Go to Post When we find bugs at work, we don't ask "who wrote that section of code?" We ask "Who is the best, most knowledgeable person to work on fixing this bug?" - Jon Stratis [more]
Unread 25-02-2008, 01:19
George A.'s Avatar
George A. George A. is offline
I come through in a spinsch
AKA: George- The Voice
FRC #0303 (TEST Team)
George A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond repute
Send a message via AIM to George A.
Any sound engineers out there?
Here's my issue(s)
I'm trying to create a karaoke track for a party I'm holding, and I have no idea how to do it.
My problem is in fact 2 fold:
1) How do I convert an MPEG-4 audio file to MP3? Anyone able to help me with just that would be great.
2) Anyone know how to remove vocals from tracks?
Basically if anyone can help me at all it'd be a tremendous favor.
My Volunteer Resumé
Game Announcer NJ: 2005-Present
Game Announcer Philly: 2006-Present
Game Announcer NY: 2005-2008
Game Announcer Champsionships: 2005-2008
Unread 25-02-2008, 02:46
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Any sound engineers out there?
As far as a good converter from MPEG-4 to mp3 I use dBpoweramp Music Converter (dMC) for all my audio converting needs nowadays. It's great, but may require some additional codecs depending on what type of format you want to convert from. Not a big deal usually, just a few seconds to DL a new codec into it when it needs it.
http://www.dbpoweramp.com/dmc.htm
As far as canceling the lyrical portion of a song out for karaoke purposes, I'm actually spoiled as my stereo does that with the touch of a button (although I've never used that feature), so I'm not sure how to do that part.
Hope this helps!
Unread 25-02-2008, 03:13
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
There's no perfect way to remove vocals from a track once it's been mixed down (i.e. from anything you'd get off a CD, mp3, cassette tape, etc).
The most commonly used method of remove vocals makes use of a "standard" mixing style, which leaves the vocals centered between the left and right channels, while panning the instruments. The trick is to (warning, some physics involved) invert one of the channels, then sum the channels together, letting the destructive interference get rid of the vocals. [/technical description]
The problem with this is it can also get rid of some stuff you do want, so the track may sound a little distorted. It can also not work at all, depending on how the song was originally mixed, or if the track is mono.
If you want to try this out, you can do it manually using the freely available Audacity* audio editor, using the available video guide. Alternately, there is a freely available plugin for WinAmp that will do it for you.
Good luck
--Ryan
*The Audacity site seems to be down right now, but you can still get the software here
Unread 25-02-2008, 04:02
George A.'s Avatar
I tried downloading Audacity, except when I opened the song file instead of the full song it was just a quick blip and that was it. I can't figure out what is wrong with it.
Oh well.
My Volunteer Resumé
Unread 26-02-2008, 01:22
RyanCahoon's Avatar
Oh well.
This happens when you try to open a format Audacity doesn't understand. There's no option available for MPEG-4 that I know of, but if you've gotten the file converted to MP3 (try www.media-convert.com if you have a decent internet connection) you should be able to open it. The one thing is you have to install the LAME MP3 encoder (as described here).
Hope that helps
--Ryan
Unread 26-02-2008, 02:41
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Unfortunately, most tracks sound awful after canceling the vocals out because they're not mixed entirely to center. The DJ software I use on my PC has a plug-in that does this automatically and the results are usually terrible -- but it may be the best you can do.
Out of curiosity, what song are you trying to make into a karaoke track?
--Madison--
...down at the Ozdust!
Unread 26-02-2008, 23:18
George A.'s Avatar
It's all about the Pentiums, by Weird Al.
My Volunteer Resumé
Is there any North Dakota Teams out there!! team877 General Forum 0 21-01-2008 07:56
could any engineers help me out please? archiver 2001 6 24-06-2002 02:55
Any Sponsors Out there? archiver 2001 3 24-06-2002 02:17
Any Information out there? Shelley_delphi chick Career 0 05-12-2001 11:04
any animators out there? Dave_222 3D Animation and Competition 3 14-10-2001 23:20
