Go to Post What's the reason for having a rule if it's not enforced? - jpsaul7usa [more]
Unread 01-03-2008, 20:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Little-known rules for 2008
I'm sure that a lot of people will find these to be pretty fundamental, but I was surprised at the number of teams this weekend that were unfamiliar with these rules.
You can start your robot anywhere in your home stretch, so long as you are touching either the player station or the fence, and not touching each other. You cannot start your robot on the left side of the field (as viewed from the player station), nor do you have to cram all three of your robots flush against the player station.
Your robocoach should be looking directly at your robots when standing forward in the robocoach station. If you have to crane your neck to see your robot, you're in the wrong place. Also, your coach (the team member with the yellow dot on their badge) should not be in the robocoach station... particularly not the remote station.
You cannot grasp the opponent's ball, even as a method of removing their ball from the overpass. You also cannot grasp another team's robot, even if they forced themselves into your gripper. You are responsible for anything that happens with anything you stick outside of the starting envelope.
You cannot rear-end an opposing robot that is in the act of HURDLING. If you turn them, tip them, or otherwise interfere with their attempt, you will incur the wrath of the referees.
When you are fully within a quadrant of the field, you cannot break the plane of a line in the clockwise direction. This includes hybrid mode. This includes reaching your gripper over the lane divider into the previous quadrant. This includes your bumpers.
If you have any horizontal extension on your robot that can fit through a chain-link fence, please consider modifying it. I don't know that there is a rule specifically outlawing parts from passing through the corner fences, but you will undoubtedly incur a penalty under <S01> if you impale a robocoach.
Considering the cost of a penalty in relation to the average match scores so far, it's easy to see that adhering to these rules will greatly increase your chances of winning matches. Best of luck to all teams.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 01-03-2008, 20:43
AdamHeard's Avatar
Lead Mentor
Re: Little-known rules for 2008
Per the Q&A, I would like to add Impeding in Hyrbrid; So little-known this year, the refs weren't even aware.
Unread 01-03-2008, 20:44
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
You arent supposed to, however at the midwest regional today I never saw it called, when I thought it should have been called.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 01-03-2008, 21:06
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
This call was made several times yesterday and today at Midwest. Sometimes the announcer does not always announce why a penalty was given.
_
Unread 01-03-2008, 21:17
AKA: Joey
Were you at the regional, or watching a webcast? I was at the regional, I admit I may have missed some, however whenever I thought there should be a penalty I would look at the refs and they werent waving a flag. If you were watching the webcast, were you sure the penalty was for impeding? It is hard to tell what the penalty is called for while watching a webcast. They dont say the difference between impeding and clockwise penaltys at the end, I kind of wish they would. The vast majority of penaltys were from clockwise, I still havent seen a penalty called outside of that.
Joey
Unread 01-03-2008, 21:23
Joey
I did see a few on the webcast...There was one match that one highly veteran team hit another from behind when the second team was hurdling. At least one flag waved almost immediately. There were a few others that looked like penalties, but I couldn't see the flags.
When I was looking at the webcasts, if the team(s) I was watching broke a rule, I noted that they would have gotten a penalty, regardless of whether I saw that they actually got one or not.
Unread 01-03-2008, 21:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Joey
He was a referee at the event
2001-2004: Team 100
2006-Present: Team 254
Unread 01-03-2008, 22:12
AKA: Joey
Yeah, now I know. I dont mean it to sound like I'm bashing them, I'm just pointing out some of the things I saw. There are so many rules created that are hard to keep track of. I think this game needs more refs with more specific tasks. They did make alot of right calls though. This is a very hard game to ref, especially week 1. It just kind of bothers me that a match can change depending on the views of the referee, but so far I do think this ref certification is helping. I guess all sports change depending on the calls, and even the professionals miss things. Sorry if I bothered any of the refs, I am just pointing out some of my observstions to try to make later competitions better.
Joey
Unread 01-03-2008, 22:23
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Here's another one that does not appear to be known widely enough:
You can catch your control board/OI if it is falling off of the shelf due to a robot colliding with your player station wall in hybrid. Teams, don't let your control boards smash!!!
Unread 01-03-2008, 22:26
AKA: Joey
Don't rely on your drive team catching it. On the alliance station these is a long strip of velcro that you can connect your controls to. I dont know if it is the fuzzy or pokey side of the velcro though. Could someone who was at one of the comps let us know?
Joey
Unread 01-03-2008, 22:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Joey
According to the manual it is loop side (fuzzy). So your controls should have hook side (plasticky).
Anyone know if any controls that were velcroed have fallen?
Unread 02-03-2008, 10:16
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
When in starting configuration, does your robot have to be flush against the wall or just toughing it?
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 02-03-2008, 10:19
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Just touching it.
Unread 02-03-2008, 10:52
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
[quote=jgannon;710615]
QUOTE]
I was watching the webcasts and did see this happen alot but no penalties being thrown. Is this rule like the high-speed hitting rule only its watched more closely. Or is it like any time of tap, bump, anything being thrown at it and refs are just not noticing?
Im not insulting the refs or anything just want clarification because yea watchin the webcasts saw it and no penalty...
Unread 02-03-2008, 11:42
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
Someone please correct me if I am wrong, but in reply to an earlier post the impeading during hybrid penalty was removed in a team update. Not too sure which one it is though.
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
2008 Autodesk Inventor Design Competition Rules Clarification sfcaddesigner Rules/Strategy 1 21-02-2008 23:48
an idea for nats for a little bit of fun Masterfork Championship Event 2 10-01-2008 01:24
Where is the 2008 animation rules for autodesk animation? GVDrummer General Forum 1 09-01-2008 19:04
An apology from someone a little foolish, a little selfish, and a little inconsiderat Ken Leung General Forum 16 01-11-2006 10:07
teams known for scouting mrmummert Scouting 15 23-04-2006 22:07
