Go to Post Well, there goes our bare aluminum corner tracking full field navigation system... - Whippet [more]
  #31   Spotlight this post!
Unread 01-03-2008, 00:07
jason_zielke jason_zielke is offline
AKA: Jason Zielke
FRC #1024 (Kil-A-Bytes)
jason_zielke is a splendid one to beholdjason_zielke is a splendid one to beholdjason_zielke is a splendid one to beholdjason_zielke is a splendid one to beholdjason_zielke is a splendid one to beholdjason_zielke is a splendid one to behold
Send a message via AIM to jason_zielke
Re: Rule G22 needs to be changed
Originally Posted by TubaMorg View Post
Here is the most important point of this discussion. If the rule were changed then just as many penalties would be called because teams would knowingly cross back partially but sometimes cross too far.
I would have to disagree with this point. I have been at Midwest for the last 2 days and have never seen a robot that crossed a line because they were trying to interntionally go backwards. I have seen robots with drivers that have little or no experience and struggle to control the robot crossing a line by 1/2" and then breaking the plane resulting in a penalty. We are putting a ton of pressure on the student drivers if we are expecting them to control a robot in a high stress situation, looking 50 feet down a field through multiple layers of lexan (that is reflecting in all kinds of funny ways) and keep from crossing a line backwards with no tolerance for error. In many cases, they can't even tell if they have crossed the line or not.
I am lucky to have an exceptional drive team, but I am sympathetic to those teams that have inexperienced drive teams.
By not penalizing until to robot completely crosses back across the line, you give the the drivers the length of the robot to recognize their error and correct it. This seems much more in the spirit of the game and of the mission of FIRST than penalizing a tiny error.
  #32   Spotlight this post!
Unread 01-03-2008, 00:17
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I will agree that this rule does seem to be a bit harsh in a lot of situations, especially in autonomous mode where there isn't anything you can do about your robot (unless you have a working Robo coach program). Unless there is a team with an auton program that is obviously making an intentional effort to go against traffic, I don't think the penalty should be so severe.
Tele-operated mode is a slightly different story, I can see how the rule needs to be there to prevent teams from going back across, but I don't think it's necessary to give a 10 point penalty just because a team happened to go like an inch across while still trying to go in the correct direction. Now if you have teams trying to go back to grab a ball, thats an obvious penalty, but so long as the intention is there, I don't see how it would cause a problem.
From a drivers point of view, it is very difficult to see your robot on the other side of the field, especially with the number of other robots that can be impeding your vision at the same time.
I guess I would just like to see the rule at least a little less strict.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
  #33   Spotlight this post!
Unread 01-03-2008, 00:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Speaking as a former referee (2005) intent is incredibly hard to judge in the heat of the moment. You can't assume anything about intent, only what your eyes have seen on the field.
You either have to call every infraction, no matter how small, or figure out how to keep teams from continuing to receive penalties, be it a rule change, or simply more practice for teams, etc.
2001-2004: Team 100
2006-Present: Team 254
  #34   Spotlight this post!
Unread 01-03-2008, 02:00
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Speaking as one of the many many loophole finders that plague the GDC every single season.... Dave's proposed rule change is going to cause more problems and is probably just going to be exploited by teams that could take advantage of it. I can think of a few teams that would benefit from redoes by whipping out an extension behind their robot so they have about 5 feet of wiggle room.
Honestly, if you really really absolutely hated this rule, just switch it from an instant penalty to a timed penalty like the endzone encroachment last year. You get a fair warning but still have leeway to sneak a bumper across th plane by accident.
  #35   Spotlight this post!
Unread 01-03-2008, 02:14
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
G22 is the 2008 version of the incredibly high 30-point penalties from Triple Play in 2005.
Yeah, we all hated the rule. Yeah, there were a ton of penalties. But eventually, teams got used to it and drivers learned to drive a lot more carefully while at the opponents end of the playing field.
That being said, I certainly do not like the amount of penalties being seen in this year's game. One way or another, I sure hope it goes down as the season progresses.
Art Dutra IV
世上无难事,只怕有心人.
  #36   Spotlight this post!
Unread 01-03-2008, 02:33
President, VEX Robotics, Inc.
I just don't get it. You have 30+ inches to figure out if the congestion will hurt you. Don't fully cross the line if you think you might have to go backwards. There are too many penalties because people are causing the penalties by not following the rules (in most cases).
This rule was clear from the start, never changed, and gives us 30+" of leway .. I just don't get why people are attacking this rule.
  #37   Spotlight this post!
Unread 01-03-2008, 02:45
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
I havent competed yet, but I think the big deal is that there are a lot of penalties occuring AND its affecting match outcomes.
I cant speak for the drivers that are doing it wondering why they aren't careful enough or the reasons why they "accidentally" do it (lack of sight, etc.) but I think its safe to say that teams dont purposely accumulate penalties and the comment about the lexan glare is a valid one.
