Go to Post One of my early mentors gave me wise words -- when designing a system to compile & analyze information, your first design choice should always include consideration of a stack of 3x5 file cards. - Jaxom [more]
Unread 26-02-2008, 17:01
Re: battery charger
Yes.
<R48> The ES17-12 shall only be charged between MATCHES by a 6-ampere rated automatic battery charger. When recharging the Kit Of Parts batteries, either the charger provided by FIRST or an automatic charger with an equivalent charging current rating may be used.
Make that yes for both batteries:
<R49> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with a 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc. or any similar charging circuit (note: IFI will provide the design for this circuit on the IFI website, however teams must obtain the parts for this circuit and assemble it themselves). The use of this circuit is strongly encouraged.
Battery Charger schmidtz Electrical 9 03-02-2008 11:27
On-Board Battery Charger bronxbomber92 Technical Discussion 6 08-02-2007 11:11
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
battery charger archiver 2001 3 23-06-2002 23:20
Battery Charger jgrater Kit & Additional Hardware 1 12-04-2002 14:14
