Go to Post There are no guarentees in life. Cherish what you have while you have it. None of us knows what tomorrow will bring. - KenWittlief [more]
Unread 26-02-2008, 22:08
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
IR board improvement
Attached is a new schematic for the IR board. I will be posting the layout within the next few days. I am posting the schematic to get feedback from teams before I do a layout. Once the layout is done, I will post the Eagle and gerber files for any team that wishes to build there own board to replace the board provided in the KOP. I have added a diode for reverse polarity protection and an electrolytic cap to help with any ripple. I have also increased the value of the current limiting resistors for the LEDS from 240 to 330. Any other suggestions let me know. Also, the finish board will have a ground plane covering the bottom layer.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 26-02-2008, 22:09
Re: IR board improvement
Also let me know if I made any mistakes. I was multi-tasking when I made this schematics.
Mike Copioli
Unread 27-02-2008, 14:50
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Please don't be offended, your efforts are truly appreciated, but there is an even simpler, more reliable option available. It is comprised of a single VISHAY IR receiver, a PWM cable and a PWM connector. That's it!
You then just add a small amount of code provided by Kevin Watson and BINGO, the RC is now your IR receiver as well. You do not need to "train" the receiver, you just pick which four commands you want to respond to in your code.
Details can be found in this thread.
Unread 27-02-2008, 17:46
nixie nixie is offline
nixie is an unknown quantity at this point
Mike,
Your schematic looks OK to me. One thing to check is the pinout of the voltage regulator. The pins shown look correct for the 78L05, but the part is called 7805. They are different. I would use a 7805, since they are available at Radio Shack. Also, you show an 8-pin dual row header, but the std size is 10.
Concerning the sw-only solution using just an IR receiver. That software seems to be only looking for Sony IR codes. How will that work with a bunch of teams at once? If everybody selects Sony, things will get very interesting.
Good luck,
Bob Grieb
Unread 27-02-2008, 18:26
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by nixie View Post
Mike,
Good luck,
Bob Grieb
You should make sure teams know what the valid input voltage will be with the added diode drop. Will they be able to use the ~7 volt PWM outputs? How about using a LDO regulator? Perhaps eliminate the regulator all together and have a pinout that allows teams to use the RC's 5 volt output?
Um, are you saying that you can somehow remove the interference in software or by choosing a different protocol? My suspicion is that there is zero difference between the software only solution and the IR board solution. Both are subject to interference because they both use the same Vishay IR detector and both ultimately do the protocol decoding in (PIC) software.
-Kevin
Kevin Watson
http://kevin.org
Unread 27-02-2008, 21:00
DonRotolo's Avatar
Back to humble
FRC #0832
I think the implication is that there is a greater possibility of one team's code matching another team's (and therefore causing unintended operations), as opposed to the interference issue which is a physical phenomenon and on which you are absolutely correct.
Just a different point of view.
Don
Unread 27-02-2008, 21:43
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: IR board improvement - JP1
Mike,
Kudo's for coming up with 2008 IR Board #2 design. Further recommendation deals with JP1. Since the standard method of hooking up is to use 3 wire, pwm cables, I recommend modifying JP1 to become 4 sets of 3 wires to mate with the pwm cables for the 4 signal input/outputs. The 10 pin JP1 would then become a 3 column by 4 rows or 12 pin connector.
Since your design features a reverse polarity diode without a LDO regulator, I would propose moving the power/ground
input to a separate connector (JP3?). I added this in conjunction with one of those 2 pin terminal blocks to provide power
to one of the KOP IR boards. I am assuming a connection to the 12V fuse panel in this configuration.
I would also consider, if space permits, having open solder pads connected to the 12 JP1 connections to allow soldering a pwm wire with it's one connector cut off. This would eliminate the possibility of a pwm connector coming lose for team's that use the solder route.
Can you also space the 78L05 TO-92 pads to be TO-220 pad spacing? This would facilitate replacement of the 78L05 with 7805 TO-220 parts. I needed help from Frank Leritz, HDC-Troy, to swap out the part because the TO-92 pads were so tightly spaced.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 28-02-2008, 01:01
billbo911's Avatar
Good luck,
Bob Grieb
With all the people that can possibly respond to this, I believe your opinion carries the most weight considering the amount of time you put into the IR side of this competition. As you well know, the Sony as SIRC protocol is fairly well defined, and it is a very popular protocol.
After playing with Kevin's software for just a few minutes and one of my universal remotes, I have found a quark and the protocol. We fully intend to take advantage of this quark.
In addition to taking advantage of this quark, there are other things to consider as far as strategy with this game. When and how you use your IR remote will have a big impact on how well the receiver operates in this environment. If the intent is to use the IR during a time period when most teams will not be, and from a location that may not be common, as in immediately after the ball is placed and before the bots are put in to hybrid mode, from the Robocoach Station right next to the Alliance station, then the outcome should be quite favorable.
