Go to Post ... boundless mentory goodness ... - pfreivald [more]
View Poll Results: do you think they are unreliable
yes 20 66.67%
no 10 33.33%
Voters: 30. You may not vote on this poll
Unread 19-02-2008, 01:10
647techangel's Avatar
647techangel 647techangel is offline
K.I.S.S (Keep It Simple Stupid!!)
AKA: Tech_Angel
FRC #0647 (Cyber Wolf Corps)
Team Role: Driver
647techangel has a spectacular aura about647techangel has a spectacular aura about
Who thinks the IR board's operational characteristics leave much to be desired?
in other words it vehemently inhales
Unread 19-02-2008, 01:13
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Re: WHO THINKS THE IR BOARDS ...OPERATIONAL CHARACTERISTICS LEAVE MUST TO BE DESIRED
I would like it to have a diode but otherwise i like the idea
Unread 19-02-2008, 01:29
AdmiralAllen's Avatar
AdmiralAllen AdmiralAllen is offline
Master of Computers and Robots
AKA: Allen Worcester
FRC #1662 (Raptor Force Engineering)
AdmiralAllen will become famous soon enough
i could prolly build a better one myself......
Unread 19-02-2008, 01:32
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Although it is a new idea, it's VERY unreliable. I think it gets to the point that they might as well have not given it to us and let us do fully autonomous robots. It just makes the job for us programmers a LOT more complicated.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 19-02-2008, 03:14
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
The IR board is pretty reliable by my standards.
It survived a direct short from an energized frame(reminder, ALWAYS triple check how taped your batteries are) through the board, while only destrying 3 traces, that were easily (with a fine soldering tip and tiny wire) fixed.
It lives, and the hybrid code runs excellently. The range on the recciver is very nice when your remote uses full batteries, and it lived.
Unread 19-02-2008, 10:30
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We have found it reliable, and the support from the desgner outstanding.
I don't understand the complaints about durability when subjected to reverse-voltage. Try wiring a Victor incorrectly... (I've seen FETs explode!)
Unread 19-02-2008, 12:53
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Who thinks the IR board's operational characteristics leave much to be desired?
The biggest problem it has is not getting around IR interference - other remotes can make it unresponsive to your remote. While this is clearly something you'd want them to solve, it does bring up some pretty important real life considerations. When dealing with something like the Mars Rover, NASA fully expected to have continuous contact with it, but they couldn't plan on it. So they have to have a certain amount of autonomy built in in case something goes wrong with the communications. If, for example, the rover landed and broke it's modem, NASA couldn't have communicated at all. But the rover could still go around and collect data and store it internally, which NASA could retrieve at a later time. Another great example might be a remote deep see submersible. These are things that are generally controlled from a joystick on a boat, but do have certain programming if the communications drops - like return to the surface.
Regardless, when dealing with remote systems you ALWAYS have to plan for the probability of your communications dropping out at some point. In that regard, the IR boards are perfect for use in the competition.
Unread 19-02-2008, 14:59
Racer26 Racer26 is offline
My beef with the reverse voltage thing is that 1) a simple diode would have solved the problem, where this is more complicated with the victors, after all, they handle alot more power. and 2) the supplied ribbon cable has a BLACK wire connected to the positive pins, and a GREY wire connected to the negative pins. Needless to say this would be confusing to many teams (including my own), especially those with an electrical team thats learning.
Unread 19-02-2008, 16:06
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Ours worked for Twice. Our robot has no shorts, no current through the frame, and no shock to the board. It fried. There are no exact replacements though you can buy an equivelent for around 30 bucks. The only explanation for there spontaneous breakdowns given buy the designer was something that couldve been simply fixed by adding a few components before shipping them out to the teams. I have made equivelent boards and they've never broken down. unfourtunately they r built in to several projects that would be destroyed if i removed them so i guess were going to have to go with the KOP one.
First one to reply gets a cookie!!!
Unread 20-02-2008, 16:35
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Please don't say there is no other explanation. Unless you were actually wearing static wrist straps and practice proper ESD control there is no way you can blame this entirely on the design. The amount of static that is needed to damage a component actually falls under the value needed to perceive such a shock.
