Go to Post Students dream up the ideas for bots, it is than up to the mentors and engineers to make these dreams a reality. - dddriveman [more]
Unread 26-02-2008, 15:43
comwiz7's Avatar
comwiz7 comwiz7 is offline
AKA: Joey
FRC #1323 (Madtown Robotics 1323)
comwiz7 will become famous soon enoughcomwiz7 will become famous soon enough
Send a message via MSN to comwiz7
Question about Inspection
This is a pic of our robot. http://www.chiefdelphi.com/forums/sh...ght=1323+robot
My concern is that the back sprocket and chain that lift the arm are too exposed and they might make us cover it. Any thoughts?
Unread 26-02-2008, 15:56
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: Question about Inspection
There are several considerations regarding your question.......
Any exposed pinch or shear point needs to be evaluated for safety of the staff on the field, other robots and very important the persons transporting the robot and working on it in the pit.
A sharp or mis-shaped surface may warrant a guard or cover. The main question is "will this potentially cause physical harm".
note: To teams with stored energy systems.... is your system safe against accidental release, and if it releases what is the result? Flying robot parts at the staff or audience is a bad thing. Think about the worse case and plan for it.
Mike Martus
Racer26 Racer26 is offline
I suspect you will be fine, however a relatively simple cover could be made fairly easily.
Unread 26-02-2008, 15:57
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
I have seen much worse pass inspection. You should be fine.
Unread 26-02-2008, 16:45
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
it doesn't look like either stick that far out... but then again I'm looking at a picture.
I think you'll be fine but worst case you can tyrap a piece of cardboard as a cover as a quick fix.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 26-02-2008, 16:58
I'd be more concerned about those numbers and the drivetrain. The back sprocket should be fine (and if it isn't, it's an easy fix as noted), but the numbers in your frame look too small for regulation (I'm pretty sure that isn't 4" tubing). Another easy fix, but something to think about. It won't be too hard to fix the drive covering, either.
Unread 26-02-2008, 20:55
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
EricH you are right. those numbers are just for show and the #'s are actually on our bumpers. For the cover, would expanded aluminum be better or a sheet of lexan bent to form the shape, thanks
R.C.
MadTown Robotics Team 1323
Unread 26-02-2008, 20:57
Either would work, but expanded aluminum could pose an entanglement risk (and bends really easily--see 330's ramps after L.A. last year). I'd go with Lexan, or if it's a low impact application, corrugated plastic.
Unread 27-02-2008, 10:42
Joey,
It is hard to evaluate from this picture, your inspector will be able to give a better idea of the problem if it exists and how to address it. It looks like you might be near max weight at the moment. I do see a lot of tubing and wiring that is just hanging out that I would recommend to tywrap in place. I wouldn't want another robot to come along and rip it out leaving you undrivable or disabled.
Unread 27-02-2008, 10:52
IndySam's Avatar
Good call Al
One of the things I love about the inspectors is thy always see things that you don't see.
You have been with your robot and design for so long that you always miss things. The inspectors are veterans of competitions that can look at you robot with a fresh eye and help you improve.
Remember folks, your inspectors are there to make your experience a safe and reliable as possible. They are your best friends not you enemies.
HELP!!! question about inspection schmidtz Rules/Strategy 30 11-02-2008 08:59
Inspection question Sqwigy Pneumatics 12 08-02-2008 02:00
Question about treads? HarryV Technical Discussion 1 15-03-2005 12:53
Question about Outriggers stevo2k Kit & Additional Hardware 6 10-01-2005 22:17
Question about splines Daishichimaru 3D Animation and Competition 2 22-01-2003 09:20
