Go to Post Code doesn't break. It reacts exactly the same time every time. When something new happens that never happened before, it's because the mechanicals, electricals or drivers gave the code some new stimulus that wasn't tested before. - GaryVoshol [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:39
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Have you backdriven the wheels by hand?
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 4/2/2000 7:51 PM MST
In Reply to: Re: EXACT Same problem seen on the mystery machine posted by Travis Covington on 4/2/2000 11:32 AM MST:
Have you actually backdriven the wheels on the two sides to get a feel for whether or not something is causing a hang up on the bad side?
Backdrive effort is a pretty good method to judge efficiency of gear trains.
Also, have you tried switching the left and right side wiring so that you can judge if this is an electrical or a mechanical problem?
This is not a fool proof method. As it turned out on the Mystery Machine they had multiple problems that caused us to be confused by this technique --- actually, this is probably worth going over --
Like you, they had one wheel (the left side) that would not go under load. We found that it was tripping the breaker. When we switched the wires from side to side, the right side would not go under load.
As it turns out, ,they had binds in BOTH sides of their drivetrain (bad bevel gear bearing design, I hate bevel gears ;-).
Anyway, we were prevented from finding it because
1) they had not removed the no-backdrive pins from the transmissions and
2) they had a bad electrical connection on the motor that did NOT trip the fuse.
The bad connect caused high resistance that kept the RIGHT side from tripping the fuse. We kept looking for trouble in the wiring on the LEFT side (replacing the whole side piece by piece and then entirely). It really took a lot to discover that there were several problems causing the strange behavior.
I'll try to stop by the pits in FL to see if you have fixed the problem. I am sure that you will have more help than you can really use, but I will stop by just in case.
Good luck.
Joe J.
[IMG] code is Off
