big easy ( that is if I get to go :-( ) |
#19
Woah! Very nice!
It's nice to see the influence of such a prominent team, the Robonauts, displayed all around. Their idea of the V6 seems to have been simplified so wonderfully! I love how you rolled from their enormous system into such a small package. Bravo! Last edited by CraigHickman : 24-02-2008 at 20:09. |
#20
If you want to go 20 fps you need 6 motors. If you need 6 motors and want to use a crab drive, you have to do coaxial crab. If you want to save weight/complexity, you use 3 wheels. If you use 3 wheels, you have to use all 6 motors in one gearbox. I think both are each very much their own designs. Last edited by Cory : 24-02-2008 at 22:11. |
#21
Really...This from a team known for putting 2 CIMs and 1 FP in the same gearbox for a 6WD drop-center.
#22
#23
True, I wouldn't necessarily make all of those statements as written, particularly in that order, but I think the point still stands. If your goal is to go as fast as robotically possible, you want 6 motors to help acceleration. If your goal is maneuverability while putting all that power to the ground, you want a swerve. Three wheel (67-esque) is a simpler and lighter way to make a swerve. With six-motors and any odd number of modules (except one module), you probably want a coaxial method powering all of them from one gearbox, otherwise you'll have an unequal power distribution between your modules. The module itself was stated to be inspired by 217's systems from about six years ago. I wouldn't be surprised if there was some Robonaut influence in the design (how they steer all the modules together, for example), but it isn't a really obvious one like using a West Coast Drive or something like that.
#24
254 has never had a 6 motor drive before. Not sure who you're referring to? Quote:
I was brief in my description, but it shows you what I believe their design path to be, and why. If you think about it, I think it's not unreasonable to come to the same conclusion |
#25
Although your point is well taken, you may want to be less vague with your statement. If you believe that some or all of Cory's statements aren't valid, specifically address them with your rationale. I'm not trying to single you out, but lately there's been far too many posts where people make claimss without any real justifications. As for the meat of Cory's post, I'll attempt to point out the flaws that I think Morgan was trying to get at. - Although not impossible to go 20 fps without 6 motors, it is incredibly difficult to so with a typical FIRST robot. Unless your robot is significantly lighter than usual, or uses a very low traction wheel, issues such as breaker tripping and battery power become quite serious when only using four motors. - If trying to do a swerve with 6 motors powering your modules, coaxial is by far the easiest way to do it. As you increase the motors in your system, having to rotate them with the swerve module becomes cumbersome. (In 2004 we used two two-motor swerve modules to drive our robot. Designing our modules such that they remained compact was a significant challenge.) |
#27
The point is, you don't have to have a crab with 6 motors. Though I see you've edited for clarity, and I do agree with the 6-motor swerve needing a coaxial (otherwise, you've got two motors loose...), unless you have a three-wheel crab, and if you have that, one wheel will have more power if you don't have a coaxial. |
#28
Even if you had a 3 wheel crab, it would make no sense to have two wheels with two CIM's each, and one wheel with two FP motors. Hence the need for a coax drive. |
| pic: Team 148 Robowranglers: Controls | Brandon Martus | Robot Showcase | 8 | 04-04-2008 02:28 |
| pic: Team 148 Robowranglers: TUMBLEWEED | Brandon Martus | Robot Showcase | 38 | 21-02-2008 22:10 |
| Team 148: Robowranglers Video | Brandon Martus | Robot Showcase | 7 | 24-05-2007 21:21 |
| Team 148 Robowranglers Autonomous on high and medium | chrisrobin | Robot Showcase | 5 | 24-03-2007 11:59 |
| pic: Robowranglers Teaser (FRC 148) | Brandon Martus | Robot Showcase | 5 | 14-02-2007 22:36 |
