Go to Post Engineering is all about trade offs. You can design yor system to do A, B or C easily. Combining A abd C or A and B or B and C requires some effort. Combining A, B and C should be near impossible. - Mike Betts [more]
Unread 28-02-2008, 13:51
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
IR LED wavelength requirement
howdy everyone, I have been thinking about all the talk about people hacking apart remotes, putting infrared LEDs in series and the like. Our team has a simple remote control for our transmitter and is using the FIRST supplied ir receiver. I was wondering that if I were to hack a few more infrared LEDs into the remote, what wavelength LED would I need to use?
I know it would have to be considered infrared but within, but does the ir receiver only recognize certain wavelengths of infrared emission? Does it really matter? Ive been looking at a bunch of LEDs with 940nm and some with 850nm wave lengths. Any help would be greatly appreciated.
Unread 28-02-2008, 15:00
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: IR LED wavelength requirement
Remember to look at both the sending element and the receiving element characteristics. The receiving element on the KOP board is the Vishay TSOP34838. I found the Vishay datasheet and Figure 11. Relative Spectral Sensitivity vs. Wavelength shows sensitivity from the range of 750 to 1150 nm.
It is greater than 50% from 825 to 1075 nm and peaks around 950 nm. Therefore, your selection of sending element frequency will tend to have minimum impact on the system design because the receiving element has a wide range of sensitivity. I will attempt to attach some pdf's for your reference.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 28-02-2008, 15:30
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I suspect more can be gained by moving the carrier frequency away from the usual 38KHz to 56KHz. This would, of course, mean that you'd have to find a remote that used a 56KHz carrier, or invent your own. If you're really hard-core, you'd invent your own data protocol with a error detection (and possibly error correcting) wrapper to ensure you're getting good data. You might get some ideas by studying my 2004 beacon code and transmitter circuit. A perfect transmitter waveform generator would be a EDU or Vex robot controller. Of course, if enough folks are interested, I'd be willing to help out.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-02-2008, 19:22
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
-Kevin
Good idea!
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 28-02-2008, 22:08
in between teams
AKA: Luke Van Oort
We have actually switched our setup over to a 56KHz system. This year, we were lucky enough to have the help of two alumni who just got their degrees (Computer Science and Electrical Engineering), and without them we'd never have pulled it off. As I understand it, they switched the IR receiver on the IR board to a different model, and built a custom remote. I had nothing to do with it, so I don't know the details, but apparently it wasn't particularly hard. We never got it mounted before ship, but we should be able to see if such a change is actually useful next week.
Team 1219: 2009 - Mentor
Unread 29-02-2008, 17:10
marccenter's Avatar
Talking Re: IR LED wavelength requirement
I switched over all the IR boards for the Chief Delphi team to use the 56 kHz Vishay TSOP IR part. This is just a matter of desoldering and removing the existing 3 pin piece and replacing it with the Vishay TSOP 34856. The units still work with the limited number of IR remotes tested (2) and still have jamming when both units are pressed at the same time. There is also a Vishay TSOP 7000 IR component that works at 455 kHz. My searching revealed that this is an uncommon remote frequency and I couldn't locate an inexpensive remote
that works at that frequency. I will post the Vishay TSOP 7000 IR pdf for reference.
Marc Center
Rule R17 - the flag requirement mwhebert Rules/Strategy 7 18-01-2008 12:44
Passport Requirement News dtengineering General Forum 0 25-02-2007 21:33
Team DVD Requirement Danny Diaz Chairman's Award 6 27-01-2006 19:00
Current Sensor Requirement Air Soarer Electrical 1 22-02-2004 17:46
SPI Requirement To Purchase archiver 2001 3 24-06-2002 00:33
