Go to Post "Well, geez, I can't figure this out. I cut the piece [I]three times[/I] and it's still too short!" - joshsmithers [more]
Unread 23-02-2008, 12:18
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Using Kevin's PWM outputs for a quieter drive system.
Now that the crisis is over for a while, my mind wanders to paths not followed. Specifically, using Kevin's PWM 12,13,14,15 outputs.
The fact that our drive system always sounds very "cruncy" with the banebot gearboxes when moving at anything less than full speed, made me start to wonder if using the custom PWM code would help.
I'm guessing that the default 38Hz rate could be part of the problem, but unless I call the PWM() function more often than during teleop(), even the "precise" PWMs give me the same quality... right?
Please educate me somone.... is there an easy way to use PWM() faster than the default rate to give me "smoother" main wheel drive.
Also, I do have a steering motor this year, so getting better control over this motor would be helpfull. Since it's based on a pot feedback, I guess I could use the PWM() call inside the code that checks for a new A2D value....
Reasonable??
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 23-02-2008, 12:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Using Kevin's PWM outputs for a quieter drive system.
Phil,
The PWM outputs on the robot we're so fond of don't actually spit out a true PWM signal that you would directly use for controlling a motor. They spit out a pulse train of 1ms to 2ms pulses. The Victors interpret this as 100% reverse to 100% forward and PWM their outputs accordingly at their own PWM frequency. So in answer to your question, you can't make your motors quieter by sending the pulses faster, you can only update their speed faster than the standard 38Hz.
You could however call Kevin's PWM function faster to gain slightly better control over your steering or any other feedback controlled system. Most systems on our robots have bandwidths less than 38Hz, so the gain isn't going to be huge, but you should see an improvement. You should keep in mind however that you can only update the victors at around 120Hz max, so be certain you don't call the function any faster than that.
Unread 23-02-2008, 12:58
PhilBot's Avatar
AKA: Phil Malone
That's usefull information, since with servos, the actual output drive IS directly related to the RC's PWM frequency (many servos use the PWM leading edge to initiate the drive signal)
So that begs the question....: What is the PWM Output frequency of a Victor? and: Why does my transmission sound so cruncy at low power.
The noise starts well before the GBox's output shaft starts moving, so I assume it's an oscillation detectable at the motot's output shaft.
Phil.
Phil Malone
Unread 23-02-2008, 18:00
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
With regards to your gearbox - they are LOUD. Grease the heck out of them with some good thick grease, put a motor on them and run them with no load for a bit to break them in. They aren't going to get a whole lot quieter though.
Unread 28-02-2008, 15:22
Kevin -
Is 120Hz the actual max update rate on the victors? Is this published info or do you just know off hand.
We desperately need more control on our drive motors this year but the 40Hz loop is wayy wayy wayy too slow. I'm not sure if 120Hz would even help.
Unread 28-02-2008, 17:21
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Tom Bottiglieri View Post
Kevin -
This is what I heard from one of the IFI guys when we were discussing my PWM code. I'm not sure if it's published or not.
There is something seriously wrong if you can't control a ~100 pound robot using KOP motors at a 100Hz control rate. Are you using encoders to determine velocity? Remember, the higher the control rate, the less you know about your velocity (Heisenberg was a very intelligent fellow ).
-Kevin
Kevin Watson
http://kevin.org
Unread 28-02-2008, 17:43
Kevin -
Tom,
IFI seems a little conflicted about exactly how fast you can update the vics. This FAQ says the update rate is 120 Hz.
However, This other FAQ says that the vic requires the signal line to be held low for 8ms between pulses. Which actually works out to 100 Hz, considering the 2 ms high pulse for full forward condition. So I think you'd be safe setting up a timer and updating the PWMs at 100 Hz in your x_Spin() function. IFI also says that there maybe be a delay before the change is reflected on the output, so it might behoove you to set up a test rig and monitor the output on a decent digital storage o-scope.
I'll note that 57 had a fast update loop on our shooter wheel a few years back. We ran it at about 75 Hz, if I recall correctly. Our update rate was actually primarily limited by how quickly it was reasonable to sample our encoder. If you're going the standard route of counting encoder ticks per unit of time to get velocity, getting a 100 step resolution at 100 Hz means you're servicing 10000 interrupts per second. We had a fun trick to get around this without any extra hardware, but it's only good for 1 encoder and it's non-directional to boot.
Unread 28-02-2008, 18:03
Using current sensors, not position feedback. We've been trying to use some back emf based control to take out the back drive and slop in the KOP motors.
Unread 28-02-2008, 18:19
FRC #2429
It's been on the back burner for a while and someday I'll get around to finish coding it, but a really neat trick is to not measure the number of encoder ticks per unit time, but to measure the amount of time between ticks instead. Using your example, you could use the internal 10MHz timer to give you a one part in a thousand resolution in velocity at a control rate of 10KHz!. If you don't need to control at 10KHz, you can forward predict the number of ticks to accumulate for a, say, 100Hz control rate, which will give you an incredible velocity resolution of about one part in 100,000. I've used this technique in a few applications for my day gig, with pretty stellar results. Pretty cool, eh?
