Go to Post I think it's pretty cool that the Black Eyed Peas and other celebrities are willing to take up their time to come celebrate science and technology with us. - BIGWILLI2081 [more]
Unread 29-02-2008, 20:02
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Get_Gyro_Angle() overflows beyond about -20000 deci-decgrees?
I'm trying to make an approximate lap counter by dividing the accumulated gyro angle by 360 (or 3600, since I'm working in decidegrees).
It works up to 5 laps, then the gyro value seems to wrap around to the positive side and start decreasing. I'm using long ints for the calculations. Here is a simplified version of the code....
  long int gyroAngle;
  unsigned int  numLaps = 0;
  gyroAngle = Get_Gyro_Angle();
  if ( gyroAngle < 0L ) gyroAngle = -gyroAngle;  //absolute value.
  numLaps = (unsigned int) ( (gyroAngle) / (long int)3600);
  printf( "gyro: %5ld LAPS = %2d\r\n", (gyroAngle), (int)numLaps );
//   etc.....
I looked at the gyro.c code briefly. Get_Gyro_Angle() (below) returns a long int, but there's a bunch of #defined constants, not all of which sport the decorative "L" at the end. (BTW, does "L" make a literal into a short int (16) or a long int (32)? I checked the compiler manual and didn't see it defined.)
long Get_Gyro_Angle(void)
	// Return the calculated gyro angle to the caller.
	return(((gyro_angle * GYRO_SENSITIVITY * 5L) / (ADC_RANGE * ADC_UPDATE_RATE)) * GYRO_CAL_FACTOR);
Why can't I get big values out of Get_Gyro_Angle()? e.g. 6 laps = 6 * -3600 = -21600.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 29-02-2008, 20:18
Re: Get_Gyro_Angle() overflows beyond about -20000 deci-decgrees?
  long int gyroAngle;
//   etc.....
gyro_angle * GYRO_SENSITIVITY * 5L is overflowing a long. Kevin's latest gyro code gives a little more headroom by rearranging the order operations are done to not overflow as early.
Unread 29-02-2008, 20:31
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
Okay, I'll check out Kevin's newer code....
BTW, for my current code I dereferenced the macros and got
        // translates to:
	//return(((gyro_angle * 800L * 5L) / (1024L * ADC_SAMPLE_RATE/(ADC_SAMPLES_PER_UPDATE * NUM_ADC_CHANNELS))) * 958/1000);
        // which translates to ...
	//return(((gyro_angle * 800L * 5L) / (1024L * 200/(4 * 1))) * 958/1000);
I guess I could make my own Get_Gyro_Angle_Low_Resolution() that doesn't use such a large value for GYRO_SENSITIVITY.
Unread 29-02-2008, 23:11
gnormhurst's Avatar
Norm Hurst
AKA: gnorm
I've seen the gyro.c,h code in the new 3.0 compatible code. I am using 2.4. Can I just drop the gyro.c,h files into my code and expect everything to be fine? Or are there 3.0/2.4 issues?
'Robocup, soccerdogs, and beyond' JaneYoung Robotics Education and Curriculum 0 24-02-2008 13:44
Drivetrains beyond the KOP twolf Kit & Additional Hardware 5 08-06-2006 17:25
Beyond the rules: helpful suggestions? Billfred CD Forum Support 1 25-05-2005 10:34
Team 33--Above and Beyond Beth Sweet Thanks and/or Congrats 3 04-04-2005 21:55
Moving beyond boxes on wheels. jon General Forum 29 07-04-2003 06:14
