Go to Post Either way, I'll stay a FIRSTer for life. =) - Adare180 [more]
Unread 27-02-2008, 08:55
Jaybee1405
Posts: n/a
pic: Closeup of 1405's Steering
Unread 27-02-2008, 09:05
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: pic: Closeup of 1405's Steering
Is your fork bending or is that an optical illusion? Be very careful with this, 710 did this style of steering in '03 and it was very sucessful however our forks had a tendancy to bend and one match the entire wheel dropped out of the bottom on to the ramp.
Coincidentally we still won the match missing a wheel, wish I still had video.
But if we had attended a second competition it would have been nesc to manufacture new forks. Because once you bend it back the strength goes down dramatically. It looks like the way you mounted them ( looks like #10 hardware? ) it should be relatively easy to replace if this does happen, but with the high speeds of this game and high speed collisions I'd make sure to watch out for bending and stress fracture and figure out a way to replace them quickly in the heat of battle. Also if it does bend don't let them get too bad before yanking them out otherwise you'll be sitting with a dremel trying to cut off the heads because you'll never get the bolts out.
Looks like this will be a fun bot to drive however, for some reason I've always liked this style over ackerman, maybe because its different.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 27-02-2008, 13:15
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
fun stuff nice job how it work
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 27-02-2008, 17:13
Jaybee1405
Posts: n/a
By "forks" I assume the mean the aluminum wheel housings? I don't think bending will be a problem. Maybe its the angle but they're about 6 inches deep. 340 milled it for us out of 1/4 in. aluminum and it all fits together great, plus I stress tested it with my hands lol. Thanks for the kind words though.
Thanks Colin, it works great. It allows very tight turns and high speeds. We're currently working on programming our potentiometer, so everything should be ready to go come March 6.
Unread 27-02-2008, 18:21
human
AKA: Colin Nobles
FRC #0148
joe if it becomes a problem we i e (ross) could weld it on with sum reinforcements right at flr
Unread 27-02-2008, 18:54
Jaybee1405
Posts: n/a
Thanks a lot Colin. I'll let you know if it becomes a problem.
Unread 27-02-2008, 21:20
afi419 afi419 is offline
afi419 is infamous around these partsafi419 is infamous around these parts
Why didn't you do ackerman
Unread 27-02-2008, 22:34
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I was concerened about that when I designed it, more so when the structure was slightly compromised. I was thinking about 3/8ths but I was also thinking about weight. Also I was not thinking much because I wanted to leave your school 2 hours ago when I was drawing that monstrosity.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 27-02-2008, 23:04
Jaybee1405
Posts: n/a
WAG/Accidental Ackermann!
Turns out that we have Ackermann (spelled with 2 N's)!! We take off the front cross bar and use the frame as the tie rod (the vertical shafts are the pivot points). The rear bar works for Ackermann because their pivot holes are inset slighly to the inside of the bot, pointing in the general direction of the rear axle. Obviously, it would be best to drill new holes that point exactly to the rear axle, but some Ackermann is better than completely parallel.
Last edited by Jaybee1405 : 27-02-2008 at 23:27. Reason: I spelled Ackermann wrong, of all things!
Unread 28-02-2008, 00:26
Imaginary Friend
AKA: Kevin Li
Team Role: Student
It's probably pretty close.
Kevin Li
596 - Sciclones
pic: Closeup of NK2007 Robot Showcase 3 10-02-2007 11:40
pic: Closeup of atlas ball Carol FIRST Tech Challenge 6 19-09-2006 23:47
pic: Chief Delphi Closeup sanddrag Extra Discussion 2 09-04-2005 23:10
pic: closeup of the omniwheel CD47-Bot Extra Discussion 4 20-07-2004 20:04
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