-Kevin
Kevin Watson
http://kevin.org
Unread 28-02-2008, 19:29
-Kevin
To continue my recent trend of totally sidetracking threads...
I've thought about going that route myself, actually, but I've been put off by the inherent difficulties of measuring slow speeds with that method. Resolution at top speed is actually lower than resolution at slower speeds. If your top speed is 10 RPS and you've got a 100 pulse per rev encoder, the time between pulses would be 1 ms. So you prescale your timer to count at, say, 10 microseconds. That means your time to speed conversion is 1000/ticks = RPS. So at 100 ticks, speed = 10 RPS, at 101 ticks, speed = 9.9 RPS, 1 tick difference = .1 RPS. At 1000 ticks, 1 tick difference = .001 RPS. And at this conversion rate, the slowest speed you can measure (easily) is 1000/65536 = 0.015 RPS. That's a pretty good range, provided 1% resolution at your top end is adequate. The main problem with the concept as a whole is that your update rate slows down the slower you're moving. At 1 RPS, you'd be updating every 10 ms. Or once a control cycle if you're working at 100 Hz. At .25 RPS, it's once every fourth control cycle and so on. So I think it'd be optimistic to expect a PID based off this to maintain 0 velocity.
Programmatically, my main problem is that unless you've got extra logic in there, things get screwy if you're moving at less than 0.015 RPS. If you roll over the 16-bit timer, it suddenly looks like you've only taken 1 microsecond between pulses and you're suddenly traveling at ludicrous speed. So you'd have to have extra logic tracking how often you've rolled it over, etc. And, of course, the encoder jiggling while you're at rest would make it look like your robot was traveling at a fair clip as well, and etc, etc, etc.
So, mostly, it'd be a fair amount of effort to work up this code, I think. At least it would be to get it efficient and fast. That plus the prospect of a totally new and different control system next year has pretty much completely sapped me of any will to work on it. Except, of course, that composing this post already started the process of hammering out the logic and structure and working around at least some of the problems.... I'm actually pretty sure you could make it work fairly reliably off your Port B Encoder jiggle-resistant logic.....
Unread 28-02-2008, 19:59
MWagon MWagon is offline
Curmudgeon
AKA: Todd
FRC #0057 (Leopards)
MWagon is an unknown quantity at this point
Inquiring minds want to know:
Which of you Kevin's originated Kevin's PWM code: Sevcik or Watson.
OK, I didn't search. So shoot me already. Wait......
Unread 28-02-2008, 21:05
FRC #2429
It may be clearer when I admit that I've always implemented this functionality in a FPGA, not software. There is little difference though. Measuring low velocities isn't really a problem because you can expand the sixteen bit timer to any width by incrementing the upper bits in the ISR. Secondly, if you know your pressent velocity, you can forward predict the number of ticks to let go by before you calculate your next update.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-02-2008, 22:31
-Kevin
Yes, I agree that FPGAs, uninhibited PICs, MCUs, etc would all make implementing just about anything a lot easier.
And yeah, I was in fact already thinking about how I'd be incrementing a char as the timer was overflowing to expand my bits somewhat. I hadn't considered predicting a reasonable number of encoder ticks to measure over, however. That'd definitely be the way to make it work. More complicated, but not terribly. And pretty fast if you're changing the ticks by powers of two so you can just use bit shifts and masks....
Unread 28-02-2008, 23:03
I can't believe one of my own team mentors doesn't know this.... heh. Sadly, this doesn't mean I get to take credit. As far as I know, Mr. Watson is responsible for the all the "Kevin" labeled code around FIRST parts. So much so that I default to it in advising anyone wanting to use MPLAB to program their robot, since it just works. For the version I used during Aim High, I adapted some code posted by.... Someone I can't seem to search up at the moment. It didn't have Dubya's fancy gains, offsets, and range expansion, however.
And yes, that will be the first and last time I'll refer to Mr. Watson that way. It does get a might trying giving programming workshops and noting that, no, I didn't write the code. Nor am I in possession of the kevin.org domain name. Unless Watson foolishly forgets to renew his registration by... ummm... 05:00, March 27th, 2017. Cause, yeah... I know I'd never remember something that far in the future.
Unread 29-02-2008, 08:59
Kind of off topic, but related to my previous post:
I think I may have found another error in the control scheme I suggested before. It seems I was oversampling the ADC a bit too much and getting some slow readings.
motor = setpoint + ( amps * gain ) ;
To debug and tune we set the motor to a certain base fake velocity, and tuned the gain so that when we applied friction to the wheel it would keep the same real velocity. The problem that arose was the wheel would keep the velocity it needed, but would take about .5 seconds to "spin up" when the friction was applied and another .5 to "spin down" after the friction was released. At first we attributed this to the 40Hz control frequency (which im still partially blaming), but now I'm guessing I can attribute this to the laggy ADC readings.
Kevin^2, any comments?
Problem with PWM outputs on RC Adam Richards Control System 1 20-02-2007 06:37
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
What drive system is your team using? dpick1055 Technical Discussion 22 27-01-2007 23:29
Using 6 motors in a drive system? FIRST JerseyKid Motors 7 12-01-2005 23:49
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