I certainly can understand some of the points made by my observations watching regional play from the "side" view all day.
  #38   Spotlight this post!
Unread 01-03-2008, 08:08
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
They are taking an incredibly hard line on this rule, and it needs to be modified.
I watched a number of matches where a robot crossed a line, turned to proceed onwards, and back corner of the bot crossed the line again when they turned. Instant penalty.
When a rule is broken this much, clearly unintentionally, then it needs to be changed. The spirit of the rule is to prevent backwards motion of the robots - against the flow of traffic. The letter of the law is making it very dangerous to do any maneuvering. MANY times it's being broken because bot has to back up to get away from a wall, etc that they've been pushed or bumped into.
I agree with Dave. This rule is deciding way to many matches, and needs to be changed to penalizing a bot that FULLY crosses back over the line. Then all these small unintentional crossing penalties that are having a major impact on the final scores would be mitigated.
  #39   Spotlight this post!
Unread 01-03-2008, 09:20
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Paul, what I'm seeing a lot of and the reason I think this needs to be changed is that we're seeing lots of tank-steer robots which cross the line then start to tank-turn which causes one of their corners to back up slightly, creating a shadow about 1" long on the other side of the line and BAM... penalty. The majority of the penalties I'm seeing are not at all intentional and many are coming from younger teams with less experienced drivers.
Incidentally, I think we've only been penalized for this once. I'm not arguing for this change for the benefit of our team, but rather the many other less experienced teams that are getting dinged repeatedly basically just because they have inexperienced drivers and robots that aren't quite as easy to control.
Maybe it's just not being enforced as strictly at your regional as here.
  #40   Spotlight this post!
Unread 01-03-2008, 09:35
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
That is a very good point. It is hard to judge "intent" when you have 5 other robots and such to watch. Thinking about it more, I do think that drivers will learn (over time) to be more careful and they'll pick up less of these penalties.
However, if someone has an auton that goes awry, I feel that it shouldnt be penaltized UNLESS it hurts another robot.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
  #41   Spotlight this post!
Unread 01-03-2008, 12:37
AcesPease AcesPease is offline
Teacher Mentor
AKA: Bill Pease
FRC #2836 (Team Beta)
AcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud of
It sounds like the head referees at this weekends events need to meet with the GDC and decide if a change is needed, and if so, be sure it doesn't make the problem worse. I hated the way penalties decided matches in 2005, and I do not want that to rule the game this year. BUT, We all knew the rules before this weekend started, a new rule may be tough on some teams that are already avoiding this penalty.
Bill Pease FIRST Team 2836 Team Beta
Formerly FIRST Team 176 Aces High
WFF 2010
  #42   Spotlight this post!
Unread 01-03-2008, 13:32
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
After reading this thread, this is what I hear:
I don't like this rule. Change it.
What is this? Complaining wiil get you nowhere and I doubt this rule will be changed. Yeah, so there have been really nice matches that could've bee close if it weren't for that 1/16" bit of bumber that broke G22, but that's life. I quote:
Originally Posted by robostangs548 View Post
This game was built around penalties... we will just have to learn to live with it i guess...
Next to Copioli, this guy makes the most sense. (Thank you.) C'mon, y'all, hate the players, not the game.
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
  #43   Spotlight this post!
Unread 01-03-2008, 14:07
mathking's Avatar
mathking mathking is online now
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
I haven't been to any matches, so all I have to go on is videos I have watched online. It does seem like a very large number of penalties are being called. This should at least cause the GDC to take a look at the rule.
I do think that lessening the penalty in autonomous mode would be a good idea. It seems as though this year's game was designed to try to get more teams to try to do autonomous operations. Having a big penalty is just going to discourage the least experienced teams from trying to do much in hybrid mode.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
  #44   Spotlight this post!
Unread 01-03-2008, 14:09
Billfred's Avatar
Billfred Billfred is offline
I honestly think Copioli nailed it. We'll be nailing down drivers on Thursday at Chesapeake, and I'll be training them to make turns with a bit more technique. More specifically, I'll be telling them to get well clear of the lane divider before turning, especially in traffic. Even if getting closer to the field barriers is a bit slower, I do not want us getting these penalties. The more you can be sure about your clearance, the better.
  #45   Spotlight this post!
Unread 01-03-2008, 14:32
cbale2000's Avatar
AKA: Chris Bale
I think I like this solution better than any of the other ones I've seen so far, something that would give you a few seconds to correct your mistake, instead of x amount of inches leeway. It would keep the intention of the rule, without being so strict.
G22 Direction of Traffic Hilarity Kevin Sevcik Rules/Strategy 16 17-01-2008 22:30
problems with G22 JMH Electrical 2 19-01-2005 20:52
VB changed my capitalization! Greg Ross CD Forum Support 3 25-02-2004 15:42
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
A Changed F.I.R.S.T Vin211 General Forum 0 26-09-2001 22:39