Your point about the amount of IR signals flying about is quite valid and we have considered that extensively before coming up with our strategy to play this game.
The bottom line is we may choose to use your IR board, or the software only solution. We will determine this during practice on the first day of competition. Personally, I think we may be leaning toward the software only solution because it allows us to place the IR receiver and a much more favorable position on a robot than we had originally placed the IR board. That alone may be the deciding factor for our team.
Unread 28-02-2008, 01:41
FRC #2429
Ugh, hopefully you mean quirk with the protocol and not quirk with the software <grin>. BTW, I know I owe you an e-mail and I'll get to it tomorrow at some point.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-02-2008, 02:01
Please don't be offended, your efforts are truly appreciated, but there is an even simpler, more reliable option available. It is comprised of a single VISHAY IR receiver, a PWM cable and a PWM connector. That's it!].
The purpose of this post was not to provide an alternative but to provide teams that have already implemented the IR board with a replacement if there board was to go south. Using the RC is an obvious option. This is simply a replacement for teams that find themselves in need of another board when one is not available.
Mike Copioli
Unread 28-02-2008, 02:18
billbo911's Avatar
-Kevin
Yes, the quirk is in the protocol, not your code.
I would rather not reveal exactly what I found so that the advantage will not be nullified by multiple teams jumping on the same bandwagon.
Mike,
My concern with posting what I did was that I would be detracting from the work you had done. By no means did I intend to minify your solution. The software only solution Kevin provided is just that, another solution.
Between these two options, teams should be fairly well covered.
Unread 29-02-2008, 10:18
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
This is a great idea, our team fried the IR board, and we have not looked for a replacement because of cost, but we have an ability (PCB knowledge) to make the circuit board through http://4pcb.com with their Student Discount fee.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 16-03-2008, 21:32
jmu465 jmu465 is offline
FRC #2077
jmu465 is on a distinguished road
A second and less obvious diode is common across the Vin and Vout pins of the regulator. This is a common design practice (but interesting left off the app note for the LM79L05) This diode protects from transients during power down. Imagine the device is powered up and then Vpwr is suddenly (0V) removed. This second protection diode is required to discharge the filter caps on the output by safely shunting the current around the regulator. Without this diode, the Vreg will be stressed with reversed polarity. VReg are hyper sensitive to any reverse voltage. As engineers we need to think beyond the "run" mode and also consider the power up and power down modes.
Mode Vin Vout Diode
Run 12V 5V Reverse Biased
Pwr Up 0->12V 0->5V Reverse Biased
Pwr Down 0V 5->0V Forward Biased
Hope this was helpful. Sorry the feedback is "late"
Unread 17-03-2008, 14:47
Excellent point, that is one reason why the 33uF cap is on the upstream side of the reg, that and to also filter out ripple.
Mike Copioli
Unread 17-03-2008, 15:02
Originally Posted by marccenter View Post
Mike,
Kudo's for coming up with 2008 IR Board #2 design. Further recommendation deals with JP1. Since the standard method of hooking up is to use 3 wire, pwm cables, I recommend modifying JP1 to become 4 sets of 3 wires to mate with the pwm cables for the 4 signal input/outputs. The 10 pin JP1 would then become a 3 column by 4 rows or 12 pin connector..
That is a great suggestion. The reason I stuck with the two row config is so teams that have already made custom wiring would not have to make a new harness. If they need a replacement they can just swap out boards.
to one of the KOP IR boards. I am assuming a connection to the 12V fuse panel in this configuration..
Same reason as above.
This is a great suggestion. I will see if I can fit a T-220. We bypassed the reg all-together and just run off of the 5 volt dig outputs +5v rail. The rc has a 5 volt reg built in. Why not use it. If you do, you have the advantage of not dealing with transient V-drop from overloading the 12 volt battery. Any time Vbatt drops below Vdropout the backup battery kicks in. You have near perfect regulation. Also, you can wire the board directly to the rc without a breaker as allowed by the rules. This saves weight and I know how precious that can be to those mechanical people.
Mike Copioli
[FVC]: Analysis Shows Improvement Possible in Ranking System billw FIRST Tech Challenge 24 05-07-2007 01:35
White Paper Discuss: Continuous Improvement - 2005 Championship Forum Presp Chris Fultz Extra Discussion 0 25-04-2005 12:55
Forum Improvement (Team Searching) Cyberguy34000 CD Forum Support 4 16-01-2005 19:27
A Simple Improvement to Driving generalbrando Programming 16 01-01-2005 15:32
[OCCRA]: Rule GR4.1 improvement Mike Martus OCCRA Q&A 0 13-09-2004 21:00
