Go to Post As a real pig farmer*, I definitely endorse team 1902. - Andy Baker [more]
Unread 15-02-2008, 00:20
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
15 pin cabel and connector of OI
Where can I get one?
Thanks
Unread 15-02-2008, 00:30
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: 15 pin cabel and connector of OI
The easiest place is IFI.
Scroll down or search for DB15
If you're planning on making a competition port dongle or a custom switchboard for your OI, don't bother with that. There are better things to use. If you just need a cable, you can get it there.
Unread 15-02-2008, 00:31
AKA: Dr. Brooks
no team (WRRF)
Thanks
If you find an electronics store frequented by hobbyists
and repair people, you will find the connectors and cables
that you seek. They are called d-sub connectors. You
get the connector, the back shell, the crimp pins, and 15
conductor cable at the same store. You want the male
connector and pins.
Check your phone book for electronics stores and call them
and ask if they have dsub connectors and tooling.
We use the ss109 aircraft rated version, ordered from www.steinair.com.
What you are likely to find at a local store is the commercial stamped
pin version, but it will do just fine.
Eugene
Unread 15-02-2008, 00:32
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
These connectors are called "DB-15", or "D-Sub 15" connectors.
Your local connector store should have them, as they are very common. Maybe even RadioShack. Worst comes to worst, you can cut off the connector from something else. You COULD order from digikey, but we ship in 3 days, so that would only give you about a day to build whatever you are trying to build.
You can use just regular wire. (24,26 gauge.... Stranded telephone wire)
Jacob
Unread 15-02-2008, 00:33
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
I think the quickest way is to buy a solder cup DB15 from radioshack and use a multiconductor wire like a cat5 cable.
hope this helps.
Unread 15-02-2008, 00:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I did not find any 15 pin connectors at Radio Shack...they have been obsolete for a while.
Unread 26-02-2008, 16:19
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Were you referring to the connectors, or Radio Shack?
Unread 26-02-2008, 19:40
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Sorry for the late reply....
I usually order most of our Teams "electronic" stuff from online mail order vendors. Mainly because our local RadioShack has done away with or stopped carrying the components we use. The DB-15 solder cup for example. I tend to use Jameco when possible and try to order in advance of the season for common items.
DB-15 Solder Cup:
http://www.jameco.com/webapp/wcs/sto...roductId=15035
Housing:
http://www.jameco.com/webapp/wcs/sto...roductId=15019
Wire 15 Leads:
http://www.jameco.com/webapp/wcs/sto...oductId=644455
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 26-02-2008, 20:50
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
go to l-com.com, they have everything in electronic
R.C.
MadTown Robotics Team 1323
Unread 26-02-2008, 22:28
DonRotolo's Avatar
Back to humble
FRC #0832
Radio Shack only sells the High-Density DE-15 connectors, which are used for VGA video for example. Standard DA-15 connectors are not carried by RS.
Aside from Jameco, also check DigiKey, Mouser and Circuit Specialists.
Don
Unread 26-02-2008, 23:01
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Don
our local radio shack has standard solder on DB-15 connectors
Unread 26-02-2008, 23:06
AKA: Jacob Komar
Typically larger RadioShacks in smaller communities have more 'parts' and less consumer electronics. I don't know what your RadioShack is like, but most of ours around here are electronic toy sale centers, as opposed to part centers. It sounds like yours is more like the one by my summer home in Maine, in a very rural community. The guy there sells everything from connectors to albums, and high-end and low-end speaker systems that he bought in the 70s!
Jacob
Unread 26-02-2008, 23:24
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
LOL! I used to hang out in Radio Shack in the good old days (mid 1970's), when I was 12, and help the customers (I knew more about electronics than most of the sales people). It was almost a real electronics store back then. They used to have walls and walls of parts: Now they have a few parts in drawers, and a few on the wall. I have more Radio Shack electronics parts than just about any Radio shack store does these days. Now they are mostly just an overpriced cell phone store (Though I occasionally drop in for old time's sake).
One of my saddest days was when they discontinued the Radio Shack catalog. I looked forward to it every year, and read every page as soon as it came out. I still have every year from the mid 70's to the end. (Maybe this post should go in the "I am a geek because ..." thread.)
PS: If you want to see how to connect to the OI in style, see the Team 116 OI adapter board on my web site via my link below, and in the thread about it here.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 27-02-2008, 08:48
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Thanks
super easy, go here:
http://www.action-electronics.com/co...ight=db15#Db15
Order this part, a male to male 15 pin cable. S-15MM-10
It is less than $ 11
then cut it in half and then you will have TWO cables. and wire the end into your custom box and save the hassle of fabricating the OI end of the cable.
Ed Barker
Unread 27-02-2008, 08:51
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
We get a lot of small electronics parts from these guys:
Marlin P Jones
Don't PANIC!
S. P. A. M.
Anyone have any leads on the steering wheel controller that uses a 15 pin connector? waialua359 Control System 20 30-01-2008 12:58
what is the four pin white connector for on the ir board ? Smaug Electrical 2 10-01-2008 23:37
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
DB15, Male 15 pin connector. AdamT Technical Discussion 8 06-02-2002 17:17
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