Unread 25-02-2008, 07:58
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
First off, I'm not sure that's the way to put it. Remember, the company that makes the IR board can read this, too.
With that said, I would have to mention- this IR board is new to us. It is something FIRST teams haven't done before, and will most definitely have bugs. Everything does. Think about the first week of regionals, every year, with the field control and scoring systems.
The first time anyone does anything, there will be a problem. It happens, and we have to try and fix what we can, instead of complaining about it. To quote my always-correct mother (who sometimes reads CD ... ), whining solves nothing.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 25-02-2008, 08:15
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
It's not Diversified's fault at all that this board is unreliable. It's the technology being used that's unreliable.
Using IR is very similar to the old "Wireless" telegraph from long ago. There are no channels... anybody starts keying their telegraph (pushing buttons on their remote) and everybody hears it.
IR wasn't really meant to have multiple unique signals going to multiple robots at the same time. Also, remember most television remotes are made to work in a living room, and I doubt many living rooms are as big as a FIRST field (or as brightly lit).
So, not at all because of Diversified but only for the sake of physics, we aren't using an external IR input during autonomous this year. But I think our robot does pretty well without it...
Thanks Diversified for making a great donation of Time and Money!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 25-02-2008, 20:59
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Old style party lines, ehhh?
I was actually thinking about that today. Wouldn't it be nice to be able to saturate the area with IR pulsed radiation? It would be like jamming- something several Aerospace sponsors work on for the military. Then good little programmers would have to devise methods to beat the jamming, such as perhaps specific spectral IR filters to only bandpass certain wavelengths, then authenticate with a certain code first..... anyway.
We've had no luck with the board. I looked at it when it first came in and then handed it off to another engineer. If it works at the competition, great, but since we don't really have a programming team I'm not too hopeful
What would I find really nice to see here? Telemetry feedback. Not every team has a huge gymnasium or build center to work on- or perhaps nascar style first person view of the action. That would impress me much more than a semi-teleoperated period.
Or even lastly... stateful machine. 4 command sequences each evaluated upon what the current state of the robot is. But since that's specifically outlawed I think our IR board will go sit next to the EDU robot.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 25-02-2008, 21:33
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
The board does have a lot of downfalls in its design like the brownout problem and no reverse polarity protection. Obviously these are simple problems to fix (a small code change and a diode), but this is not Diversified System's fault. All they do is put together the boards to the customer's expectations (FIRST). If I were to give them a circuit that would catch on fire and release tons of magic smoke, then they would, and they would not be accountable for my mistake. I believe Diversified Systems also manufactured our sensor strips, and it appears to be an issue with the schematic FIRST gave them, so again, this is an issue with FIRST. Don't get me wrong, FIRST is a great organization that has benefited me for 6 years now, but in the past two years, I've seen quite a few quality control issues, some of which were not FIRST's fault, but they could have been prevented by testing the KOP that every team gets in January.
I believe the big three (Dean, Woody, Dave) could have sat down in November with a prototype KOP and tried to make a robot with the parts given, then do stress tests like that of a competition robot for four weeks, and try to break some components by making mistakes like some students may do in the build season. By doing this, they could have found the issue with the BaneBot gear boxes that plagued many teams, they may have found the issue with the radios last year, they would have found the issue with the IR Board, and they would have found the issue with the gear tooth sensor board. By doing this, FIRST would save money and would ease the burden of the build season.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 25-02-2008, 22:39
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by eagle33199 View Post
When dealing with something like the Mars Rover, NASA fully expected to have continuous contact with it, but they couldn't plan on it...
No, not really. We knew that, at best, we would be able to converse with each rover twice a day and somtimes we wouldn't be able to converse for over a day. BTW, my wife lead the telecom team in flight operations for a few years.
Nope. The autonomous mobility software wasn't uploaded until after each rover landed (The first cut was still being worked on after they launched). Furthermore, there is no provision for either of them to go site seeing without permission from Earth .
-Kevin
Kevin Watson
http://kevin.org
who thinks this years competion is easy jedilearner General Forum 25 11-01-2004 00:55
who thinks that 74,68,9 were a good alliance 18voltMilwauke Championship Event 2 29-04-2003 11:46
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
