Go to Post If you think that teams would never bypass the rules or do something unsafe (intentional or unintentional), I suggest you spend a weekend as an inspector. Every bad scenario that you can think of, we have seen. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 02-03-2008, 11:57
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: Slack in the Overpass
"Team 25 posted something last Thursday indicating the overpass was an inch or so lower than it should have been, so if you're counting on having 1/4" clearance, you might want to rethink your design!'
good advice but the design stage was last January and it may be too late......
More on sagging overpass-
By the time NJ was finished yesterday the overpass was visibly torsioned. Numerous robots would hang up on it and try to pull away when they were hurdling and I am sure that was messing up the metal.
Our measurement in the field on Friday night had the overpass by the control side at 76" height midfield and 76.5 right at the wall (atop the wall support). Neither was the 78" assumed height (+- 1 inch). Yesterday it was getting lower in spots to the degree that we would pass cleanly under one side and tip the other on our IR guided round. Our robot height was set for 75". I measured it personally with a tape before the round.
In one round we popped the ball up slightly and it rolled down the overpass in slow motion like the marble in one of those games with the holes. It was obvious that the materials of the overpass were getting beat up and the height was nowhere near 78" as per specs.
As stated previously- we had more issues with the field related nonsense than with dealings with the other robots.
I would like to see teams allowed onto the field at the beginning or the rounds and at downtimes to take measurements so they can adjust their machines(in the same manner we had camera calibration times in prior years). We designed to the specs in the manual. If the field can't maintain that there is a problem.
WC
And one other thing-
we built our bumpers to the exact specs in the manual. We only covered 3 of 4 sides of the robot. Why would they weigh 16.5 lbs? The only way anyone's bumpers seemed to be passing inspection and making weight was to remove the angle aluminum that the manual tells us to put on them. We did so and had a half pound to spare.
If we had 4 bumpers and built them exactly as the manual prescribes they would never be able to pass the weight test. Maybe our experts who write the manual should reexamine their weights and measures or give a more realistic range.
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 02-03-2008, 12:10
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yes, it's too late to start over, but not too late to make some minor changes that might allow for the field elements to be as they really are. I guess that's just one more game challenge...trying to second guess how the actual field will compare to the drawings.
I think our 4 bumpers weighed right around 12 lbs, 26" for the ends and 36" for the sides, 5" high, no angles. Quick calculation of the weight of angle shows that adding 1/16" thick 3/4" angle would put them just over 15 lbs. Perhaps they had 1/2" angle in mind? Not much room for screws then....yes, the prescribed design seems to be questionable.
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Our bumpers are built to spec and cover three sides of our robot, they weigh exactly 10lbs. We have used full bumpers the last two years and have never been anywhere near the max bumper weight.
What size aluminum are you guys using? What size bolts? What kind of plywood?
We use 1/2" and there is plenty of room for the screws.
Unread 02-03-2008, 12:30
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
Wayne,
Were you measuring to the top of the overpass or the bottom? The specs clearly state the height of 78" is to the top of the overpass. With the pipe at approximately 1.25", the bottom should measure nominal 76.75". With the +/- 1" that would make the range 75.75" to 77.75".
Paul
Unread 02-03-2008, 12:38
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
We measured the Saint Louis Regional overpass height first thing Thursday since we needed to be pretty close to knock the ball off in hybrid. It was 76" to the bottom of the overpass tubing.
Unread 02-03-2008, 12:49
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Looking at the MWR field I definitely saw some sagging, but nothing that was getting in the teams' way.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 02-03-2008, 18:13
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Well, you must have missed seeing us get hung up half the time we went under the middle of the overpass.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 02-03-2008, 12:56
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
If the crossover drops two inches, you are going to hear a very loud crash when we go around. Luckily we can easily adjust our height, however, do both sides of the overpass drop the same amount? We will be fine if the crossover is held to +/- an inch, much more than that could cause trouble. We designed according to the specifications, if it looks like it ends up having more of a +/- 1.5 inches for a three inch range from one side to the other, that may cause problems for us and I am guessing several other teams. We would be fine if each side is kept within an inch or two of eachother to even +/- six or seven inches of the stated 78 inch height. How many flags are hitting the overpass? Will we be able to measure the overpass or could the field administration take measurements several times during the day and annouce/post the actual high and low points to the bottom of the tubing for clearance?
Unread 03-03-2008, 20:05
Originally Posted by Paul Copioli View Post
Wayne,
Paul
Paul- you are right- the 78" would be to the top but the bottom spec says approx. 76.5. A 75" robot should have cleared. Not to dwell on this- we will and did adapt.
Next time we'll just have the robot leap the overpass and knock the balls off on the way......
Unread 02-03-2008, 18:32
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
"And one other thing-
We ran into the same problem. we switched from a 1/8" thick angle to a 1/16" and we lost the weight
Unread 03-03-2008, 10:13
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Watching the webcasts of NJ & MidWest, there was noticable flex in the overpass when a bot would hit it. There was a ~2" 'bounce' at one point in the elims just from a launcher bot shooting the ball at it from underneath and hitting it.
This is a huge issue for us as we planned on setting our autonomous for a specific height -- if the overpass is too low we'll probably have the most hilarious high-speed flip-over in FIRST history -- 15ft/sec in hybrid . With the fatigue from the flexing, I wouldn't be surprised if we saw an overpass crack towards the end of the season -- hopefully the mounts for the overpass are replaced in between regionals.
GitHub
Unread 03-03-2008, 19:47
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Trust me robots hit that overpass all week b/c they forgot to lower themselves before going under. That overpass is not going anywhere unless the regional assembles it wrong. Shockingly enough I didn't see really any extra spare pieces of the field like I did last year. I saw one piece of spare driver station plexi but that was it. I guess FIRST also feels confident the field won't break.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
the overpass latonya General Forum 3 07-02-2008 20:14
Hurdling using the overpass robogeek753 Rules/Strategy 40 20-01-2008 17:02
How to get the ball over the overpass!? ar2 General Forum 63 11-01-2008 23:58
Carrying the ball under the overpass but across the finish line BaldGuy Rules/Strategy 13 09-01-2008 14:53
Its time for this generation to pick up the slack! KenWittlief Chit-Chat 23 10-02-2006 07:20
