Go to Post Things go wrong; it happens to the best of us. You learn from it and move on. - Waynep [more]
Unread 29-02-2008, 01:15
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: NJ Regional: IR Legality
To clarify. I am not a programer by any means. They talk about speed as some kind of multiplier and percent of power, turbo mode etc. As our robot stands right now we only have the foward motion at a set speed, whatever way they set it, I know it is not full speed (18fps) which you could not rely on IR to control very well. You just push whatever button and the robot goes straight at a constant speed. And they have a button to stop all motion, just in case. From what I saw today, it looks like some teams have a reverse and I know our programers talked about adding it and that they wanted to keep stop, probably wisely, as the fourth option instead of reverse. It also looks like teams are changing the speed of the forward motion.
Unread 29-02-2008, 06:24
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
Red face Re: NJ Regional: IR Legality
What team are you talking about.......because we scored 28 points in hybrid (3 lines, 2 balls knocked down), and we certainly don't drive the robot fully. Basically, the robot is already preprogrammed to do a desired route around the field with input from the gyro and optical encoders, the job of the robocoach is only to "nudge" the robot left or right depending on where the balls are. We spent significant time working on and developing the remote and the code t make it just righht. If you are at the NJ Regional we have a Design & Manufacturing Notebook where it goes into more detail.
P.S. Sorry if i sounded a bit mad.....
Unread 29-02-2008, 06:27
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
we have 4 commands on our custom IR transmitter. They are
0. Raise our lower mast section for 4 seconds, then retract
1. Set a timer to 0 and Drive forward for two seconds, then stop
2. Set a timer to 0 and Turn left for two seconds, then stop
3. Set a timer to 0 and Turn right for two seconds, then stop
Pressing the buttons repeatedly result in the same function, thus we can mash the buttons for continuous driving. In addition, we can have multiple functions functioning simultaneously because of timers (IE we can raise the arm up and go foward)
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Gas springs legality itsme Technical Discussion 7 09-02-2008 21:21
Modifying piston legality? Zyik Pneumatics 1 27-01-2008 16:22
Legality question SonicKidGJ VEX 6 13-01-2008 14:00
Legality question Tottanka Rules/Strategy 5 14-02-2007 14:32
legality question rbayer General Forum 8 15-09-2002 00:25
