Go to Post Spelling mistakes make me sad...Almost as sad as not being able to go to Atlanta this year.. Almost. - Elgin Clock [more]
View Poll Results: do you think they are unreliable
yes 20 66.67%
no 10 33.33%
Voters: 30. You may not vote on this poll
Unread 25-02-2008, 22:49
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: Who thinks the IR board's operational characteristics leave much to be desired?
We have found our IR very reliable, once we got the remote we had programmed to a different setting(before we were having problems programming one button, less likely four, then once solved that problem we had no problem programming the IR and using it, it has good range and everything
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 26-02-2008, 00:05
AKA: Dr. Brooks
no team (WRRF)
The IR board, like every thing else, is part of the game challenge. If you reverse the power it fries like a few other IFI parts. Avoiding this by being careful, or modifying the board with a diode, is up to you.
The "brown out" problem is one of those unpredictable unfortunate things, leading to more game challenge that we counted on, but it is still quite surmountable. We will try Kevin's brownout fix as soon as we get access to the robot again.
I would like to suggest that those teams who have succeeded in reloading the IR board code show up at your event with a sign that reads "IR boards reloaded here." We will be at Portland, and San Jose with our PIC programmer. Make sure that you bring the standard hex file and the one modified according to Kevin's directions. The other teams counting on their IR boards will appreciate it.
Eugene
Unread 26-02-2008, 01:14
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Our IR board stopped working shortly after being mounted on our robot. I figured it was having the brown-out problem so we tried to reprogram it with no success. Reading the device revealled a bunch of emptyness. Then I checked the regulator and it was outputting 6 volts. I don't know if that wrecked the PIC or not, but it wouldn't work. The team decided that the IR isn't worth the effort due to the high probability of IR interference during the matches. We are going with an alternative means of communication.
Unread 26-02-2008, 01:35
dtengineering's Avatar
AKA: Jason Brett
If you don't like the IR board, don't use it.
We have been using a PIC16f627a with a PNA4602M IR receiver and about six lines of Pic Basic Pro code to decipher the Sony IR protocol for the past seven years as part of a mini-sumo robotics project. There is absolutely NO magic in reading an IR remote control signal... this board just makes it easier. At least until you hook up the power supply backwards.
It's a bit more of a challenge to program the IR routine in C than Basic, but there is no reason you couldn't just hook the Vishay sensor (or a PNA4602M) up directly to a digital I/O port on the RC and write your own code to decipher the signal.
And if you have a specific suggestion on how the board can be improved (yes! the diode would be a great improvement!) then make the suggestion.
Jason
Unread 26-02-2008, 01:56
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by dtengineering View Post
...but there is no reason you couldn't just hook the Vishay sensor ... up directly to a digital I/O port on the RC and write your own code to decipher the signal.
Excellent idea! A link to the code can be found here .
-Kevin
Kevin Watson
http://kevin.org
Unread 11-04-2008, 16:40
lingomaniac88 lingomaniac88 is offline
FRC #1554
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
Ours worked before the ship date, but for some reason, it wouldn't pick up the signal at the regional, even when I held it five inches away. It may be because there were some components in the way. I ended up making hybrid mode completely autonomous.
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
Unread 11-04-2008, 17:40
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
There have been many issues with the FIRST KOP IR board, but we were successful in getting it to work on the Chief Delphi robot. We scored three times during the hybrid period at the Great Lakes Regional in Ypsilanti, Michigan for a total of 24 points. We missed two chances to score because of robot misalignment so the opportunity to score was 5 times.
I will be delivering a presentation about how we used the FIRST KOP IR board at Atlanta during the 2008 Conferences. I am scheduled for 1 pm on Thursday. Presentation title is "Using the VEX robot system to prototype the autonomous operation of a FRC/FTC robot" . I think of it as "How we got the KOP FIRST IR board to work on the VEX robot and then the FRC robot" but that title doesn't really sell.
If you would like a powerpoint copy of the presentation, after April 17, when it will be completed, please shoot me an email at marccenter@inbox.com
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
who thinks this years competion is easy jedilearner General Forum 25 11-01-2004 00:55
who thinks that 74,68,9 were a good alliance 18voltMilwauke Championship Event 2 29-04-2003 11:46
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
