Go to Post Remember that the 4-slot cRIO...only has 4 slots. :) - Alan Anderson [more]
Unread 26-02-2008, 12:45
Aldabe's Avatar
Aldabe Aldabe is offline
It's a long way to the top
AKA: Eduardo de Souza Aldabe
FRC #0383 (Brazilian Machine)
Aldabe is on a distinguished road
Send a message via MSN to Aldabe
pic: Big Mouse 2
Unread 26-02-2008, 12:46
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Re: pic: Big Mouse 2
Heaven forbid that I seem uneducated/dimwitted/not seeing the obvious, but what exactly does it do?
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 26-02-2008, 12:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It's a mouse ball - or it works along the same principle. When the robot moves in the x, the ball rotates in the x and turns an encoder. Likewise in the y. In this manner, they use the mouseball for absolute positioning and use the gyro for heading.
Unread 26-02-2008, 13:09
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
so it is supposed to touch the ground at all times?
what about the bump under the overpass?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 26-02-2008, 13:16
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Brilliant!
Unread 26-02-2008, 13:20
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
It looks like there are compression springs around the four bolts holding it onto the chassis.
Art Dutra IV
世上无难事,只怕有心人.
Unread 26-02-2008, 14:11
The lane divider bump shouldn't do a whole lot.
What's this about a bump under the overpass? Is there something I missed?
Unread 26-02-2008, 14:41
GaryVoshol's Avatar
Cogito ergo arbitro
This is what you evidently missed:
6.2.3 The LANE DIVIDER
The TRACK is divided by a LANE DIVIDER that extends along the major axis of the TRACK. The
LANE DIVIDER is six feet tall and approximately 27 feet long. It is constructed of 1-1/2 inch O.D.
steel pipe and connecting hardware, forming railing panels. The openings in the railing panels are
filled with clear plastic to prevent portions of ROBOTS from inadvertently passing through the
structure. The LANE DIVIDER is attached to vertical posts that are anchored to supporting plates
covered by carpet. Note that these plates will create a bump in the carpet approximately 1/2 inch
tall
, and as a result the surface of the TRACK will not be perfectly flat. ROBOTS must be designed
to accommodate these surface variations. The LANE DIVIDER is attached to the floor such that it
should remain vertical and not move when struck by ROBOTS.
(emphasis mine)
(since 2004)
Unread 26-02-2008, 14:45
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
I like it - it is very clever way to track position in hybrid (maybe teleop, too?) - hopefully eliminating the issue of wheel slippage with encoders on drive wheels. Seems perfect for swerve drive control, especially (which I don't think you have, but I could be wrong).
By the way, I thought that I'd make the blatantly obvious Trackball observation.
Unread 26-02-2008, 14:48
tall
(emphasis mine)
Is that under the Overpass? No. It's under the Lane Divider, only part of which is under the Overpass. The reason I was asking what I'd missed is that there isn't a bump under the Overpass in the manual at all, other than the lane divider one, which shouldn't affect play very much, if at all. Tottanka is an FTA, so he'd know if there was a bump that wasn't called out and should have been.
I knew about the lane divider bumps already.
Unread 26-02-2008, 14:55
GaryVoshol's Avatar
Cogito ergo arbitro
OK, I assumed they meant the lane divider bump that is even with the overpass. Yeah, that's my story, and I'm sticking to it ... I didn't misread the question.
I recall another BUSTED myth, that there would be a slight bump at the finish line. Someone's depth perception was thrown off by the checkerboard pattern.
(since 2004)
Unread 26-02-2008, 15:23
Manoel's Avatar
Manoel Manoel is offline
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Oh, it swerves.
We are using it in teleoperated mode as well to keep the robot driving/strafing straight. Hopefully everything is going to work in a crowded field!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 26-02-2008, 22:06
JM987's Avatar
JM987 JM987 is offline
High Rollers
AKA: Josh Mauro
FRC #0987 (High Rollers)
Team Role: Driver
JM987 has a spectacular aura aboutJM987 has a spectacular aura aboutJM987 has a spectacular aura about
Send a message via Yahoo to JM987
Just stop haha, geez relax man
Check Out Our Website!
HERE!
- 2009 Las Vegas Regional Winners (thanks to 1622 and 1013)
- 2009 Las Vegas Regional Chairman's Award Winner
- 2008 IRI Winners (thanks to 330, 67, and 68)
- 2008 Archimedes Division Finalists
- 2008 Las Vegas Regional Chairman's Award Winner
- 2008 Las Vegas Regional Winners (thanks to 39 and 1013)
- 2008 San Diego Regional Finalists
- 2007 FRC World Champions (Atlanta thanks to 190 and 177)
- 2007 Newton Division Winner
- 2006 Las Vegas Regional Winner
- 2005 Las Vegas Regional Winner
Unread 26-02-2008, 22:09
MDiff MDiff is offline
AKA: Diffy
FRC #0469 (Las Guerrillas)
MDiff is a glorious beacon of lightMDiff is a glorious beacon of lightMDiff is a glorious beacon of lightMDiff is a glorious beacon of lightMDiff is a glorious beacon of light
I like it a lot!
Looks very cool, and the nerd in me loves that it's a trackball
Although does it come with the same problems of a trackball? Get dirt in there and it fudges up
I noticed the springs to keep pressure forward, but it has something that restricts that movement right? as to not get very weird when lifting the robot
Speaking of which, i noticed you guys have mecanum (or we're assuming you do), have you ever run into the issue of having come off the floor having hit a corner too quickly and have the trackball skip any?
or is it only for autonomous?
sorry for the confusing sentence structure...
Unread 26-02-2008, 23:14
Manoel's Avatar
Originally Posted by MDiff View Post
I like it a lot!
Well, it's not a trackball, it's a standard, COTS billiard ball. It does get dirty so we will be checking on it before each match.
Neither the mouse nor the ball will fall off of the robot if it's lifted.
The entire structure is compressed about two inches by the springs, so small bumps shouldn't really make us lose contact with the ground.
We do plan on using it for teleoperated mode, but the driver has the possibility to turn off all automation and drive unassisted if he wants to.
Brazilian Machine
Team # 383
Optical Mouse Navigation phrontist Programming 60 14-03-2005 21:48
Looking for Mouse part Mr. Lim Electrical 3 27-12-2004 19:56
Optical Mouse / Ball Mouse Clark Gilbert Chit-Chat 26 22-07-2004 13:17
Mouse Odometer charlie_grr Chit-Chat 5 11-12-2003 00:34
Mighty Mouse Is Here RebAl Robot Showcase 0 31-03-2002 21:55
